Like Tree40Likes
 Old 01-21-2013, 01:50 PM   #41
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Doesn't matter what angle the intake is on as far as valve wetting is concerned. You're batch firing, and that valve is always going to close.
"Exclusivity" - CP-enis
Demodded.
The Seals
The Following 5 Users Say Thank You to Tokay444 For This Useful Post:
Easter Bunny (01-21-2013), phate (01-21-2013), rfinkle2 (01-21-2013), sidekick (01-22-2013), SilverDemon (01-21-2013)
 Old 01-21-2013, 01:55 PM   #42
SilverDemon's Avatar
Posts: 3,034   (View Stats)
I thought the meth system is batch fire.....??? (don't answer, that was sarcasm)
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 4 Users Say Thank You to SilverDemon For This Useful Post:
Realgib3 (01-21-2013), rfinkle2 (01-21-2013), Tokay444 (01-21-2013), Tomas (10-02-2014)
 Old 01-21-2013, 02:02 PM   #43
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
In any case, regardless of the group of ideas used, both camps are providing fueling that will be leaps and bounds more reliable than pre-throttle body meth injection.
Hell, erich made 700 + hp with an ots Snow Performance kit.
The Following 7 Users Say Thank You to rfinkle2 For This Useful Post:
atvfreek (02-04-2013), NJSPEED3 (01-21-2013), sidekick (01-22-2013), SilverDemon (01-21-2013), superskaterxes (01-21-2013), Tokay444 (01-21-2013), wolly6973 (01-21-2013)
 Old 01-21-2013, 03:03 PM   #44
Celestspeed3's Avatar
Posts: 1,136   (View Stats)
Celestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the world
Groaned at 55 Times in 26 Posts
Well aside from the colors I think this is probably the regulator of choice.
-8AN to match the intank pump and AN boost fitting for extra piece of mind. Also rebuild-able and alcohol friendly. It also does up to 85psi so you can meter fuel properly if you choose to boost to 45psi.
MagnaFuel EFI Fuel Pressure Control Units MP-9950-B - SummitRacing.com
I think this will be able to supply just about any injectors we plan on using.
Thoughts, comments, suggestions?
Fueled by the haters.
Celestspeed3 is offline   Reply With Quote
The Following 2 Users Say Thank You to Celestspeed3 For This Useful Post:
Realgib3 (01-21-2013), SilverDemon (01-21-2013)
 Old 01-21-2013, 03:07 PM   #45
I like it...other than the colors...lol!
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 01-21-2013, 06:12 PM   #46
Realgib3's Avatar
Posts: 2,443   (View Stats)
Groans: 52
Scott your engine bay makes me so fucking mad. My next mod is engine bay cleanup so I'm not 100% embarrassed to park next to you at the meet in April.
The Following 4 Users Say Thank You to Realgib3 For This Useful Post:
atvfreek (02-04-2013), Easter Bunny (01-22-2013), NJSPEED3 (01-21-2013), SilverDemon (01-21-2013)
 Old 01-21-2013, 06:13 PM   #47
lol says the guy who claims u dont need a fpr haha
jkjk
personally i like the radium engineering one with a set base pressure thats boost referenced. theres really no need for it to be adjustable since we arent using it at idle/pt and it just takes 1 more thing out of the tuning equation. im still deciding wether i want to do 3 bar or 4 bar for a base pressure though.
Celestspeed3 likes this.
Celestspeed3 (01-21-2013), Mylifeiseasy (08-27-2017)
 Old 01-21-2013, 06:17 PM   #48
Realgib3's Avatar
Groans: 52
jkjk
I'm running at 65psi and its running great. No data to support the pressure I'm using, other than the fact that In the real world its working perfectly, consistantly, at least as high as ~33psi of boost so far.
The Following 5 Users Say Thank You to Realgib3 For This Useful Post:
atvfreek (02-04-2013), Easter Bunny (01-22-2013), sidekick (01-22-2013), SilverDemon (01-21-2013), wolly6973 (01-23-2013)
 Old 01-21-2013, 06:19 PM   #49
Tokay444's Avatar
Groans: 793
Then you need to change your damn sig.
