Like Tree4Likes
 Old 08-29-2011, 10:49 AM   #41
JLee1469's Avatar
Posts: 1,195   (View Stats)
JLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the world
Originally Posted by J-Liss View Post
YO, if your not busy tommarow around 630 lets do the swap tommarow, should be really easy since were just loosening from the inlet pipe!
Gotta take off bumper to reach bolt on lower bracket
JLee1469 is offline   Reply With Quote
 Old 08-29-2011, 11:11 AM   #42
J-Liss's Avatar
Posts: 1,949   (View Stats)
J-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the world
Groans: 81
we should only have to take off splash shield to reach that bracket........
J-Liss is offline   Reply With Quote
 Old 08-29-2011, 03:30 PM   #43
bnoon's Avatar
Posts: 1,770   (View Stats)
Im sorry and im not ragging on your setup at all, but i do not like your set-up at all, i dont mind relocating my battery at all, and with a bigger tank that holds alot more water it will be easier to maintain cooler temps. I chose this core and location for a reason, down to it's size, psi compadability, Moving the battery to trunk maybe a big deal to you, but its a small thing to me. Not to mention It looks AWESOME in the engine bay for eye candy.
The first one isnt that bad, BUT this is a CUSTOM set-up to my liking and wants, not what others do, ive done countless hours of research on this, and spoke to a chemist teacher to see how i could get this to work best, and Cain did tons of research on his own part along with the shop till we came up with this, This has the angles and bends to the frame of the car to fit perfectly where i want it.
Not to mention with the battery gone and out the way it looks so much nicer and clean then everything just crammed togethor, i make things work the way i want them, and im not going to let a battery in the way change that.
you should really consider moving your water pump behind the headlight like im doing, looks so much cleaner, you want to see only the things neccesary.
Just stay tunned, sit back and watch me work
Sorry, but I think mine is a cleaner install, for the piping anyway. Your piping just looks wrong and needlessly too long to me. Mine has the minimum length of 3" piping allowed by the space given and I had tons of 3d modeling done to prove it. The only thing shorter is custom core shapes.
The pump I agree with, it looks better if it's hidden, but I've had it down below the bumper in a previous install and it was actually getting dirtier down there, so I came back to this.
As for the amount of research done, you won't win me over there either. Everything in my system is sized appropriately for the upgrades installed and planned. Proven by the BAT logs and never bested by anyone here yet.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
bnoon is offline   Reply With Quote
 Old 08-29-2011, 04:46 PM   #44
J-Liss's Avatar
Groans: 81
My IC was custom MADE completely from the core, mine was not just ordered complete, Im not sure if your pipes are actually shorter travel distance than mine, and if they are, that is not that big of a deal, IMO it seems your just worked with the space you had, and crammed your IC in there, and i can see causing you intake to be shoved against battery tray AND blocking any air flow it was receving from the cool air coming from the grill.
How much water can your IC hold at a time?
I do appreciate you putting "yet" at the end of your statement, because i intend to change that a friendly competition never hurt.
Not to mention you cant say your install is cleaner, when mine is not even on the vehicle yet....From my pic's before on my old water to air setup on my mazda 3, you can see how much cleaner it looks without the battery there. I dont know how my piping can Look wrong, if its made for this car, and not to mention my piping onto turbo is maybe 6" long with a 90 degree angle coupler and coupler to IC itself, i didnt need much piping in any instance at all.
I noticed you Powder coated everything, which is nice eye candy, but also serves as a insulation for heat which is taking away from the point of the cooling factor.
Was also reading on your HE location, i cant imagine your BAT's would be lower than mine, when i have one sitting in the lower grill.
 Old 08-29-2011, 05:01 PM   #45
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Im not so sure that pipe length makes that much difference, I also dont think that a bare alum pipe has any measureable cooling effect verses anything else. When air is going through that pipe at 300mph, that stuff is kind of a joke.
2006 Mazdaspeed 6
Enki (08-29-2011), J-Liss (08-29-2011)
 Old 08-29-2011, 05:34 PM   #46
J-Liss's Avatar
Groans: 81
it differentiates, torque really, but i could not see it really making a difference at all, although when you compare a short ram intake to a cold air, its not too much more added piping and the hp/tq numbers are greater and noticeable.
I agree about the piping be coated may not be a great difference but i want as efficient as possible, 1-5hp + if even that, or cooler pipes with cooler air travel means something to me, if it causes insulation, i wont do it, but just My opinion, again im not ragging on anyone here, and i hope bnoon isnt taking my posts as insulting.
I have one of your bnoon bolts on my car lol.
