 Old 09-20-2017, 12:52 PM   #1
qtrmile beast's Avatar
Posts: 2,417   (View Stats)
Default PTP hprv
Im sorry have looked all over and i cant find where to purchase a PTP HPRV.... is this still available or do i have to stick with the stock HPRV?
track weight 3220
street weight 3370
 Old 09-20-2017, 01:01 PM   #2
Code Monkey's Avatar
Posts: 7,666   (View Stats)
Here.
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
 Old 09-20-2017, 01:56 PM   #3
Thor Hammer's Avatar
Posts: 1,839   (View Stats)
Groans: 210
That's a damned expensive valve! Is there truly a benefit?
 Old 09-20-2017, 07:09 PM   #4
Varomnia's Avatar
Posts: 451   (View Stats)
Varomnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the world
If you believe that, I have a bridge to sell you.
Varomnia is offline   Reply With Quote
The Following User Says Thank You to Varomnia For This Useful Post:
KiwiFlavor (09-21-2017)
 Old 09-20-2017, 07:36 PM   #5
aaronc7's Avatar
Posts: 8,054   (View Stats)
Groans: 370
lol
About | DamnFastDD.com
 Old 09-20-2017, 08:08 PM   #6
SSinstaller's Avatar
Posts: 3,943   (View Stats)
Groans: 55
I tested two of those valves years ago. Both held pressure much better than the oem valve. But, both also caused fuel cut every time i tried to hold WOT to redline. The ms6 ecm is not happy if you hit 2074psi ever...
Soon to be installed:
The Following 3 Users Say Thank You to SSinstaller For This Useful Post:
MazdaspeedKills (09-21-2017), qtrmile beast (09-21-2017), Thor Hammer (09-21-2017)
 Old 09-21-2017, 06:23 AM   #7
Is this site valid still? Mazda DISI High Pressure Rail Relief Valve | HPFPUpgrade.com
I know it says out of stock but they may still be able to get one..
Also is this a required mod for high hp cars? Or is this a mod just to eeeek out a few extra ponies from the stock injectors.. Also any one have the part number for the dealership?
track weight 3220
street weight 3370
 Old 09-21-2017, 06:37 AM   #8
Varomnia's Avatar
They're banned for a reason.
L3K9-13-2J0 is the pressure relief valve.
It's not a mod. It's a wear item that should be replaced with oem every time.
 Old 09-21-2017, 06:44 AM   #9
mituc's Avatar
Posts: 3,517   (View Stats)
Groans: 111
No. High HP cars usually have various types of port injection (single port with 5th/6th port, single port with 1-2 nozzles of WMI, or multiport with individual port injectors for each cylinder and even one more meth injector).
So the gain from the extra pressure, like 1800PSI versus 2000-ish PSI is not that big, even though it can account for 8-10% of fuel headroom. I'd go some flavour of PI though.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
qtrmile beast (09-22-2017)
 Old 09-21-2017, 08:29 AM   #10
MazdaspeedKills's Avatar
Posts: 443   (View Stats)
MazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the world
Groaned at 7 Times in 4 Posts
Same thing happened to me. I uninstalled it and put in my worthless crap collection.
'06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs
MazdaspeedKills is offline   Reply With Quote
The Following 2 Users Say Thank You to MazdaspeedKills For This Useful Post:
qtrmile beast (09-22-2017), Thor Hammer (09-21-2017)
 Old 09-21-2017, 09:04 AM   #11
Groans: 210
I don't believe it. That's why I asked. So you can hold on to your bridge.
The Following 2 Users Say Thank You to Thor Hammer For This Useful Post:
qtrmile beast (09-22-2017), Varomnia (09-21-2017)
 Old 09-22-2017, 04:16 AM   #12
Ok great info fellas..... I have a fully built car I just got back on the road after about 5 years... I have never had a problem with relief valves so this is my first rodeo!!! I appreciate everyone feedback... last question is where is the cheapest someone has found this valve...
I was told byou one dealership that it was only serviceable with the rail... and they wanted over 600 for it
track weight 3220
street weight 3370
 Old 09-22-2017, 06:04 AM   #13
Varomnia's Avatar
You can do it. Takes about 30 minutes for a noon to replace with little swear words. Costs $120 for a new valve. I've always ordered from edgeautosport.
 Old 09-22-2017, 06:53 AM   #14
You are talking about the fuel pressure sensor, which has to be purchased with the fuel rail. The relief valve can be purchased separately, as @Varomnia; said.
2006 Mazdaspeed6
2017 Subaru BRZ
 Old 09-23-2017, 04:21 AM   #15
We'll went to the stealership and pointed the part out that's what I was told..... well if it could be ordered from the dealer... anyone have a part number... as far as edge goes I will give them a call Monday....
track weight 3220
street weight 3370
 Old 09-23-2017, 05:05 AM   #16
Varomnia's Avatar
Did I not already give you the part number?
qtrmile beast (09-26-2017)
PTP HPRV Review >>> Alpha MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 125 01-24-2014 07:31 PM
HPRV luv2gorealfast MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 4 03-01-2013 11:45 AM
Page generated in 0.36637 seconds with 27 queries
