MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection Have a CDFP fuel pump question? Do you want to add Nitrous or Water Injection to your Mazdaspeed 3/6 ? Please come on in! |
![]() | ![]() | #1 | ![]() |
![]() Join Date: Jan 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 952
(Thread Starter) | ![]() ![]() ![]() just took the shitty one out, when i compare it to the new one the springs look different. the length of the shitty one is smaller then new one, but the tip of the new one is a little loose.shakey is that ok. look at the pics, the clean one is the new one... Should i go ahead an install new one let me know, car is apart now.. ![]() ![]() ![]() ![]() ![]() ![]() |
![]() | ![]() | #2 | ![]() |
pewpew ![]() ![]() Join Date: Apr 2008 Location: NoVA
Rep Power: 758 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,124
| ![]() ![]() ![]() don't ask us...call/email up ptp to see what he thinks. |
![]() | ![]() | #3 | ![]() |
![]() Join Date: Sep 2009 Location: NE PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,832
Groans: 109
| ![]() ![]() ![]() i have no clue... but i have the same microfiber cloths lol
__________________ Mk7 GTI |
![]() | ![]() | #4 | ![]() |
(Thread Starter) | ![]() ![]() ![]() A Little update... The car runs, the new pump is much louder than the old one "tick tick tick tick" Just did the new initial break in. • Let the car idle for one minute • Rev the car in neutral to 1500 RPM for one minute • Let the car idle for one minute • Rev the car in neutral to 2500 RPM for one minute • Let the car idle for one minute • Rev the car in neutral to 3500 RPM for one minute • Let the car idle for one minute You repeat these steps at two minute and three minute intervals (total of 3 cycles). The fuel pressure was at 430psi while at these rpms. Ill report more later. |
![]() | ![]() | #5 | ![]() |
Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
| ![]() ![]() ![]() im assuming your "shitty one" is a seized ptp pump thats why the spring looks more compressed, not shorter its not letting the piston create a complete stroke, unlike your new pump. The shakey tip i have no clue. I've havent seen a ptp pump yet. Does he press the retainer? |
The Following 3 Users Say Thank You to NJSPEED3 For This Useful Post: |
![]() | ![]() | #6 | ![]() |
![]() Join Date: May 2009 Location: Little Neck, NY
Rep Power: 3768 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,108
Groans: 326
| ![]() ![]() ![]() I agree with gerry, its stuck halfway |
![]() | ![]() | #7 | ![]() |
Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| ![]() ![]() ![]() word |
![]() | ![]() | #8 | ![]() |
(Thread Starter) | ![]() ![]() ![]() so far so good. a whooping 10 miles to pick up beer and pizza. no cut just weird looks driving at 4k 5k 6k rpms down streets. I hate the ricer break in so much. |
![]() | ![]() | #9 | ![]() |
Trail of Fail ![]() Join Date: Jan 2010 Location: rock city AR
Rep Power: 9903 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,493
| ![]() ![]() ![]() what happened to the "let it idle for 30 minutes" breakin? I put in my PTP back in Feb and that's what the instructions said.
![]() | ![]() | #10 | ![]() |
Fuel Pump Break in Procedure Step one: • Let the car idle for one minute • Rev the car in neutral to 1500 RPM for one minute • Let the car idle for one minute • Rev the car in neutral to 2500 RPM for one minute • Let the car idle for one minute • Rev the car in neutral to 3500 RPM for one minute • Let the car idle for one minute You repeat these steps at two minute and three minute intervals (total of 3 cycles). Step Two: Drive car for next 100miles of just regular driving while fluctuating the rpm’s from 1000-5000, only use low boost. Step Three: Monitor Pump pressure during wide open throttle (if you have equipment to do so) if pressure drops repeat step two of brake in procedure. If you are not equipped to monitor fuel pressure then you’re going to have to watch for key signs of fuel cut. At first sign of fuel cut you’ll need to repeat step two of brake in procedure. | |
The Following User Says Thank You to 2007speed3 For This Useful Post: | Dano (06-10-2010) |
![]() | ![]() | #11 | ![]() |
![]() Join Date: Oct 2008 Location: Orlando/ Daytona Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 219
| ![]() ![]() ![]() lol good luck paul! Third times the charm!
