  • 1 Post By m4tic
 Old 05-29-2012, 07:43 PM   #1
CowboyMS3's Avatar
Posts: 51   (View Stats)
CowboyMS3 has a reputation beyond reputeCowboyMS3 has a reputation beyond reputeCowboyMS3 has a reputation beyond reputeCowboyMS3 has a reputation beyond reputeCowboyMS3 has a reputation beyond reputeCowboyMS3 has a reputation beyond reputeCowboyMS3 has a reputation beyond reputeCowboyMS3 has a reputation beyond reputeCowboyMS3 has a reputation beyond reputeCowboyMS3 has a reputation beyond reputeCowboyMS3 has a reputation beyond repute
Default Should I be worried
I installed my Autotech internals this weekend. When I was driving home after work noticed the FP dropped to 60-40. When I started to drive it returned to normal after about 1500-2000 RPM. Should I re cal my MAF to see if this fixes the problem. Thanks for your help
Boom Slide Side
CowboyMS3 is offline   Reply With Quote
 Old 05-29-2012, 07:53 PM   #2
Dmurray06's Avatar
Posts: 3,279   (View Stats)
Groans: 189
Groaned at 64 Times in 21 Posts
60-40...ummmmm....as in 60 psi?! I wouldnt be driving.
And MAF cal won't change fuel pressure.
2010 Mazdaspeed 3 Black Mica w/ Tech Package - Traded In
2014 Ford F150 FX4 Ecoboost - Current
Last edited by Dmurray06; 05-29-2012 at 07:53 PM. Reason: MSF Database - Automerged Doublepost
Dmurray06 is offline   Reply With Quote
The Following User Says Thank You to Dmurray06 For This Useful Post:
CowboyMS3 (05-31-2012)
 Old 05-29-2012, 07:57 PM   #3
m4tic's Avatar
Posts: 4,922   (View Stats)
Impossible, Autotechs are hand made by god.
skeeter149 likes this.
2007 MS6 w/ Cheez
The Following 7 Users Say Thank You to m4tic For This Useful Post:
CowboyMS3 (05-31-2012), Eighty8 (05-30-2012), fooqr (05-30-2012), helmetface (05-30-2012), jack_hammer (05-29-2012), skeeter149 (05-29-2012), smoogs12 (05-30-2012)
 Old 05-29-2012, 07:57 PM   #4
sassyspeed3's Avatar
Posts: 1,054   (View Stats)
sassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the world
What happened to you coming over to do those? Lol. We had almost all of NATOR CO at my house this past Saturday!
sent from my cleavage via Tapatalk
2013 Mitsubishi Lancer Evolution GSR
2008 Red MS3
BT & All
Eth Mix - 460hp/429tq
Pump - 411hp/403tq
**SOLD**
[02:58 PM] dturboman: and ZZB will happen one day, its just how long you can avoid it for
[09:15 PM] Erich: if you aren't notching your block, your turbo isn't big enough
sassyspeed3 is offline   Reply With Quote
The Following 2 Users Say Thank You to sassyspeed3 For This Useful Post:
CowboyMS3 (05-31-2012), J'sSpeed3 (05-29-2012)
 Old 05-29-2012, 08:06 PM   #5
Stealth01's Avatar
Posts: 6,910   (View Stats)
Stealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the world
Groans: 201
Groaned at 164 Times in 103 Posts
60-40? Ouch. Be careful...
Stealth01
2006 Mazdaspeed6 GT
Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose
SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG
Read my stories: https://www.smashwords.com/books/view/55318
Stealth01 is offline   Reply With Quote
The Following User Says Thank You to Stealth01 For This Useful Post:
 Old 05-29-2012, 08:08 PM   #6
CowboyMS3's Avatar
Went home this weekend and did it there. On the drive home the FP held strong above 1600 all the way home about 400 miles and on the way home from work today is when I noticed the drop. it only does it when it idle not driving.
Boom Slide Side
 Old 05-29-2012, 08:09 PM   #7
J'sSpeed3's Avatar
Posts: 722   (View Stats)
J'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the world
Groans: 76
Like Sassy said! We coulda had another speed out there doing internals along with @slikr
| 2007 True Red Mazdaspeed 3 GT |
GO: | SURE SRI V2 | COBB TIP | CP-E FMIC | Corksport DP | Corksport CBE | Cobb AP RICHTUNED | Autotech Internals | SURE RMM | Denso ITV-22's | Turbosmart BPV |
SHOW: | Evo X Enkei's 18x8.5 +38 Painted CWP| Nitto Motivo's 225/40 | BC Racing Coilovers | SPC Camber Arms | DDM 3000k fogs | CPE Tow Plate |
J'sSpeed3 is offline   Reply With Quote
The Following User Says Thank You to J'sSpeed3 For This Useful Post:
 Old 05-29-2012, 08:15 PM   #8
CowboyMS3's Avatar
I'm always down to uninstall and reinstall to see if I missed a step since you all have done this many times before
Boom Slide Side
The Following User Says Thank You to CowboyMS3 For This Useful Post:
J'sSpeed3 (05-30-2012)
 Old 05-29-2012, 08:33 PM   #9
Dmurray06's Avatar
Groans: 189
Idle should be ~430 psi once warm.