Demodded.
The Seals
 Old 01-21-2013, 06:27 PM   #50
Realgib3's Avatar
Groans: 52
Lol, changed. Back to the 8 injector epicness of this thread now.
The Following 2 Users Say Thank You to Realgib3 For This Useful Post:
SilverDemon (01-21-2013), Tokay444 (01-21-2013)
 Old 01-21-2013, 06:34 PM   #51
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,798   (View Stats)
Originally Posted by boost_addict View Post
I think you guys may be over-thinking this a little bit. Sure, this set up may not be perfect and the fuel may not be perfectly atomized, but guess what, it will work just fine. Look at all of the big, carbeurated V8s that manage to make huge power by literally just dumping fuel into the intake manifold. You think they give a shit about fuel pooling or atomization? It's really not that big of a deal since we are only using this as AUX fueling. The only problem that I foresee this causing, would be making it hard to tune for the extra fuel. Even if fuel is pooled up on the intake valves, the second they open with 20+ PSI of boost flowing past them, I believe that the fuel will mix with the air pretty quickly. Perfect atomization is really only a big deal in low load/low throttle situations to get a complete burn. At full boost and high load, it really isn't going to make a significant difference in power output and I seriously doubt it will cause issues.
^ This.
Lol @ fuel going down the head runners like Niagara falls.
GM ran throttle body injection systems with what they call "wet manifolds" for most of the 80s and they have much worse fuel atomization than this set up. Shit I remember working on my old Deville and looking at the 2 injectors fire into the throttle body when you you took the air intake out. You literally see the fuel coming out of the injector hitting the throttle blade and think how the fuck does the fuel get to the combustion chamber but it does.
SCOTT YOU ARE DOING JUST FINE DON'T LET THE HATERS POOP ON YOUR PARTY LOL PS I LOVE YOU AND ITS NOT JUST THE ALCOHOL TALKING.
MAKE LOVE TO THE CANVAS
The Following 10 Users Say Thank You to Tomas For This Useful Post:
atvfreek (02-04-2013), Downmented (02-25-2013), Easter Bunny (01-22-2013), jmhinkle (01-22-2013), ms3blackmica (05-15-2013), phate (01-21-2013), sidekick (01-22-2013), SilverDemon (01-21-2013), SPEED6 KILLAH (01-21-2013), wolly6973 (01-23-2013)
 Old 01-21-2013, 06:39 PM   #52
Tokay444's Avatar
Groans: 793
Demodded.
The Seals
The Following 11 Users Say Thank You to Tokay444 For This Useful Post:
BlueStreak (01-21-2013), Dano (02-22-2013), Downmented (02-25-2013), Easter Bunny (01-22-2013), jmhinkle (01-22-2013), ms3blackmica (05-15-2013), psychophyr (03-21-2013), Realgib3 (01-21-2013), sidekick (01-22-2013), SilverDemon (01-21-2013), wolly6973 (01-23-2013)
 Old 01-21-2013, 07:05 PM   #53
BlueStreak's Avatar
Posts: 1,467   (View Stats)
^^^ Wall wetting and pooling at valves.
Won't work.
'07 CWP MS3
Forged.
The Following 4 Users Say Thank You to BlueStreak For This Useful Post:
Easter Bunny (01-22-2013), phate (01-21-2013), SilverDemon (01-21-2013), Tokay444 (01-22-2013)
 Old 01-21-2013, 07:27 PM   #54
Eth Fiend
phate's Avatar
Posts: 6,935   (View Stats)
heh, it'll be fine. I was just going to say that carb manifolds have been drilled for injectors for years with little (no) consideration of using regular ole injectors that fire right onto the opposite wall of the manifold. 16 injectors, 2000+hp and they're fine, let alone the F1 crazies like the above video shows.