 Old 08-29-2011, 07:07 PM   #47
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
That insulation you don't want works both ways though; those pipes will get hot. Hell, my CP-E whale penis (TM) is hotter than fuck by the time I shut it down, and I had it ceramic coated.
 Old 08-29-2011, 08:54 PM   #48
J-Liss's Avatar
Groans: 81
if done correctly the pipes should not get that hot on my mazda 3 they stayed cool.
 Old 08-30-2011, 11:10 AM   #49
bnoon's Avatar
@J-Liss It's OK, we can agree to disagree on how things look. We can also disagree on how well things work. But for less than $500 invested, I gotz cooling skillz yo.
2002 BMW M3 - Sold!
 Old 08-30-2011, 03:32 PM   #50
J-Liss's Avatar
Groans: 81
Nice im at 710, with the custom core and pipes and heat exchanger and water pump.
Im going to have the IC on the car without the cooling effect this friday so pics to come, ill do some logging right now with my FMIC on and then compare to the water to air working properly on satuday. should be pretty sweet guys!
Stay tunned!
The Following User Says Thank You to J-Liss For This Useful Post:
Enki (08-30-2011)
 Old 08-30-2011, 04:19 PM   #51
Enki's Avatar
Groans: 189
Nice; I'll be ordering my air-water goodies this weekend most likely, and will have my new battery by then.
Planning stage to commence (again)!
 Old 08-30-2011, 11:47 PM   #52
J-Liss's Avatar
Groans: 81
What kind of setup are you going to be running?
Location of IC?
Heat exchanger...water pump. piping, etc?
 Old 08-31-2011, 02:51 AM   #53
Enki's Avatar
Groans: 189
I don't really want to say anything about placement until I've done the proper planning and determined that it will all work; that said, all CXRacing aluminum barring some goodies from Treadstone like a big blow through MAF and relocated BOV piping, with the possibility of meth injection just after the MAF.
The key adjective here will be "sleeper" though, should it lay out how I want.
J-Liss (08-31-2011)
 Old 08-31-2011, 11:42 AM   #54
J-Liss's Avatar
Groans: 81
Very nice, your set-up should look just like mine but with diffrent placement, i have meth going in after MAF, and BPV obvi before maf, and the fitting for meth is UNDER the pipe like when i had nitrous on my other 3, i would pop hood and NOBODY ever knew.
 Old 08-31-2011, 02:32 PM   #55
bnoon's Avatar
I like stealth!!! Can't wait to see it.
2002 BMW M3 - Sold!
The Following User Says Thank You to bnoon For This Useful Post:
J-Liss (08-31-2011)
 Old 08-31-2011, 02:45 PM   #56
mazdaspdmike's Avatar
Posts: 784   (View Stats)
mazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the world
Groaned at 50 Times in 30 Posts
i want more pictures, hurry up!
'12 Ford Focus SEL
mazdaspdmike is offline   Reply With Quote
The Following User Says Thank You to mazdaspdmike For This Useful Post:
J-Liss (08-31-2011)
 Old 08-31-2011, 04:31 PM   #57
J-Liss's Avatar
Groans: 81
LOL, im installing the cold air intake tonight, then im dropping it off @ performance autowerks so they can do WERK!
I should have it back thur night or friday for sho, ill post pics either day, then on saturday im going to install water pump and remove my FMIC system, and put heat exchanger in.
 Old 09-01-2011, 09:24 AM   #58
J-Liss's Avatar
Groans: 81
Alright guys, i ran into some trouble, i installed everything and all, and i let the car warm up fully and cruised around and whenever i punch it, the temp needle goes down and it goes to open loop mode, like a cold start, i let it idle warm again and i go punch on it, again, and again and the temp needle goes down and car goes back to cold start mode.....i will need to re-adjust water pump and slow down the flow, and this should correct the problem.
 Old 09-01-2011, 10:43 AM   #59
Enki's Avatar
Groans: 189
Wait, what temp needle? The engine temp needle? I hope you aren't using your engine coolant in the air/water kit...
 Old 09-01-2011, 02:01 PM   #60
J-Liss's Avatar
Groans: 81
LOL that was a joke to see who was following. Shop just sent me some teaser pics, LOOKIN GOOD!
 Old 09-01-2011, 02:11 PM   #61
Enki's Avatar
Groans: 189
You have a shop installing it? Wish I had that kind of money lol.
My Braille battery just showed up today; can't wait to tear into the engine bay and do some more planning.
