Like Tree2Likes
 Old 12-06-2011, 09:12 AM   #41
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
I was seriously considering going with an M1 with 100% meth at the inlet of my K04, but then it died and there is no need for it with the new turbo.
It can work and essentially has the effect of expanding the compressor's efficiency island farther to the right by dropping the temp in the inlet/volute.
You just have to make damn sure that you are only sending atomized mist into the compressor and not a running stream. Nozzle placement is critical.
So would you tap for the nozzle in the TIP as close to the turbo as possible then?
The Following User Says Thank You to wolly6973 For This Useful Post:
rfinkle2 (12-06-2011)
 Old 12-06-2011, 03:32 PM   #42
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Ideal placement would be like this (zero locations for mist to puddle/collect into drips):
But if not like that, then as close as possible (like in the coupler connecting to the compressor housing) such that there are no likely puddle points to create a running stream of drips into the compressor. If installed in that coupler, then the only thing you have to consider is the lip of the compressor housing inside the coupler and try to place/orient the nozzle to minimize the chance of the mist hitting this circumference.
You really have to think this through else you can erode the compressor wheel significantly in a matter of 10's of pulls.
The Following 4 Users Say Thank You to cld12pk2go For This Useful Post:
GLORIFIEDBOZO (12-14-2011), Mizzle (12-10-2011), rfinkle2 (12-06-2011), wolly6973 (12-06-2011)
 Old 12-06-2011, 03:54 PM   #43
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
on the 335i forums ive seen meth nozzles drilled DIRECTLY into the comrpessor housing but i believe it was off of a super car or something. some crazy shit those guys do
The Following 2 Users Say Thank You to dooderek For This Useful Post:
cld12pk2go (12-08-2011), rfinkle2 (12-07-2011)
 Old 12-07-2011, 12:35 PM   #44
JumpingJackson's Avatar
Posts: 967   (View Stats)
JumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the worldJumpingJackson is the leader of the world
You can also buy a circular fixture that will slip onto your compressor housing that has a place right in the middle for you to mount your nozzle. I forget who makes em though
2006 Titanium Gray MS6 Mods:
DCR - Built Longblock with Pauter Rods , Wiseco 8.9:1 Pistons, Stiffer Valvesprings, P&P Head Upgraded VVT Actuator
Cobb AccessPort + 3 Bar Map Sensor
CP-E TIP , RMM
Aquamist HFS-4 WMI Injection System
Bullseye - T3 .55AR S259 Turbo
Synapse - BOV
Custom - Ceramic Coated T3 Exhaust Manifold , 3" T3 Downpipe, 3"-2.5" Dual Catback Exhaust, 3" MAF SRI, FMIC
PT-P CDFP + Walbro 255 Intank Pump + Fuelabs Adj. FPR + -6 AN Feed/Return
Turbine Tech / Street Unit - Front & Rear Diff Mount
eDesign Audio - NINe.2x 760W AMP , 2x 11Kv.2 10" Subwoofers
JumpingJackson is offline   Reply With Quote
The Following 2 Users Say Thank You to JumpingJackson For This Useful Post:
rfinkle2 (12-07-2011), wolly6973 (12-07-2011)
 Old 12-08-2011, 07:24 PM   #45
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
I want to pre-turbo nitrous my speed...
403whp/451ft/lb Dry Shot
The Following User Says Thank You to Bucker For This Useful Post:
Chimmike (12-14-2011)
 Old 12-08-2011, 07:31 PM   #46
2zz mr-s
dooderek's Avatar
Groans: 239
The Following User Says Thank You to dooderek For This Useful Post:
 Old 12-10-2011, 06:49 AM   #47
Eth/Meth Junkie
cld12pk2go's Avatar
That looks like a sweet setup for a drag car that is limited on compressor size by rule.
That would greatly help to cram more out of a limited sized compressor, but that is obviously "a bit" overkill for a DD.
wolly6973 (12-10-2011)
 Old 12-11-2011, 04:20 PM   #48
Eth Fiend
phate's Avatar
Posts: 6,945   (View Stats)
Somebody just picked up a K04 for mock up
-06 MS6
-Corn fed 07 MS3 - Sold
Bucker (12-11-2011), cld12pk2go (12-11-2011), GLORIFIEDBOZO (12-14-2011), mazdafreak (12-11-2011), rfinkle2 (12-11-2011), wolly6973 (12-15-2011)
 Old 12-11-2011, 04:54 PM   #49
Eth/Meth Junkie
cld12pk2go's Avatar
I am betting that an M1 can help squeeze another 20 HP from a K04...
Bucker (12-11-2011), phate (12-11-2011), rfinkle2 (12-11-2011), wolly6973 (12-15-2011)
 Old 12-11-2011, 05:10 PM   #50
Eth Fiend
phate's Avatar
Thankfully, we have Virtual Dyno to find these things out.
-06 MS6
 Old 12-11-2011, 05:47 PM   #51
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Lemme guess... Glrorified Bozo's car? LOL
 Old 12-11-2011, 06:02 PM   #52
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
Thanks to me
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
 Old 12-12-2011, 11:00 PM   #53
2zz mr-s
dooderek's Avatar
Groans: 239
 Old 12-12-2011, 11:17 PM   #54
Dust's Avatar
Posts: 192   (View Stats)
Dust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the world
Derigo, unless you have the nozzle right at the center nut, there will not be much advantage. Most companies suggest mounting perpendicular to the airflow.