__________________ 09 CWP Speed3 GT- CP-e Nano, Speedie6 TIP, CP-e Catless Downpipe, ED FMIC w/ GodSpeed core, Devils Own Stage 2 Meth Injection Kit, KMD v2 fuel pump internals, HKS BPV, SU full motor mounts & shifter bushings, Cobb Springs, 1 res delete in cbe, HID Fogs, AutoMeter Cobalt boost gauge, Michi OCC, Denso 1 step colder plugs, MSD DH, COBB AccessPort V105 Stage 2+sf 93 fmic [Today 11:50 PM] aaronc7: i just measured mine, a little over 12 |
The Following 2 Users Say Thank You to wakeboarddude For This Useful Post: | 2007speed3 (06-10-2010), IshiKage (06-11-2010) |
![]() | ![]() | #12 | ![]() |
![]() Join Date: Apr 2008 Location: MS
Rep Power: 842 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 360
Groans: 56
Groaned at 15 Times in 14 Posts
| ![]() ![]() ![]() I didn't break in my shit. But it wasn't ptp. I still have the pg v1 internals, 48k miles on them, just as strong as there were the day they went in. ![]() |
![]() | ![]() | #13 | ![]() |
![]() Join Date: Mar 2010 Location: Salinas, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31
Groaned at 23 Times in 10 Posts
One fail was enough for me...I went a different route....didn't want to bone around with more disappointment and inconvenience.
__________________ US Air Force Retired - Gunner - AC-130 Spectre Gunship / Disabled American Veteran 4 tours Iraq / 3 tours Afghanistan "Smoked 56" But Who's Counting? Vengeance From Above: http://www.youtube.com/watch?v=If-oQXk0oI4 COBB AP, COBB INTAKE, COBB Turbo Inlet Pipe, CP-E HPFP, CX-RACING FMIC, CP-E CATTED DP, CP-E EXHAUST, FORGE BPV, FORGE WGA, PTP PVC Restrictor Pill, Boon Turbo Bolt ![]() Last edited by MS3_65; 06-10-2010 at 03:16 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | ![]() | #14 | ![]() |
![]() Join Date: Dec 2009 Location: Fontucky, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,096
Groans: 1,364
Groaned at 589 Times in 386 Posts
| ![]() ![]() ![]() Tapping your shoes before you get into your car is Step 5 |
The Following User Says Thank You to felt For This Useful Post: | FreeFlyFreak (06-11-2010) |
![]() | ![]() | #15 | ![]() |
| ![]() ![]() ![]() When did you buy the first and second pump? Damn!..3rd pump?!!..You are defnitely a patient man..I'm envious. ..and crossing your fingers ![]()
__________________ US Air Force Retired - Gunner - AC-130 Spectre Gunship / Disabled American Veteran 4 tours Iraq / 3 tours Afghanistan "Smoked 56" But Who's Counting? Vengeance From Above: http://www.youtube.com/watch?v=If-oQXk0oI4 COBB AP, COBB INTAKE, COBB Turbo Inlet Pipe, CP-E HPFP, CX-RACING FMIC, CP-E CATTED DP, CP-E EXHAUST, FORGE BPV, FORGE WGA, PTP PVC Restrictor Pill, Boon Turbo Bolt ![]() Last edited by MS3_65; 06-10-2010 at 03:20 PM. Reason: MSF Database - Automerged Doublepost |
![]() | ![]() | #16 | ![]() |
Groans: 1,940
![]() | ![]() | #17 | ![]() |
There must be a very reasonable explanation to this issue. I thought the new PTP pumps were supposed to be the latest and greatest compared to their previous pumps?? What could be causing these "sticking" "seizing" issues? ![]()
__________________ US Air Force Retired - Gunner - AC-130 Spectre Gunship / Disabled American Veteran 4 tours Iraq / 3 tours Afghanistan "Smoked 56" But Who's Counting? Vengeance From Above: http://www.youtube.com/watch?v=If-oQXk0oI4 COBB AP, COBB INTAKE, COBB Turbo Inlet Pipe, CP-E HPFP, CX-RACING FMIC, CP-E CATTED DP, CP-E EXHAUST, FORGE BPV, FORGE WGA, PTP PVC Restrictor Pill, Boon Turbo Bolt ![]() Last edited by MS3_65; 06-10-2010 at 03:28 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() | ![]() | #18 | ![]() |
Groans: 1,940
| ![]() ![]() ![]() they stick at upper rpms due to the coating... so umm... the consumer is supposed to umm...rev harder, and rev more. hahahaha. that's the "break in" period. ahhhhahaha. suck my nuts with that shit. |
The Following User Says Thank You to phillyb For This Useful Post: | FreeFlyFreak (06-11-2010) |
![]() | ![]() | #19 | ![]() |
![]() Join Date: Mar 2010 Location: Washington
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 778
| ![]() ![]() ![]() just dont be surprised if your fuel pump isnt broken in @100 miles....It took mine about 200 miles actrully..its got 6000 miles on it since then and runs good. My pump looked like your new one btw...the older one doesnt look right..piston is not where it should be. As for my spring..it was on pretty firm.