The only time I've really heard of wall wetting being a concern in PI setups is for cold start emissions and AFR control. Since you spray and some fuel impinges on the opposite wall, that fuel delivery calculation was just skewed. Some of it evaporates in time for the next sequence...more impinges....it just screw with things a little bit. Aaaannnnddddd we won't really be using the PI for cold start
Edit: Sounds like some DI concerns, just in a different part of the engine, no?
Edit: Nice work man. Wish I had those tools to play with
-06 MS6
-Corn fed 07 MS3 - Sold
Easter Bunny (01-22-2013), jracer (01-21-2013), SilverDemon (01-21-2013)
 Old 01-22-2013, 04:17 AM   #55
so wait your running 65psi but you have no mechanical gauge to tell you thats what your running at?
 Old 01-22-2013, 05:19 AM   #56
Realgib3's Avatar
Groans: 52
No, I have a guage on the fpr.
So just nothing in the cabin for now. I set the base pressure under the hood and I'm good to go. I don't really feel there's a need for a gauge in the cabin but maybe down the road I'll change my mind
The Following User Says Thank You to Realgib3 For This Useful Post:
superskaterxes (01-22-2013)
 Old 01-22-2013, 05:33 AM   #57
out of curiosity what were the conditions under which you set the pressure?
also, can you draw us a quick diagram of how your entire system is setup?
Downmented (01-22-2013), Realgib3 (01-22-2013)
 Old 01-22-2013, 05:46 AM   #58
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
SarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the world
Groaned at 8 Times in 4 Posts
Preferably in ms paint so everyone can understand it
Dano likes this.
OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPV
NEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP
SarcasticOne is offline   Reply With Quote
The Following 9 Users Say Thank You to SarcasticOne For This Useful Post:
amoosenamedhank (01-22-2013), atvfreek (02-04-2013), cld12pk2go (01-22-2013), Dano (02-22-2013), Downmented (01-22-2013), magicka (01-22-2013), Realgib3 (01-22-2013), SilverDemon (01-22-2013), superskaterxes (01-22-2013)
 Old 01-26-2013, 11:38 AM   #59
Realgib3's Avatar
Groans: 52
set the pressure in ~40* ambient temp with the pump on, engine off, after I let it run for ~1min.
Sorry it's been such a long wait, but here's the diagram. Enjoy. If anyone has specific questions just let me know.
jmhinkle, Dano, atvfreek and 1 others like this.
The Following 18 Users Say Thank You to Realgib3 For This Useful Post:
09Speed3Z (05-15-2013), atvfreek (02-04-2013), cld12pk2go (01-26-2013), CWP_MS3 (11-07-2014), Dano (02-22-2013), Etipp98 (01-26-2013), forcedinduktion (04-06-2013), impossible (05-20-2017), jmhinkle (01-26-2013), magicka (01-26-2013), ms3blackmica (05-15-2013), NJSPEED3 (01-29-2013), psychophyr (03-21-2013), rigor (04-16-2013), SarcasticOne (01-26-2013), SilverDemon (01-26-2013), Tokay444 (01-26-2013), Ziggo (01-26-2013)
 Old 01-26-2013, 12:25 PM   #60
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
So. Much. Win.
The Following 7 Users Say Thank You to cld12pk2go For This Useful Post:
atvfreek (02-04-2013), DSIT995 (04-13-2013), jmhinkle (01-26-2013), ms3blackmica (05-15-2013), NJSPEED3 (01-29-2013), Realgib3 (01-26-2013), SilverDemon (01-26-2013)
 Old 01-26-2013, 12:46 PM   #61
Realgib3's Avatar
Groans: 52
So. Much. Win.
Mad paint skillz yo. hahaha I was bored today if you couldn't tell.
The Following 3 Users Say Thank You to Realgib3 For This Useful Post:
atvfreek (02-04-2013), cld12pk2go (01-26-2013), SilverDemon (01-26-2013)
 Old 01-26-2013, 12:51 PM   #62
I finished up a little bit more of the work this week. Cut one inch of the fuel rail off each end, made brackets for the rail itself, and had everything welded together by a very talented welder (not me..lol).