 Old 05-29-2012, 08:37 PM   #10
jack_hammer's Avatar
Posts: 6,821   (View Stats)
Groans: 549
Yes. Yes you should be worried.
Sent from my LG-MS690 using Tapatalk 2
it's fun to do bad things
The Following User Says Thank You to jack_hammer For This Useful Post:
 Old 05-29-2012, 08:41 PM   #11
event's Avatar
Posts: 521   (View Stats)
event is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the world
did you install them backwards (it's easy to do this)? Did you torque down the internals? Did you forget the locking pieces in the collar?
***sold*** 06 MS6 Cobb SRI 3.5" ETS TMIC Cobb AP Sure RMM JBR SSP EBay Catless DP Autotech HPFP Magnaflow
2013 Scion FR-S 6MT
1993 Mazda Miata with shocks, springs, fsb, GT2560r, Megasquirt
event is offline   Reply With Quote
The Following User Says Thank You to event For This Useful Post:
 Old 05-30-2012, 04:40 AM   #12
CowboyMS3's Avatar
I could have intalled them backwards. I did torque them down and the locks are there. looks like a late night for me to see if I put them in backwards.
Boom Slide Side
 Old 05-30-2012, 06:41 AM   #13
Srsly though, if you need help, I'm sure either @slikr or @DISIindahead can stop by. Just let us know.
2008 Red MS3
BT & All
Pump - 411hp/403tq
**SOLD**
The Following User Says Thank You to sassyspeed3 For This Useful Post:
 Old 05-30-2012, 06:44 AM   #14
Ferg's Avatar
Posts: 1,498   (View Stats)
Ferg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the world
i @sassyspeed3.... why was i not invited?
2008 Silver Mazda 6s (AEM cai and jdm cbe) sold feb 2011
2008 Black Ms3 SOLD
Vibrant CBE/custom straight test pipe/SURE AEROS SRI/short shifter/jbr chrome molly 88 duro dogbone rmm/rally armor mudflaps/MOTORCRAFT trans fluid/EBC Redstuff front pads/JBR short shift weight/JBR adjustable short shift plate @30%/autotech internals/MD OCC/ Prosport Evo Boost gauge with Vent Pod/NGK one step colder plugs
AP Dizzy Tuned by BUCKER
CorkSport Interior LED Kit
2015 STi Limited in Lightning Red
Stock bottom end died at 18K hard canyon miles.
Current Mods after build
Forged High Performance CP Pistons, CP Rings, King Race Bearings, Manley H Beam Rods, 20g Turbo with 8cm Hotside, Cobb Performance Fuel Regulator, DW300c Intake pump, 1000cc Injectors, Cobb intake, Nameless 3" divorced catless DP, 3" MagnaFlow catback, Grimmspeed EBCS, SPT lower shift bushings, SPT short shifter, Diode Dynamics Boomerang kit, AP v3 Tuned by Justin@FreekTune
[11:46 AM] wdawson4: now here is where i get expensive it takes atleast 250,000 to pound my butthole i cant sell that for cheap
Ferg is offline   Reply With Quote
The Following User Says Thank You to Ferg For This Useful Post:
 Old 05-30-2012, 06:49 AM   #15
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
60psi is the pressure from the ITFP, so I would be worried.
I suggest you take them out ASAP and check that you installed them correctly. You could have installed the lower retainer backwards.
You might also want to check your oil as there might be plenty of fuel mixed in there.
The Following User Says Thank You to adlpb For This Useful Post:
 Old 05-30-2012, 07:14 AM   #16
Stangcobra's Avatar
Posts: 584   (View Stats)
Groans: 51
Take everything apart, check internals, its the only way youll know if youre going to zzb or not
I am a huge faggot
The Following User Says Thank You to Stangcobra For This Useful Post:
The Following User Says NO Thank You to Stangcobra For This Un-useful Post:
mazdafreak (05-30-2012)
 Old 05-30-2012, 07:58 AM   #17
CowboyMS3's Avatar
ok thanks I will call when im on the way home tonight Im going to leave early.
Boom Slide Side
 Old 05-30-2012, 07:03 PM   #18
Alright, so we installed these twice and it's still reading between 56 and 61 at idle. We are thinking its a bad batch.
@JP@edgeautosport.com
@eric@edgeautosport
Can you guys help a brother out by getting him some new ones ASAP? He's out of a car until then.
