Notices
Like Tree13Likes
 Old 07-02-2012, 08:26 AM   #1
former 2007 MS6 owner
Worbit's Avatar
Posts: 1,231   (View Stats)
Groans: 113
Groaned at 36 Times in 25 Posts
Default My FAILED attempt to install Autotech internals :(
EDIT:
Please feel free to GROAN the fuck out of me since I should have read all the stickies on this board
Long story short, we were following the Autotech instructions which said to remove the pressure release valve and when we started to rebuild the pump we heard a snap when we were screwing the valve back on. Now we get some serious movement in the valve and it throws a code......talk about a learning experience. I don't know much about engines so I'm not too pissed at myself but this still sucks.
After talking to some people I found out that you DO NOT have to remove the pressure release valve when swapping out the internals. I hope that this thread helps others who install internals so they don't do the same thing I've done. Now I am in search of a whole new pump since Mazda doesn't sell just the valve by itself.
2008 BM Mazdaspeed3 GT
Cobb AP - Stage 1+ OTS //Cobb SRI // Cobb TIH // TRZ RMM //Autolite Iridium Spark Plugs
TurboXS CBE // Black Forge BPV V.1// Autotech FP internals// EvoX wheels //Suabru STi s204 lip
JBR Short Shifter Plate
The Following 2 Users Say Thank You to Worbit For This Useful Post:
jack_hammer (07-03-2012), tddvrrn (07-02-2012)
The Following 2 Users Say NO Thank You to Worbit For This Un-useful Post:
BrianZX10R (07-07-2012), Joe Isuzu (07-07-2012)
 Old 07-02-2012, 08:28 AM   #2
Posts: 5,629   (View Stats)
Groans: 58
Dood, there is a sticky here on the forum on that! Arrrrg!!!
Sponsored driver~~~First amphibious PU~~~World record fastest fully bolted 2013 Pu! Fast Pu is Fast best ET> 12.586 best trap> 114.25. Thanks to all who helped me get back in the Pu!
kritz is online now   Reply With Quote
danieldolina70 (07-07-2012)
 Old 07-02-2012, 08:30 AM   #3
Worbit's Avatar
Groans: 113
I missed that thread clearly......read some of the others but lesson learned.
 Old 07-02-2012, 08:30 AM   #4
(Toe-kay)
Tokay444's Avatar
Posts: 9,508   (View Stats)
Groans: 501
See what SPEED6 KILLAH can get you in the way of parts. He seems to be quite resourceful.
Demodded.
Mwho?
danieldolina70 (07-07-2012), kritz (07-02-2012)
 Old 07-02-2012, 08:38 AM   #5
Groans: 58
No need to remove the spill valve unless cleaning it. The complete pump needs to be removed and then the pump must be held in a bench vice and an 18mm deep socket needs to be put over the spring piston assembly to gain access to remove teh OEM piston and sleeve. What did you use to remove the spill valve? I hope a 32 mm open end wrench, you prolly broke the plastic plug on it. You make me so mad! Ask for help next time you are in over your head please.
danieldolina70 likes this.
The Following 3 Users Say Thank You to kritz For This Useful Post:
danieldolina70 (07-07-2012), Dmurray06 (07-02-2012), Worbit (07-02-2012)
The Following User Says NO Thank You to kritz For This Un-useful Post:
 Old 07-02-2012, 10:56 AM   #6
Worbit's Avatar
Groans: 113
I thought I had read enough threads on the process and figured it was ok to follow the autotech instructions. I was trying to finally do something on my own rather than rely on others and the conclusion is that I should stick to getting help lol. Anyways, my friend found a dealer that can get a full pump to us by tomorrow, he's just double checking to make sure its in stock.
The Following User Says Thank You to Worbit For This Useful Post:
kritz (07-02-2012)
 Old 07-02-2012, 11:18 AM   #7
richkidone's Avatar
Posts: 108   (View Stats)
richkidone has a brilliant futurerichkidone has a brilliant futurerichkidone has a brilliant futurerichkidone has a brilliant futurerichkidone has a brilliant futurerichkidone has a brilliant futurerichkidone has a brilliant futurerichkidone has a brilliant futurerichkidone has a brilliant futurerichkidone has a brilliant futurerichkidone has a brilliant future
Check prices and see if the cp-e pump cost the same as stocker and just get that.