Tapped the rail for 9/16x18 thread, cut a chamfer for the -6 o-ring fittings. Made up a return line for mock up purposes. The return line fitting just clears the power steering hard line.
Downmented likes this.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 23 Users Say Thank You to SilverDemon For This Useful Post:
atvfreek (02-04-2013), BlueStreak (01-26-2013), cld12pk2go (01-26-2013), daafisch (02-25-2013), Dano (02-22-2013), Downmented (02-25-2013), JacksonMS30 (01-26-2013), jmhinkle (01-26-2013), jracer (01-26-2013), kritz (02-22-2013), magicka (01-26-2013), ms3blackmica (05-15-2013), NJSPEED3 (01-29-2013), psychophyr (03-21-2013), Realgib3 (01-26-2013), SarcasticOne (01-26-2013), silvapain (02-04-2013), speed3sailor (02-04-2013), superskaterxes (02-04-2013), Tokay444 (01-26-2013), Tomas (01-26-2013), wolly6973 (01-26-2013), Ziggo (01-26-2013)
 Old 01-26-2013, 01:19 PM   #63
Scott have you considered running the return into the stock line as @Ziggo; suggested in the other thread.
The Following User Says Thank You to Celestspeed3 For This Useful Post:
 Old 01-26-2013, 01:24 PM   #64
No, I honestly have not thought about that option. It could simplify the install though.
At this point I am not totally committed to one way or the other.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following User Says Thank You to SilverDemon For This Useful Post:
Tomas (10-02-2014)
 Old 01-26-2013, 01:29 PM   #65
Tokay444's Avatar
Groans: 793
Looks real trick.
Demodded.
The Seals
kritz (02-22-2013), SilverDemon (01-26-2013)
 Old 01-26-2013, 01:31 PM   #66
You can also bend the power steering line to give you more room. I did that on marinemazda's car to fit his intercooler piping in.
I would run the feed to the fitting by the power steering. Out of the rail to the hpfp. Then to the regulator and to the stock return line. Russel makes the AN fittings that fit the stock line as well as the hpfp.
 Old 02-04-2013, 06:08 AM   #67
speed3sailor's Avatar
Posts: 835   (View Stats)
speed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the world
this build makes me feel funny in my pants.....
ive got a newb question... why cant you run this setup as your primary fueling?
07 SILVER Speed3 , BNR S3- Tial 38mm EWG w/ stock mani- COBB AP- Ebay catless Downpipe- HTP 3in intake- Devils Own WMI (D10)- CX Racing FMIC- Autotech internals- Grimmspeed 3P EBCS- Denso ITV22- HKS super SQV- Bosch 3 bar - Damon PMM- JBR RMM- shift weight- EGR delete- TIGs- JBR RSB- Eibach springs- TR Motorsports 17x9- Hankook RS-3 255/40/17
speed3sailor is offline   Reply With Quote
The Following User Says Thank You to speed3sailor For This Useful Post:
SilverDemon (02-04-2013)
 Old 02-04-2013, 06:23 AM   #68
Thanks!
To date there is no controller that will sequential fire the injectors, only batch fire.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 02-04-2013, 07:21 AM   #69
Well, there is it's just not cost effective. You could wire up a standalone to just handle the fueling of these injectors. If you go that far might as well just not use the disi sytem altogether. The cost factor is simple not worth it.
On the other hand I have access to a piggyback controller that will mimic the tigger order of the stock injectors. When the injector of that cylinder fires it will fire the port injector of the same cylinder and all you have to do is adjust the pulse width, based on RPM and MAF voltage.
 Old 02-04-2013, 07:57 AM   #70
trf5000's Avatar
Posts: 2,290   (View Stats)
Even this would require some specialized tuning, because a port injector would need to fire at a different time than the direct injector. The direct injector is firing when the intake valve is closed whereas the port inject would need to fire slightly earlier when the intake valve is open.