Thanks you guys! We can send these ones back for warranty issues.
2008 Red MS3
BT & All
Pump - 411hp/403tq
**SOLD**
 Old 05-30-2012, 08:55 PM   #19
DISIindahead's Avatar
Posts: 911   (View Stats)
DISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the world
There is no scoring on the internals, We pulled the internals out, rechecked and relubricated them. Reinstalled and still same problem.
Sent from my Etch a Sketch
2010 Mazdaspeed 3 - Built Motor - GTX3071: SOLD
2012 Jeep Wrangler Unlimited Sport: Current DD
DISIindahead is offline   Reply With Quote
The Following User Says Thank You to DISIindahead For This Useful Post:
 Old 05-30-2012, 09:10 PM   #20
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
Running any kind of E? Clean spill valve?
But does sound like a bad internal.
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
 Old 05-30-2012, 09:15 PM   #21
dead-zone's Avatar
Posts: 442   (View Stats)
dead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the world
Groaned at 53 Times in 17 Posts
Do not forget to put some lubricant Good luck, hopefully you fix it!
dead-zone is offline   Reply With Quote
The Following User Says Thank You to dead-zone For This Useful Post:
The Following User Says NO Thank You to dead-zone For This Un-useful Post:
 Old 05-30-2012, 09:22 PM   #22
Mortose's Avatar
Posts: 2,441   (View Stats)
Mortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the world
Groans: 39
Don't feel lonely, i wasn't invited until i said something. lol. Too bad i was doing my rims.
dude, do you have any idea who you are talking too? these are the internal installing GURU'S of the springs. I'm quite sure they know what they are doing.
@sassyspeed3, how many sets have y'all put in now? lol
2008.5 Metropolitan Grey Mica: Sold
99 miata: sold
2011 Wicked White Evo X: built motor and efr7163 w/ full flex fuel
TRex - "i dont care if it is a soccer mom in a mini van, if that whore launches on me im going at it like im racing a supra....just so i can bask in the sweet sweet tears of their defeat"
Mortose is offline   Reply With Quote
The Following User Says Thank You to Mortose For This Useful Post:
The Following User Says NO Thank You to Mortose For This Un-useful Post:
dead-zone (08-06-2012)
 Old 05-30-2012, 09:31 PM   #23
mazdafreak's Avatar
Groans: 124
Neutral  -1 score
You don't even have to lub the internals when you put them in.......just prime pump 10-15 times.
713whp/569wtq!
 Old 05-30-2012, 09:42 PM   #24
dead-zone's Avatar
I am just trying to help. And BTW, If they made the mistake or possibly pitting it wrong does not really mean that they r very handy. And do not forget, we are human beings and we make mistakes.
The Following 2 Users Say Thank You to dead-zone For This Useful Post:
CowboyMS3 (05-31-2012), memin (05-30-2012)
 Old 05-31-2012, 05:59 AM   #25
he installed them himself the first time, we took them apart to see if there was a problem and there did not seem to be.
@Mortose - I think this is number 7....
2008 Red MS3
BT & All
Pump - 411hp/403tq
**SOLD**
 Old 05-31-2012, 06:14 AM   #26
Right now its just a matter of him getting a new set and installing. The car ran fine with stock FP internals, never dropped under 1600 until he installed the new ones.
 Old 05-31-2012, 07:48 AM   #27
event's Avatar
It might be possible that you blew your relief valve. With the car hot and off, does the fuel pressure climb to over 1600psi as the fuel heats up?
2013 Scion FR-S 6MT
 Old 05-31-2012, 08:09 PM   #28
CowboyMS3's Avatar
I would like to thank everyones help on this. After sassyspeed3 helpful last thoughts I looks at the pump again. I got runnin right. One of the spings in the relief valve was upside down turned it around and put back together and boom encouragement it works. Holds idle pressure @ 430-460
Boom Slide Side
 Old 06-01-2012, 05:50 AM   #29
Courtesy of @Captain KR, thanks will!
2008 Red MS3
BT & All
Pump - 411hp/403tq
**SOLD**
 Old 06-01-2012, 06:19 AM   #30
event's Avatar
Do you mean the spill valve? The relief valve is not serviceable.
2013 Scion FR-S 6MT
CP-E TMIC, Should I be worried? razorscs Mazdaspeed3/6 General Discussion 45 04-17-2012 11:17 PM
KR, Should I be worried? eb2292 2010 MS3 - ECU Computer Tuning 35 02-07-2012 03:44 AM
Should I be worried? ev0nstispanka MazdaSpeed 3/6 - Turbo Induction 9 04-23-2009 01:56 PM
Should I be worried? Eazy MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 08-26-2008 07:52 AM
Page generated in 0.52148 seconds with 34 queries
