 Old 03-03-2016, 10:28 PM   #1
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
specvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the world
Groaned at 54 Times in 27 Posts
Default Quick Fuel Filler
So I was always spilling when transferring fluid and fill up would be too slow and cumbersome.. I knew I had to look for a better way... did my shopping and research and found a great combo... if you have a trunk mount tank or feel like your setup will work with it, I wouldn't hesitate getting it.. at worse you'll just have to buy filler hose as an extension to make it work...
been running this for a bit now; just so proud of it.. I had to share lol
Setup: Tuff Jug 2.7g with Ripper Cap and adapter.
In action:
*COBB: AP, shifter weight *BITWISE: Harness, 3bar BNR: S3v2 *CP-e: Stage 2 RMM ,TMIC *JBR: RSB, EGR delete, WP *GRIMMSPEED: EBCS *TWM: Full Shifter *KDM: HPFP internals *DENSO:ITV22 *FORD: syn trans fluid *OBX: TBE *BILSTEIN: B8 Sport *SWIFT: Spec-R springs *GTSPEC: 4point ladder brace, rear subframe brace *NITTO: NT-05 * Whiteline: BSK *MOOG: F/R endlinks* SPC: Adj. camber arms *MORIMOTO: 5K HID elite
specvspeedfreak is offline   Reply With Quote
The Following User Says Thank You to specvspeedfreak For This Useful Post:
WetzMS3 (03-04-2016)
Fuel Filler Pipe Removal MS3Newb MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 02-16-2015 03:06 PM
fuel filler pipe manufacturer here.n.there MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 7 04-09-2012 04:51 PM
Look in your fuel filler pipe... MoparGo Mazdaspeed3/6 General Discussion 7 11-10-2011 12:56 AM
Page generated in 0.22899 seconds with 20 queries