J-Liss (09-01-2011)
 Old 09-01-2011, 03:50 PM   #62
J-Liss's Avatar
Groans: 81
Well i dont know how/own a tig welder so a shop needed to do it, i provided the pipes and told them how i wanted them to do it, and so i dropped it off for them to do today, and prob tommarow.
This saturday you guys get to see how im going to protect my ecu...haha its so hilarious but it'll work and for anyone else who does what im doing wouldnt be a bad idea to copy me, but i hope to do a mild wire tuck on this car like i did on my mazda...that was clean as FUUUU. But ill see what i can do with this one, i may need to order another BLOX vacuume manifold to get rid of some of these vacume lines.
@Enki do you plan to relocate battery? I may just turn this thread into my build thread after this is all said and done.
BTW my avatar is really my hood i sprayed that on the inside of the hood.
Last edited by J-Liss; 09-01-2011 at 03:50 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-01-2011, 05:05 PM   #63
Enki's Avatar
Groans: 189
I did plan on relocating the battery, but all said and done I really don't want to fuck around too much drilling holes in shit to run cables. We will see how I can make this Braille fit. If the way I do this works out well, I'll probably sell the design to someone like JBarone for mass production.
As a side note, the test slip said it tested at 13.09 volts and 757 cranking amps before shipping; I hope that's enough, but I really haven't had an issue with starting my car in the past. Usually only takes 1-2 seconds before it fires, even cold; considering there is a 100 amp fuse, and the starter probably takes only 80 of that it shouldn't be much of a problem.
Maybe I should put the battery in there and drive it around a bit to make sure, hah.
 Old 09-01-2011, 08:12 PM   #64
J-Liss's Avatar
Groans: 81
I got my car back man it looks awesome i LOVE IT
gets hot as FUCCCC without water connected!
Also why would you need to drill any holes anywhere, there is a 4" opening on the passenger side on the firewall.
 Old 09-01-2011, 10:17 PM   #65
Enki's Avatar
Groans: 189
A 4" opening ain't shit for two runs of 0 gauge, especially when sharing. Besides, I'd rather not have the cables come out next to the downpipe and run past the turbo; a couple of well placed and properly sealed holes in the firewall will do much more for me.
Also, depending on how the mock-up goes (possibly as soon as this weekend ) I may not even be doing the relocation to the back of the car.
Like I said, if I can do this right, it will be pretty fucking awesome and probably something to be duplicated.
 Old 09-01-2011, 10:59 PM   #66
J-Liss's Avatar
Groans: 81
two runs of 0 guage will go through just fine....although im assuming you only running one for the battery and the other for a sound system because you dont need to run one for the negative. Also the power wire goes well behind the turbo and manifold behind the heat shield and along firewall. not even close to DP as well. Anything can be duplicated, bnoons can be duplicated, its all a matter of what you want to do. Here is a pic im going to post of the IC on the car with NO HE or water pump just IC hooked up, i will pretty up the pipes this weekend.
 Old 09-01-2011, 11:26 PM   #67
J-Liss's Avatar
Groans: 81
Enki (09-02-2011)
 Old 09-04-2011, 05:07 AM   #68
J-Liss's Avatar
Groans: 81
INSTAll is 100% complete.....i had a 45 min drive home today, ambient temps were 70 degrees.....my temp DID NOT GO PASSED 81 degrees, EXCEPT WHEN I WAS AT A LIGHT IT WENT TO 94, as soon i started moving and kicked alittle boost in, IT WENT BACK DOWN TO 83-84-85. AS SOON AS I pulled in my driveway i hurry up and popped hood to feel IC....IT WAS SO COLD IT HAD CONDENSATION ON IT........thanks to @J-Lee for his minor support but support none the less in the install, hopefully he will upload the pics he took, and video!
Let me know what you guys wanna see? Im sure ull wanna see some logs.
45 min drive HOME and my IC is COLD, pipe coming off turbo IS COLD, and pipe to TB is cold, i knew my setup would be efficient but DAYUM! good old boat water pump, pushing 850 GPH
Last edited by J-Liss; 09-04-2011 at 05:08 AM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to J-Liss For This Useful Post:
06Speed6 (09-06-2011), Enki (09-04-2011)
 Old 09-04-2011, 10:05 AM   #69
JLee1469's Avatar
Sick josh. For comparison I drove the same drive in same conditions with a fmic and was cruising with temp at 102.
http://vid147.photobucket.com/albums...904_015114.mp4
Think that's ll of it
Sent from my DROIDX using Tapatalk
The Following 2 Users Say Thank You to JLee1469 For This Useful Post:
J-Liss (09-04-2011), tooslow10 (09-06-2011)
 Old 09-04-2011, 10:45 AM   #70
J-Liss's Avatar
Groans: 81
WOW are you serious dude!!! we both had around the same time drive home, and same temp, (we live near each other) WOOOOW MAN this is awesome im too happy ahahahahah
 Old 09-06-2011, 03:20 PM   #71
J-Liss's Avatar
Groans: 81
on a 65 degree day, my temps at a constant cruise was 71. This is without water wetter, so i expect better numbers with that.
how far you get bro?