Dust is offline   Reply With Quote
 Old 12-14-2011, 02:08 PM   #55
DevilsOwn's Avatar
Posts: 212   (View Stats)
DevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the worldDevilsOwn is the leader of the world
pointing it at the center nut is honesty not necessary IMO. Even if you get coverage on 1/4 of the diameter of the turbo once it goes threw is going to whrill around.
DevilsOwn is offline   Reply With Quote
The Following 3 Users Say Thank You to DevilsOwn For This Useful Post:
Chimmike (12-14-2011), cld12pk2go (12-15-2011), wolly6973 (12-15-2011)
 Old 12-14-2011, 02:21 PM   #56
Eth Fiend
phate's Avatar
I had a good long convo with the nice people at Devils Own this morning, and they made me rethink doing this. I'm going to do some more research before I invest the time and money into this project. So, my current project will wait until at least next week until I talk to some more folks in the industry.
My perspective right now is this: I don't need octane. I don't need decreased BAT's. I ONLY want this for an increase in airflow. How much airflow will we really gain from a .075 or 1.0 DO nozzle, injecting before the compressor? I've seen a little info regarding this, but nothing substantial.
I feel like I have a great situation to test this on, since my timing and boost are essentially maxed for a K04. I just need a little more solid evidence before I invest.
-06 MS6
Easter Bunny (12-14-2011), GLORIFIEDBOZO (12-14-2011), wolly6973 (12-15-2011)
 Old 12-14-2011, 02:27 PM   #57
2zz mr-s
dooderek's Avatar
Groans: 239
racecars do it
 Old 12-14-2011, 02:30 PM   #58
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Frankly I'd rather do meth injection after the intercooler or before it along with before the throttle body.
07 MS3
The original Genpoo Hater
 Old 12-14-2011, 02:40 PM   #59
I'm personally going to invest in a little porting myself.
 Old 12-14-2011, 02:47 PM   #60
Eth Fiend
phate's Avatar
Originally Posted by Derigo View Post
racecars do it
Yes, I know. But, like I was discussing with Devils Own, are the claimed results because they turned up boost, or because they could add some timing? Very little information is out there about increased airflow due to evaporating meth before the compressor. In theory, it should work fine. BUT, how much gain are we actually going to see?
That defeats the purpose of what this thread is really about. There is no potential for increased airflow with the typical set up. It just allows you to run more boost or more timing. Like I said, we aren't looking for either, we're looking to make the K04 act like a slightly bigger turbo.
-06 MS6
 Old 12-14-2011, 02:49 PM   #61
2zz mr-s
dooderek's Avatar
Groans: 239
well theres only one way to find out!
 Old 12-14-2011, 02:53 PM   #62
Eth Fiend
phate's Avatar
Agreed. But I'm really cheap.
-06 MS6
 Old 12-14-2011, 02:55 PM   #63
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
subbed
 Old 12-14-2011, 03:03 PM   #64
2zz mr-s
dooderek's Avatar
Groans: 239
maybe i can convince one of the sd nator nubs to get meth
phate (12-14-2011)
 Old 12-14-2011, 07:05 PM   #65
Bucker's Avatar
Groans: 451
nitrous.
 Old 12-15-2011, 12:04 AM   #66
GLORIFIEDBOZO's Avatar
Posts: 1,928   (View Stats)
Lol, what you think my car should be test for more turbo abuse?
Actually I'm quite interested in this, and it may become a possibility, let me get some miles on my current extreme's and see how things hold up.
The Following 2 Users Say Thank You to GLORIFIEDBOZO For This Useful Post:
mazdafreak (12-15-2011), rfinkle2 (12-15-2011)
 Old 12-15-2011, 05:40 AM   #67
Eth/Meth Junkie
cld12pk2go's Avatar
The effect is just like running winter vs. summer. In 20°F ambient I could easily hit 300 g/s on the K04, but in summer mid 260's is all it could do. The difference is the incoming air density.
The K04 compressor map we use states is it rated for 298K (~77°F). It can flow more than the map below that temp and less above.
What the meth will do is allow a little more in winter, but considerably more airflow in summer.
I would expect to be able to hit closer to the 300 g/s range year around with meth injection prior to the turbo.
The Following 6 Users Say Thank You to cld12pk2go For This Useful Post:
BigjohnB20 (12-15-2011), GLORIFIEDBOZO (12-15-2011), manselainen (12-19-2011), mazdafreak (12-15-2011), rfinkle2 (12-15-2011), wolly6973 (12-15-2011)
 Old 12-15-2011, 10:45 AM   #68
2zz mr-s
dooderek's Avatar
Groans: 239
but the real question here is
will it blend?
PTP Water Injection Check it Out!! PAM.srt4 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 18 12-08-2009 05:54 PM
Water Injection - Take it from the top? Speedie6 Mazdaspeed3/6 General Discussion 13 12-31-2008 01:20 PM
Water-Meth injection EvilMonkey MazdaSpeed 3 - Engine, Transmission & Driveline 2 08-06-2008 10:41 AM
Page generated in 0.48084 seconds with 34 queries