Sent from my SGH-T989 using Tapatalk 2
2011 lsm w/tech pack K&N sri/hks w/recirc kit / AP+autotech internals /UR racepipe/ cobb TIH /downpipe/ tigs/ rear mount inserts/ngk ltr7ix
"IM LOVING IT"
richkidone is offline   Reply With Quote
The Following 2 Users Say Thank You to richkidone For This Useful Post:
Dahouse702 (07-02-2012), danieldolina70 (07-07-2012)
 Old 07-02-2012, 11:19 AM   #8
breakfstincluded's Avatar
Posts: 2,681   (View Stats)
Groans: 173
nice sig
The Following User Says Thank You to breakfstincluded For This Useful Post:
ScarMS3 (07-02-2012)
 Old 07-02-2012, 11:22 AM   #9
Slow Canuck
Bob-o's Avatar
Posts: 636   (View Stats)
Bob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the worldBob-o is the leader of the world
Extra test pipe for the extra powah. Must be a genpu thing.
@OP Ask for help next time so you can avoid things like this! This is one of the installs that you need to have go 100% correct
Bob-o is offline   Reply With Quote
The Following User Says NO Thank You to Bob-o For This Un-useful Post:
 Old 07-02-2012, 11:25 AM   #10
Spoofmastafly's Avatar
Posts: 1,290   (View Stats)
Spoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the worldSpoofmastafly is the leader of the world
Blows man, Autotech instructions are ment for the VW. Try sourcing a pump from a junkyard. Might get lucky! I know I saw some OEM pumps forsell in the forsell section.
Spoofmastafly is online now   Reply With Quote
 Old 07-02-2012, 11:38 AM   #11
Worbit's Avatar
Groans: 113
So the dealer is saying he can get us the OEM pump for $399....that sounds a little too cheap correct? Shouldn't this run me around $650+?
I'm also looking at ebay at this point.....I'm just not sure I wanna get a pump from a wrecked car
http://www.ebay.com/itm/05-06-07-MAZ...3f8fd3&vxp=mtr
 Old 07-02-2012, 02:41 PM   #12
richkidone's Avatar
Maybe Ebay one has internals done already lol.
"IM LOVING IT"
 Old 07-02-2012, 02:50 PM   #13
Needs GHES
Etipp98's Avatar
Posts: 1,137   (View Stats)
Groaned at 6 Times in 3 Posts
Ive seen new pumps go for 300 on here. ms6ms6 usually is the one selling them that cheap.
Needs to install the GHES.
Etipp98 is offline   Reply With Quote
 Old 07-02-2012, 04:27 PM   #14
Worbit's Avatar
Groans: 113
brand new pump was just purchased from local dealer for $399 + Tax
phate (07-02-2012), Tokay444 (07-02-2012)
 Old 07-02-2012, 08:22 PM   #15
SPEED6 KILLAH's Avatar
Posts: 1,039   (View Stats)
pm me I can get you a deal on one
SPEED6 KILLAH is offline   Reply With Quote
The Following User Says Thank You to SPEED6 KILLAH For This Useful Post:
Tokay444 (07-03-2012)
 Old 07-02-2012, 09:18 PM   #16
rodrigo's Avatar
Posts: 17,647   (View Stats)
Groans: 345
Groaned at 491 Times in 371 Posts
expensive lesson...... research shit b4 hacking at it man... wtf is this forum for ??
- I see meh people
The Following 3 Users Say Thank You to rodrigo For This Useful Post:
danieldolina70 (07-07-2012), emag remrofni (07-02-2012), tddvrrn (07-02-2012)
 Old 07-03-2012, 12:09 AM   #17
Worbit's Avatar
Groans: 113
That's the thing, I thought I had done my research
 Old 07-03-2012, 07:11 AM   #18
jack_hammer's Avatar
Posts: 4,158   (View Stats)
Groans: 412
Groaned at 105 Times in 61 Posts
fuck it. things like that happen time to time. at least you're not on here complaining.
it's fun to do bad things
 Old 07-03-2012, 12:08 PM   #19
Worbit's Avatar
Groans: 113
Thanks to TWOptSL0W I will soon have a fuel pump for my car. Thanks again man!
danieldolina70 (07-07-2012), kritz (07-03-2012)
 Old 07-06-2012, 08:41 PM   #20
rodrigo's Avatar
Groans: 345
yeah at least youre not some whinning cunt that blew up cuz he floored it in 6th at 25 mph uphill
- I see meh people
The Following 2 Users Say Thank You to rodrigo For This Useful Post:
danieldolina70 (07-07-2012), Worbit (07-06-2012)
 Old 07-06-2012, 08:45 PM   #21
pzr2874's Avatar
Posts: 3,911   (View Stats)
Groans: 89
Groaned at 103 Times in 69 Posts
This is why people need to stop making half-assed installs on this (how-to's or whatever)
Do what he says with a vice and clean EVERYTHING
2007 CBM MS3
Originally Posted by Macncheese View Post
Sniff sniff... Bunch of vaginas in here.