__________________ 2009 MS3 COBB AP COBB INTAKE COBB/TURBOXS TBE DNP TURBO MANIFOLD CXRACING FMIC TURBOSMART BPV JBARONE RMM TURBOSMART BPV JBARONE SHIFTERPLATE COBB RSB KONIG WHEELS/HANKOOK TIRES TIM BAILEY PROTUNE 291WHP/310WTQ *AWD MUSTANG DYNO* |
![]() | ![]() | #20 | ![]() |
C-PE uses DLC but I read somewhere that PTP stated the DLC coating wears off. So how does the pump receive lubrication when operating? I recall the PTP pump was delivered dry while the CPE pump had some sort of lubrication in the pump....or that could've been me spewing from excitement of receiving the CPE pump!
__________________ US Air Force Retired - Gunner - AC-130 Spectre Gunship / Disabled American Veteran 4 tours Iraq / 3 tours Afghanistan "Smoked 56" But Who's Counting? Vengeance From Above: http://www.youtube.com/watch?v=If-oQXk0oI4 COBB AP, COBB INTAKE, COBB Turbo Inlet Pipe, CP-E HPFP, CX-RACING FMIC, CP-E CATTED DP, CP-E EXHAUST, FORGE BPV, FORGE WGA, PTP PVC Restrictor Pill, Boon Turbo Bolt ![]() | |
![]() | ![]() | #21 | ![]() |
![]() Join Date: Oct 2008 Location: Greenbackville, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,927
Groaned at 23 Times in 12 Posts
| ![]() ![]() ![]() god i hate break in periods...oh wait nevermind i got a cp-e pump yes i am an asshole and this post was completely useless lol
__________________ CP-E HPFpump™ CP-E 3" SS Cat Back Exhaust System CP-E 3" SS Downpipe System CP-E Rear Engine Mount CP-E XcelNANO™ Air Intake CP-E Nviscid™ Pipe CP-E Triple Gauge Pod Cobb AccessPORTv2 Cobb Anti Sway Bar(rear) Corksport TMIC PERM TUNED Forge bpv Eibach ProKit Prosport Wideband AFR Boost Oil Temp Oil Pressure JBR Shift Knob SunTek CarbonXP 30% around 2002 Mazda Protege5:AEM sri KYB gr2's DDM hid RIP |
The Following 2 Users Say Thank You to jax ms3gt For This Useful Post: | FreeFlyFreak (06-11-2010), reddeerspeed3 (06-10-2010) |
![]() | ![]() | #22 | ![]() |
Groans: 1,940
| ![]() ![]() ![]() idk. i'm sure he's posted that info here, but i cannot recall. |
![]() | ![]() | #23 | ![]() |
![]() | ![]() | #24 | ![]() |
(Thread Starter) | ![]() ![]() ![]() So far so good 120 miles on the pump today. No to low boost situations all the way to 6krpms. tomorrow im gonna floor it for the first time since February... -knock on wood |
The Following User Says Thank You to 2007speed3 For This Useful Post: | DaleNixon (06-11-2010) |
![]() | ![]() | #25 | ![]() |
Rep Power: 369 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 558
| ![]() ![]() ![]() don't blow it up !
__________________ 2013 Mazdaspeed3 Gen2 Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount |
![]() | ![]() | #26 | ![]() |
(Thread Starter) | ![]() ![]() ![]() 3rd times a charm i suppose. 120miles broken in and amazing. It a completely different car A+ now back to fucking around with ATR |
The Following User Says Thank You to 2007speed3 For This Useful Post: | Blackspeed (06-11-2010) |
![]() | ![]() | #27 | ![]() |
![]() Join Date: Nov 2008 Location: Sanford/Orlando/Daytona Beach FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,682
Groans: 278
| ![]() ![]() ![]() nice paul, glad to see you finally got back around to the speed.
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" |
![]() | ![]() | #28 | ![]() |
Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
![]() | ![]() | #29 | ![]() |
There are always going to be pump failures when you are MFG'ing down to .00005 of an inch, or when debris or end user installes get calculated into the part. This is why we have a test rig under construction, for those that can afford and pre-tested broken in pump.
Keep me posted, thanks. | |||||
![]() | ![]() | #30 | ![]() |
Groans: 1,940
| ![]() ![]() ![]() nice use of the multi button. i'll be sure to call you for those facts john. |
![]() | ![]() | #31 | ![]() |
| ![]() ![]() ![]() Sounds good. |
Display Modes | |
Quick Q | Hectik1 | MazdaSpeed 3 - Engine, Transmission & Driveline | 4 | 11-20-2009 09:21 PM |
Need some quick help... | AFcadet | Cobb ATR Support | 13 | 09-16-2009 05:49 PM |
Quick ? | SuperVillain | Cobb Access Port/Maps | 2 | 02-27-2009 09:52 AM |
quick MBC ? | EuroTuneR | MazdaSpeed 3/6 - ECU Computer Tuning | 22 | 07-30-2008 09:19 AM |
