 Old 04-02-2016, 05:41 PM   #1
GEE1989's Avatar
Posts: 182   (View Stats)
GEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant future
Default Solenoid vs Check Valve videos
I had posted this in a different thread but figured with the title this could be helpful for people who are looking for this.
First off, I have an aem kit. 5 gallon tank mounted in the trunk. So gravity feed is there. I'm running a DO 10 nozzle. I got the DO check valve and was not very happy with how it would taper to a squirt towards the end. So I bought a solenoid from DO. I took videos of the difference of the two and imo I really like the fact that the solenoid is an instant off once you are off throttle. In the videos, what ever you see laying on the car is what isn't being used. To me having meth still spraying after you let off the throttle is not good.
08 MS3
Corksport turbo, built motor, meth injection, and FREEKTUNED
GEE1989 is offline   Reply With Quote
 Old 04-02-2016, 10:30 PM   #2
dale_gribble's Avatar
Posts: 4,720   (View Stats)
I know what you are talking about, the check valves do pee a little. It's basically the amount of fluid in the line between the check valve and the nozzle. This effect can be minimized by running as short of line as absolutely possible between the check valve and the nozzle.
When throttle is off and the nozzle pees out, the boost is off and whatever is left isn't atomizing. I agree that a solenoid is superior for sure, but that the pee is pretty harmless.
MINI H1 6.0 - CAR LED TAILS
 Old 04-16-2016, 08:03 AM   #3
Dust's Avatar
Posts: 192   (View Stats)
Dust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the world
The dribble is whatever is between the hard stop (pump), and the nozzle. All of the pressure in the system from the pump to the check valve will come out until everything between the pump and check valve reaches the check valve pressure.
Dust is offline   Reply With Quote
 Old 04-19-2016, 06:27 PM   #4
GEE1989's Avatar
That's what I figured was going on. This video DO has for their check valve seems more like it's a solenoid imo. I thought the check valve would work like the video.
https://m.youtube.com/watch?v=MAaWtygKAQY
Sent from my SM-G920P using Tapatalk
08 MS3
 Old 04-19-2016, 07:29 PM   #5
Dust's Avatar
1. Without knowing how far the pump is from the nozzle, it doesn't really mean anything.
2. M14 will bleed off pressure alot faster than smaller nozzles.
Purge valve solenoid Boost Addict MazdaSpeed 3 - Engine, Transmission & Driveline 4 12-19-2013 05:59 AM
Check valve, Solenoid or both speeding3 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 2 08-11-2013 03:27 PM
Page generated in 0.25751 seconds with 23 queries