R.I.P.
JVella22
MacnCheese
bmylez
The Following 2 Users Say Thank You to pzr2874 For This Useful Post:
danieldolina70 (07-07-2012), kritz (07-07-2012)
 Old 07-06-2012, 10:54 PM   #22
Worbit's Avatar
Groans: 113
Oh hell no, I have no problem admitting when I screw up. This forum has shown me what happens when you come running here just to bitch and moan about how you didn't know this or that. I thought I had read up enough on it but I guess I just missed the one sticky that said "Hey asshole, DO NOT REMOVE THIS PART" - Lesson learned
Well, the pump I bought from TWOptSL0W turned out to be damaged by Fedex so I'm back and square one. I *might* go back to the dealership and pick up the brand new one if I cant find a used one, but I REALLY dont want to do that if I dont have to. My girl and I are trying to get into a new house so this is happening when funds are pretty tight
http://www.mazdaspeedforums.org/foru...l-pump-117832/
kritz likes this.
 Old 07-06-2012, 11:04 PM   #23
rodrigo's Avatar
Groans: 345
pics of said girl .....
- I see meh people
 Old 07-06-2012, 11:11 PM   #24
Worbit's Avatar
Groans: 113
Haha, she knows about what goes on around these parts and checks the forum often (I stay logged in on both comps because I am too lazy to log in each time) She said if she ever caught me posting the good stuff online I would never get'em again. Instead, I can post stuff like the one below.....
thats all you get
kritz likes this.
tddvrrn (07-10-2012), Tokay444 (07-07-2012)
 Old 07-06-2012, 11:26 PM   #25
rodrigo's Avatar
Groans: 345
why would u give a shit if your gf didnt give u any pics?? arent u guys a lil past sexting???
im just pointing out that u have not much to really lose by posting noodz.... just consider it , i aint here to twist no ones arm .... just business
kritz and danieldolina70 like this.
- I see meh people
The Following User Says Thank You to rodrigo For This Useful Post:
 Old 07-06-2012, 11:29 PM   #26
Worbit's Avatar
Groans: 113
This is about as close as I will get to posting noodz
The Following 3 Users Say Thank You to Worbit For This Useful Post:
meicalnissyen (07-07-2012), mrmonk7663 (07-07-2012), tddvrrn (07-10-2012)
 Old 07-06-2012, 11:33 PM   #27
rodrigo's Avatar
Groans: 345
its a start , i like where we are headed. i think u should take a deep breath ....kiss your gf good night and go to sleep.....its been a important night tonight and i believe we made a breakthrough.... tomorrow when the heartbeat is back to normal , we are all well rested we can resume discussing what kind of noodz of your chick we need to see.
listen its for the guys ..... i have free porn all day long .... whats one more, ....but the guys....man they just wanna see , ..... anyways get some good rest and we ll wrap it up tomorrow
kritz likes this.
- I see meh people
danieldolina70 (07-07-2012), meicalnissyen (07-07-2012), Tokay444 (07-07-2012)
 Old 07-06-2012, 11:40 PM   #28
GODspeed7's Avatar
Posts: 2,614   (View Stats)
Groaned at 46 Times in 31 Posts
He doesn't say to clean everything. There is no need to take the pump completely apart and clean it. Just replace the internals and make sure they are clean!
2012 Mazdaspeed3 Black Mica
HYPNOTIC TUNED, HTP full 3" intake system, HKS SSQV 4 full VTA, Corksport 65mm Racepipe, Cobb AP, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 70duro PMM, JBR cylindrical shift knob, DDM tuning HID's lows and fogs, Resonator Delete.
 Old 07-06-2012, 11:50 PM   #29
rodrigo's Avatar
Groans: 345
ive taken apart and put together 30 or so .... i clean the cylinder, the piston the retainer nut spring , locks ...EVERYTHING..... the main reason is this ....not what u might think.
when everything is clean its easy to spot a piece of dirt, or any foreign matter on the pieces, ...when they are in the black oil they come with things can hide....
do me a favor and look where the pump is discolored into charred marks.... do u think those char marks are liquid???
