  • 1 Post By Erich
 Old 10-08-2011, 10:44 PM   #1
andre0121's Avatar
Posts: 347   (View Stats)
andre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond repute
Default Relief valve is done for
So my high pressure relief valve is done for. I was checking out PTPs but they have valves for different pressures. Anyone running this and if so what pressure size? i would assume the 2250psi one? thanks
andre0121 is offline   Reply With Quote
 Old 10-08-2011, 11:33 PM   #2
Snyeed's Avatar
Posts: 743   (View Stats)
Snyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the world
Groaned at 8 Times in 4 Posts
They offer ones for different pressure now? I am running the 2250psi valve with no problems.
417whp 428tq 12.037@117.2mph
Snyeed is offline   Reply With Quote
 Old 10-09-2011, 12:21 AM   #3
708
Erich's Avatar
Posts: 4,274   (View Stats)
I tested these valves and ran a 2050, 2250 and now a 2150. Until Cobb gets the fuel pressure stuff ironed out the 2150 is sufficient. If you want to future proof get the 2250. Just make sure not to target above 2070 (really 2050) PSI in ATR.
Erich is offline   Reply With Quote
The Following 5 Users Say Thank You to Erich For This Useful Post:
Alpha (02-16-2012), andre0121 (10-09-2011), kmac (10-12-2011), rfinkle2 (10-12-2011), SLOWHATCH (10-09-2011)
 Old 10-12-2011, 09:06 AM   #4
RWDAddict's Avatar
Posts: 340   (View Stats)
RWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the world
What is the point of a pressure relief valve? Is the factory return line not sufficient?
06 MazdaSpeed6 GT w/Nav. Mods so far: Cobb SRI, RMM, HPFP, ATP 3" catted DP, ETS CBE, Synchronic BOV, AP, CP-E TMIC, SURE TIP, HKS Twin Power, Poly trans mount, PTP fuel injector seals, PCV Fix
RWDAddict is offline   Reply With Quote
 Old 10-12-2011, 11:13 AM   #5
kmac's Avatar
Posts: 1,792   (View Stats)
I'm running the 2150 and my pressure is crazy stable.
 Old 10-12-2011, 11:16 AM   #6
how do u know yours went bad?
 Old 10-12-2011, 02:22 PM   #7
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
@CCC
Anyone have a relief valve from the fuel rail? AFcadet MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 3 08-17-2011 03:51 AM
Dissected Relief Valve SilverDemon MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 39 12-27-2010 12:33 PM
Page generated in 0.28760 seconds with 26 queries
