 Old 04-26-2015, 08:50 PM   #1
nswartz19's Avatar
Posts: 117   (View Stats)
nswartz19 is the leader of the worldnswartz19 is the leader of the worldnswartz19 is the leader of the worldnswartz19 is the leader of the worldnswartz19 is the leader of the worldnswartz19 is the leader of the worldnswartz19 is the leader of the worldnswartz19 is the leader of the worldnswartz19 is the leader of the worldnswartz19 is the leader of the worldnswartz19 is the leader of the world
Groaned at 5 Times in 2 Posts
Default PI Fuel Pressure Problem
So i just finished off installing my PI fuel pressure system. I have it set up just like the diagram attached. Fuel pressure is set to 45 psi at idle with a walbro 450 in tank pump.
My issue is that the hpfp is running 1000-1700 at idle and is making a crazy screaming noise. If i drive the car it will calm down a little and drop down to 200-300 psi when i let off the gas. I cleaned off the split valve cuz it sat with E in the tank for 4 months... didnt help.
Any ideas?
BBBBraaapp!
2008 MS3 Metro Grey
Pure Performance Tune // Built Motor // 6262 @ 32psi // 6th Port // AFI T3 Mani // 44mm Tial EWG // Custom RB25 Intake Mani // Custom 4in Intake // Custom DP // HKS SSQV // Grimmspeed EMBC // KMD hpfp // JBR anchors // JBR shortcut // RPF1 17x9 // Megan coilovers // 245/40/18
nswartz19 is offline   Reply With Quote
0 Fuel Pressure/0.0 Volts HPFP Voltage...but I do have fuel pressure?? AFcadet MazdaSpeed 3/6 - Troubleshoot/Diagnostics 25 03-15-2019 07:27 PM
Wierd Fuel Pressure Problem/ Rich at Idle sriser66 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 6 05-17-2014 02:25 PM
Problem after problem: Running rich & Fuel cuts wherewuat 2010 MS3 - Troubleshoot/Diagnostics 30 01-30-2014 01:13 PM
OIL PRESSURE PROBLEM! ms3_518 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 07-06-2009 06:26 PM
Page generated in 0.22630 seconds with 21 queries