CLEAN EVERYTHING ...... not one of my pumps ever failed
p.s. u wont find it on any manual , ....because common sense should come standard in all human beings but as we all know that is not the case sadly
pzr2874 and kritz like this.
- I see meh people
Last edited by rodrigo; 07-06-2012 at 11:50 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-07-2012, 04:34 AM   #30
Groans: 58
Dude, I go O.C.D. on the pump, the tools,the vice. Cleanliness is Uber important, importante 重要な, 거드름 피우는 get it! This makes the difference between happy pump or fail pump.
Worbit>>>>> Thanks for the koi photo!
Worbit (07-07-2012)
 Old 07-07-2012, 06:35 AM   #31
pzr2874's Avatar
Groans: 89
Depends on the mileage. I douched the fuck outta mine with 100K on it. No reason to 1/2 ass something that important. But everybody is different. It is what it is.
2007 CBM MS3
R.I.P.
JVella22
MacnCheese
bmylez
 Old 07-07-2012, 06:47 AM   #32
timjs's Avatar
Posts: 436   (View Stats)
timjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the world
If you find yourself still needing a pump, I have a stocker sitting here I could sell you.
It was my original. I got another pump off an engine job at work and put ATs in it and swapped with my stocker. Let me know if i can help.
kritz likes this.
timjs is offline   Reply With Quote
 Old 07-07-2012, 07:25 AM   #33
Worbit's Avatar
Groans: 113
timjs - yeah man, PM me a price and I will take it off of your hands.
rodrigo - where the hell are my thanks for the photo above? The same goes for everyone else in here
 Old 07-07-2012, 09:42 AM   #34
pzr2874's Avatar
Groans: 89
Lenny's a PIMP....
2007 CBM MS3
R.I.P.
JVella22
MacnCheese
bmylez
 Old 07-07-2012, 10:20 AM   #35
rodrigo's Avatar
Groans: 345
give me something to jerk off to and then ill give u thanks motherfucker .....i aint fucken stroking it to a coy fish .....da fawk
- I see meh people
Ms3_Miami (07-09-2012), pzr2874 (07-07-2012), voltron (07-09-2012)
 Old 07-07-2012, 10:38 AM   #36
Worbit's Avatar
Groans: 113
No one gets to spank it to pix of my girl, but I will leave this photo of a hot Asian for all your pleasures
kritz (07-07-2012)
 Old 07-08-2012, 11:06 AM   #37
Worbit's Avatar
Groans: 113
So after thinking it over the last few days I think I'm going to toss in the towel and sell the internals so I can move on from this disaster. Quick question to everyone here:
how safe is it to run the Cobb SRI & TIP without internals?
 Old 07-08-2012, 11:21 AM   #38
radioflyer's Avatar
Posts: 431   (View Stats)
radioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the world
Personally I wouldn't run any intake modifications without an AP so that you can recalibrate the MAF. Some would argue its counter productive.
Power: // K&N SRI // Cobb TIH // ETS TMIC // CNT Catted Turbo-Back // AT Internals // ITV-22's
Tuning & Fuel: Cobb AP // 25% e85/91oct // Cobb EBCS // Stratified Tuned
Suspension: Koni Yellows // Swift Spec R Springs // Hotchkis FSB // JBR RSB
Mounts: CPE Stage 2 RMM // CPE PMM // CPE TMM
Shifting: Corksport SSP // Corksport Shifter Assembly Bushings
Wheels & Rubber: XXR 527 // Some crappy free tires at the moment
How to make your car BSOD:
http://www.mazdaspeedforums.org/forum/f13/carputer-105207
radioflyer is online now   Reply With Quote
 Old 07-08-2012, 11:55 AM   #39
GODspeed7's Avatar
Where in his post did he say he was going to run an intake and TIP without an AP? He said without internals.
 Old 07-08-2012, 11:57 AM   #40
radioflyer's Avatar
His modlist?
Autotech internals install Mazdaspeed666 MazdaSpeed 3/6 - ECU Computer Tuning 4 06-22-2012 01:55 PM
Autotech Internals install help!!!! Jake_MS3 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 44 04-02-2012 04:12 PM
Abilor's Autotech Internals Install Adventure Abilor MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 8 03-04-2012 08:56 PM
NATOR Failed FP Internals Install bioevolve MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 28 02-22-2010 08:13 AM
Page generated in 0.62029 seconds with 35 queries
