 Old 02-28-2016, 08:32 AM   #1
GEE1989's Avatar
Posts: 182   (View Stats)
GEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant future
Default Running meth line under car
When running a meth line under car, how close can you get to the exhaust? I'm not finished but I ran it with the fuel lines and then I crossed the exhaust with wire loom wrapped in heat reflectant tape good to 2000 degrees. Im just trying to be completely safe with this.
Sent from my SM-G920P using Tapatalk
Still need to finish tieing it up but I wanted to get some advice before
08 MS3
Corksport turbo, built motor, meth injection, and FREEKTUNED
Last edited by GEE1989; 02-28-2016 at 08:32 AM. Reason: MSF Database - Automerged Doublepost
GEE1989 is offline   Reply With Quote
 Old 02-28-2016, 12:23 PM   #2
GEE1989's Avatar
Nvm people. I pulled all the fuel line heat sheild and just routed it completely with the fuel lines. Better safe than sorry
08 MS3
 Old 02-28-2016, 07:16 PM   #3
sheston's Avatar
Posts: 1,847   (View Stats)
Looking at the scrapes on your brace, I'm glad you moved them :-)
 Old 02-28-2016, 07:51 PM   #4
GEE1989's Avatar
I'm pretty sure those scrapes are from me when I put the exhaust on. Im pretty sure once I took that brace off I just slid it out on the concrete. I don't know for certain though but I would assume I would of felt that lol
08 MS3
 Old 03-05-2016, 11:29 AM   #5
Cmfk's Avatar
Posts: 20   (View Stats)
Cmfk will become famous soon enough
Is there a write up on how to install a methonal kit I can't seem to find one?
Sent from my SM-G920T using Tapatalk
Cmfk is offline   Reply With Quote
 Old 03-05-2016, 12:17 PM   #6
GEE1989's Avatar
Its pretty straight forward. You just gotta do some drilling if you want to mount it in the trunk. Run wires under door jam. The others run through the hole in the firewall for your hood pop cord. All the wires are more intimidating than it actually is
08 MS3
 Old 03-06-2016, 06:44 AM   #7
Cmfk's Avatar
I hope so haha I just ordered a snow performance kit
 Old 03-06-2016, 08:23 AM   #8
blackms3_71's Avatar
Posts: 2,250   (View Stats)
blackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the world
For under the car routing i would use s.s lines
COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned
blackms3_71 is offline   Reply With Quote
 Old 03-07-2016, 04:26 PM   #9
GEE1989's Avatar
Yea Im gonna do that eventually. I wasn't too happy with how that looked so I ended up putting wire loom around the whole meth line and then wrapped it in heat reflectant tape for the time being.
08 MS3
running meth cgancarz MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 7 08-26-2013 06:01 AM
What Meth/Alcohol systems are you running? TheNewGuy Mazdaspeed3/6 General Discussion 8 04-02-2011 09:13 PM
Page generated in 0.28501 seconds with 24 queries
