 Old 08-04-2011, 02:36 PM   #1
RMCAT's Avatar
Posts: 170   (View Stats)
RMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond repute
Default Please help! How to rotate the cam for HPFP installation?
I'm doing the KMD internal installation and got stuck trying to put the fuel pump back in the car.I believe the cam follower is extended all the way out but the thing is I can't get it to budge even a bit no matter what I did.I bumped start the car with depressing the clutch and the gas pedal all the way while flipping the key to "start",I pushed the car in gear hoping to turn the cam,the cam "cup" still didn't move a bit to allow me to insert the pump in. I tried to push the cam follower and the cam lobe with my finger and they don't move either. Should I try with a mallet/hammer? Any advices?
||Cobb AP(DJ tuned)||Cobb SRI||Cobb TIP||Cobb FMIC||Cobb SW||KMD v2.2 HPFP||Catted TBE(TurboXS DownPipe+Vibrant DPback)||TurboXS Hybrid BOV||Fortune Auto Coilovers||Powergrid Endlinks||Eibach Camber Kit||CPE RMM||Denso ITV22||STRI DSD 60mm Boost Gauge||5000K HID Fogs||Lamin-x Foglight Tints||Speedy Lite-Fin 18x7.5||General UHP 235/40/18||ADR 17x7(Winter)||Nextmod GV front Lip/spoiler Lip||AutoEXE Carbon Fiber Shifter Knob||Carbon Fiber Ebrake Cover||TWM Bushings||TWM Shift/Ebrake Boots||
RMCAT is offline   Reply With Quote
 Old 08-04-2011, 07:36 PM   #2
RMCAT's Avatar
Finally got it in,I ended up using a screwdriver and tapping the cam follower all the way back in,then spent a good twenty minutes aligning and reconnecting the fuel line,what a pita...
The Following User Says Thank You to RMCAT For This Useful Post:
Chimmike (08-05-2011)
 Old 08-04-2011, 07:37 PM   #3
you dont need to have the cam lobe at the lowest point, u can just push on the FP and the spring will compress.
Blackspeed (08-05-2011)
 Old 08-04-2011, 07:39 PM   #4
m4tic's Avatar
Posts: 4,928   (View Stats)
but its easier not having to go full retard trying to hold the pump to the mating surface so you can get a bolt started
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
The Following User Says Thank You to m4tic For This Useful Post:
Tokay444 (12-18-2011)
 Old 08-04-2011, 08:35 PM   #5
[MSF STIG]
FORZDA 1's Avatar
Posts: 1,206   (View Stats)
FORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the world
Well, you better hope you didn't fuck up the cam follower or the camshaft and the HPFP will be junk before too long. That cam follower is free to move and rotate within the bore, so if it required "tapping" with a tool to get it "back in", then it was cocked in the bore or there was dirt/crap causing it to bind in the bore.
Maybe you'll be lucky. Are you feeling lucky punk? Well, are ya? LOL
`07 Speed6 Sport Tit Gray Sleeper Express... SOLD
`11 Ducati 1198SP SBK Duc Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R gear w/FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq The BIG DOG
`12 Ducati 1100SP EVO Hyper Duc CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R gear w/FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq The Hooligan
`12 Aprilia RSV4 "Factory" SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq The Land Rocket
`17 Ford Focus RS Nitrous Blue w/Cobb V3/AT; OZ Ultraleggera; Schroth harness The Super Fun Toy
FORZDA 1 is offline   Reply With Quote
The Following 3 Users Say Thank You to FORZDA 1 For This Useful Post:
Chimmike (08-05-2011), Mizzle (12-18-2011), trf5000 (08-05-2011)
 Old 08-04-2011, 08:39 PM   #6
Two nuns and a pack mule
AtTheDriveIn's Avatar
Posts: 1,527   (View Stats)
AtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the world
Love that movie....
After learning how to do the internals, I helped a few other do theirs. I remembered to always check the cam follower, but never did I have to turn it to get the pump back in. Those things are supposed to be in pristine and holy condition. I hope you didn't mess it up. Good luck!
AtTheDriveIn is offline   Reply With Quote
The Following User Says Thank You to AtTheDriveIn For This Useful Post:
FORZDA 1 (08-04-2011)
 Old 08-04-2011, 09:42 PM   #7
RMCAT's Avatar
Damn,really hope I didn't fuck it up.I primed the pump and idle for 10 mins,FP dropped from around 800ish and stablized at 500ish psi,haven't had a chance to drive it cuz I was too tired to install the new TIP,gonna see how it goes tomorrow.
Normally how long it takes to know if there's a problem with the hpfp/cam?