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
The Following 3 Users Say Thank You to trf5000 For This Useful Post:
kritz (02-22-2013), magicka (02-04-2013), SilverDemon (02-04-2013)
 Old 02-04-2013, 08:16 AM   #71
I don't think so. Batch firing willfire when the valve is closed anyway. If you use an injector that flows enough to keeo the stock duty cycle around 80% than the fuel is only being sprayed when the valve is open. 4x 1000cc injectors should give enough fuel to run the car at high load without even needing the stock injectors. So I don't think it would be too hard to tune.
Downmented (02-04-2013), sidekick (02-04-2013)
 Old 02-22-2013, 11:08 AM   #72
jreiden1's Avatar
Posts: 237   (View Stats)
jreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the worldjreiden1 is the leader of the world
Groaned at 4 Times in 2 Posts
so is anyone running and safely tuned with 4 aux injectors (port injection)???
2006 WWP Mazdaspeed 6
KILLAH BUILT 700+ AWHP TUNED BY NISHAN
jreiden1 is offline   Reply With Quote
 Old 02-22-2013, 11:09 AM   #73
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
Is there any reason you have Pablos motor/ turbo setup as your avatar picture?
700HP CLUB
11.479@124mph
#DIX
 Old 02-22-2013, 11:13 AM   #74
jreiden1's Avatar
its honestly one of the best looking set ups i have seen... and if it didnt involve moving and relocating so much stuff i would have been interested, but it does... so every time im on the forums it reminds me of the beauty that ill never own
 Old 02-22-2013, 11:20 AM   #75
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
Where can i order the exh mani in that pic lol and the DP
Damond Built Speed 6
Deldran is offline   Reply With Quote
 Old 02-22-2013, 11:30 AM   #76
jreiden1's Avatar
you can't it's only in testing for measurements and fittings, and really only a race application... custom downpipe... thats why i said ill never own it, and....
im just looking for an answer if any one is running port, and how they tuned for it?
too many questions... it was just an avatar *sigh*
Last edited by jreiden1; 02-22-2013 at 11:30 AM. Reason: MSF Database - Automerged Doublepost
 Old 02-22-2013, 01:26 PM   #77
As far as I know no one is running a true port system yet (batch fire or other wise). I am not running currently as I am still in the mock up stage for fuel lines, fuel cell, and regulator. I also still need to finish the wiring for the controller. I have actually been under the weather for a while now with the flu, and many family responsibilities so I have not worked on it for almost 3 weeks now.
Tuning will be something completely new to me on a setup like this. I will treat the tune much like a meth injection. I will start out slowly adding the fuel until I can maintain an 80% injector duty cycle on the stock fueling at the boost I am running. I will also remove one of the meth nozzles to drop the use of meth to what it was originally intended for, intake charge cooling and a boost in octane.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 5 Users Say Thank You to SilverDemon For This Useful Post:
BlueStreak (02-22-2013), breakfstincluded (04-16-2013), Celestspeed3 (02-22-2013), jreiden1 (02-22-2013), ms3blackmica (05-15-2013)
 Old 02-22-2013, 03:11 PM   #78
jreiden1's Avatar
what about the setup that killah is running? is it a unicorn setup?
 Old 02-22-2013, 03:25 PM   #79
I don't know what he is running. I have not been following what he is doing. Like I said, as far as I know.
Is his car even running?
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 02-22-2013, 03:31 PM   #80
jreiden1's Avatar
i don't know if it is running... but i saw pictures and they are almost identical to what you have posted up here... but i will do like everyone else and continue to wait lol
thanks for the help and info...
i notice youre in ohio... do you or can you tune?
The Following User Says Thank You to jreiden1 For This Useful Post:
Yllib30 (11-21-2018)
Port Injection for 2012 Realgib3 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 29 12-19-2011 02:11 PM
Direct Port Water Injection ptperformance Mazdaspeed3/6 General Discussion 12 08-13-2009 12:32 PM
Port Injection Question 6-Speed-6 MazdaSpeed 3 - Engine, Transmission & Driveline 9 07-16-2009 07:02 PM
port injection head cbspeed3 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 54 06-28-2009 09:39 AM
Page generated in 0.62743 seconds with 36 queries