Last edited by J-Liss; 09-06-2011 at 03:20 PM. Reason: MSF Database - Automerged Doublepost
Enki (09-06-2011)
 Old 09-06-2011, 03:38 PM   #72
Enki's Avatar
Groans: 189
Fully planned out, and almost done with the drilling until the fucking drill press broke. Chuck and bit spin freely by hand now.
Edit: My air/water shit will be here tomorrow, but I need to get the battery mount setup finished and ironed out before it can be mounted.
 Old 09-06-2011, 08:39 PM   #73
J-Liss's Avatar
Groans: 81
pics or lies
 Old 09-06-2011, 09:42 PM   #74
Enki's Avatar
Groans: 189
Pics of what? The broken drill press or the CXRacing A/W stuff due tomorrow?
 Old 09-06-2011, 10:32 PM   #75
tooslow10's Avatar
Posts: 700   (View Stats)
tooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the world
followed this thread and have pretty much decided on going this route over fmic. i have been to several sites looking at them, and it looks like a way diff approach (which i like) to get the same result, lower bat's. if u don't mind me asking, what are the hp goals ur shooting for with using this?
no more MS3 in the driveway
but there is an EcoBoost FX2 that will be hunting on the freeways soooon!!
TEAM LBN BEERS -- FYCN
TEAM MEAGHAN -- FYCN
tooslow10 is offline   Reply With Quote
 Old 09-06-2011, 11:34 PM   #76
Enki's Avatar
Groans: 189
I can't speak for OP, but I'm going to eventually target 500 @ the wheels, with a flat torque curve sitting right at or slightly above 300.
 Old 09-06-2011, 11:39 PM   #77
Speeeeeed
06Speed6's Avatar
I would like 600hp/1200'lb, no lie.
2006 Mazdaspeed 6
 Old 09-07-2011, 12:26 AM   #78
POWERED BY POLSKA
themytb's Avatar
Posts: 762   (View Stats)
themytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the world
Groans: 38
mazdaspeed f250? lol I think I have seen some of your posts mentioning your lust for high torque, but you serious about those numbers?
BNR S3---GS 3PORT---3bar map---COBB SRI & TIP---PG/GODSPEED FMIC ---DNP MANI--- CNT catted TBE--CP-E HPFP-- DIY P&P'd intake mani---SURE TIG(mani & tb)---DIY EGR delete---DIY VCTS delete--- DIY OCC/PCV reroute(through old egr port)---CP-E S2 RMM---JBR 80 PMM---TS BPV--- SURE ANCHORS---JBR shift weight---Whiteline RSB
25%E85FREEKPERMED
themytb is offline   Reply With Quote
 Old 09-07-2011, 01:55 AM   #79
Speeeeeed
06Speed6's Avatar
Yeah pretty serious. I have alot of the parts needed already.
2006 Mazdaspeed 6
 Old 09-07-2011, 07:48 AM   #80
J-Liss's Avatar
Groans: 81
Parts, and your plan out.
@2slow, i would love to hit 400ish hp and close to 500 trq, i got big things lined up, including e85, and meth...can you imagine, how cold the air my motor will be getting if i have water to air AND METH....sheeeeeeit.
@Enki those are good numbers to shoot for, if build the motor i want a little higher than that.
@06Speed6 .....may the force be with you, your looking at a straight drag car to be that, plus, you would need a serious water pump and IC if ur were looking to do water to air to support those numbers. the water pump would be easy to do, mine shoots 850 gallons per hour, and that's on mid low end. But hey if it can be dreamed it can be done!!
did you mean they went a way diff approach or i went a way diff approach?
Last edited by J-Liss; 09-07-2011 at 07:48 AM. Reason: MSF Database - Automerged Doublepost
Custom Water to Air Inercooler complete...PICS INSIDE Death-From-A-Mile MazdaSpeed 3/6 - Turbo Induction 107 10-03-2016 08:06 PM
COMPARISON: Labonte Stage 2 Water/Meth Kit vs. AEM Water/Meth Kit The Great NY Mazdaspeed Forums User Reviews 2 01-19-2013 08:48 AM
Page generated in 0.56739 seconds with 27 queries