 Old 08-05-2011, 05:27 AM   #8
[MSF STIG]
FORZDA 1's Avatar
......Normally how long it takes to know if there's a problem with the hpfp/cam?
It will definitely vary depending on the problem. In your case, if the HPFP itself is ok from the start then the cam follower/cam lobe MAY be ok and you never have any related issues. If the follower/bore are dinged/scuffed on the sides, it will just leave metal in the oil as they wear away, but if the contact surface is damaged, the cam/follower will go to shit in fairly short time. I would guess around 1k miles or so.
Moral of the story is to be careful when you're doing mods on the car and if you need to HIT something for it to fit, then STOP and find out what's wrong!
The Following User Says Thank You to FORZDA 1 For This Useful Post:
SLOWHATCH (08-09-2011)
 Old 08-05-2011, 06:24 AM   #9
RMCAT's Avatar
How much damage it's gonna cause if the cam/follower goes to shit? Will I need to change the cam/HPFP or even more?
What I did was I wrapped the head of the screwdriver with a clean folded latex glove to avoid metal to metal contact,then I gently tapped the end of the screwdriver with a wrench,I moved the screwdriver around and it felt like I got the right angle after 3 or 4 taps when the screwdriver reached one part of the cam follower it sucked right in and I could push it all the way back with very little effort,I then cleaned the cam follower with non chlorinated brake cleaner spray and lubed with fresh motor oil just like what I did to the fuel pump...The cam follower really felt like stuck cuz it wouldn't budge a bit at the most extended position no matter what I did,was kinda desperate at that time until I saw this solution posted by other few members...
Keeping my fingers crossed...
 Old 08-05-2011, 06:39 AM   #10
the_rolex_guy's Avatar
Posts: 59   (View Stats)
the_rolex_guy has a brilliant futurethe_rolex_guy has a brilliant futurethe_rolex_guy has a brilliant futurethe_rolex_guy has a brilliant futurethe_rolex_guy has a brilliant futurethe_rolex_guy has a brilliant futurethe_rolex_guy has a brilliant futurethe_rolex_guy has a brilliant futurethe_rolex_guy has a brilliant futurethe_rolex_guy has a brilliant futurethe_rolex_guy has a brilliant future
Groaned at 8 Times in 1 Post
Just drive the car and see what happens.
the_rolex_guy is offline   Reply With Quote
 Old 08-05-2011, 08:36 AM   #11
[MSF STIG]
FORZDA 1's Avatar
Yeah, sounds like what happened is you had the cam follower slightly cocked in the bore and when you tapped it around it squared up and went in. Based on your last description I'm thinking you will be fine. As said above, just drive it and don't worry about it.
 Old 08-05-2011, 08:45 AM   #12
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Next time, you could try bump cranking the car a couple times to move it instead of tapping with a screwdriver, lol.
07 MS3
The original Genpoo Hater
 Old 08-09-2011, 01:47 AM   #13
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
@AtTheDriveIn
Hmmm that Nator VA banner looks vaguely familiar....
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 08-09-2011, 01:51 AM   #14
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
danger to manifold
The Following User Says Thank You to dooderek For This Useful Post:
Chimmike (08-09-2011)
 Old 08-09-2011, 06:18 AM   #15
RMCAT's Avatar
Not only did I bump the crank and also I pushed the car in gear hoping to rotate the cam,if I wasn't running out of options I wouldn't using the screwdriver method...
 Old 12-18-2011, 07:48 PM   #16
Grab21's Avatar
Posts: 58   (View Stats)
Grab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud of
Any other suggestions on how to better rotate crank? Any do it yourselves?
2006 speed6 ... bnr s4 soon- on order... when danger to manifold explodes... 8 port
335i day driver
LSA supercharged Caddy CTS-V stealth gray-sold
Porsche Panamera turbo- sold
Bmw m3-sold
Z4m- sold
Grab21 is offline   Reply With Quote
forge bpv supposed to rotate at the base? Lytheum Mazdaspeed3/6 General Discussion 5 07-14-2011 06:10 PM
Installation of new set up 2gr84u MazdaSpeed 3/6 - Car Audio & Electronics 1 06-09-2011 06:26 PM
RMM Installation lerly1 MazdaSpeed 3 - Engine, Transmission & Driveline 1 11-24-2010 07:52 PM
CPE HPFP installation Trader MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 10 10-22-2009 01:00 PM
Hid Installation help AmillieMS6 MazdaSpeed 3/6 - Car Audio & Electronics 7 04-05-2009 10:05 PM
Page generated in 0.35963 seconds with 29 queries
