Like Tree2Likes
  • 1 Post By Fstrnyou
 Old 02-02-2019, 12:44 AM   #1
lethalhazard's Avatar
Posts: 39   (View Stats)
lethalhazard has a spectacular aura aboutlethalhazard has a spectacular aura about
Default Spare fuel rail anyone?
Hey everybody. Does anyone have a spare OEM fuel rail with a sensor on it that still works? I’ll pay for it. Or any ideas on what it might be? It’s throwing a P0193: fuel rail pressure sensor circuit high output.
lethalhazard is offline   Reply With Quote
 Old 02-02-2019, 03:37 AM   #2
Fstrnyou's Avatar
Posts: 2,327   (View Stats)
Do you have an AP?
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 02-02-2019, 12:20 PM   #3
Originally Posted by Fstrnyou View Post
Do you have an AP?
Yes I do.
 Old 02-02-2019, 12:31 PM   #4
Fstrnyou's Avatar
What is the fuel pressure reading when you get the CEL?
Other rides:
History:
 Old 02-02-2019, 01:02 PM   #5
The fuel pressure is stuck at 24xx and the fuel rail pressure sensor says 0v.
 Old 02-02-2019, 02:31 PM   #6
Fstrnyou's Avatar
Yep. Check your coil pack harness for a broken connection.
It could also be in the injector harness or possibly anywhere between the ECU and sensor.
My fuel pressure signal wire was returning 0v intermittently because it was broken at the crimp in the large connector in front of the intake manifold.
lethalhazard likes this.
Other rides:
History:
lethalhazard (02-02-2019)
 Old 02-02-2019, 02:43 PM   #7
I thought it might be a connector. If it does come up to be a connector, am I able to buy some replacement connectors and just replace the connector end of it where it connects? Or do I have to buy a new harness? How did you fix it? Thanks again for the assist.
 Old 02-02-2019, 02:49 PM   #8
Fstrnyou's Avatar
I attempted to open up the crimp to redo it, but it's too damn tiny for the tools I have, so I just stripped back some clean wire and soldered it on top of the crimp.
I think the original wire was pretty tight, so I believe I soldered on a short piece of wire to relieve the tension.
I'm not a fan of soldered connections in vibration environments, but I didn't have much choice here.
Other rides:
History:
 Old 02-02-2019, 02:56 PM   #9
There you go. Thanks a lot. You saved me time and money. Much appreciated. I’ll update what I find. I won’t be able to get to it till next week though.
 Old 02-02-2019, 03:49 PM   #10
Fstrnyou's Avatar
If it's in the removable intermediate harness like mine, it's an easy-peasy fix.
Other rides:
History:
 Old 02-03-2019, 11:50 AM   #11
eroler1's Avatar
Posts: 117   (View Stats)
eroler1 has a spectacular aura abouteroler1 has a spectacular aura about
you can try changing the sensor, IDK why people strongly believe about the sensor "one piece" with the rail, ive changed it before and this sensor is is exactly same as the one in there, i have ap and this sensor reads 0-2000psi or even more, sensor for 2009 chevy cobalt you can get it from local auto parts store,
BTW JMF manifold have a extension that will relocate the sensor, so it is removable.
i have jmf and i also changed the sensor.
one good thing about it is if its not the problem you can return the sensor just brake clean it and say "i didnt use it, its different problem i got"
https://www.autozone.com/engine-mana...hText=80090002
eroler1 is offline   Reply With Quote
other cars that share our fuel system (specifically fuel rail) TWOptSL0W MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1 05-12-2012 08:13 AM
In tank fuel pump and fuel rail valve Seatime3 2010 MS3 - Fuel, Nitrous & Water Injection 1 04-30-2012 07:44 PM
Page generated in 0.31778 seconds with 23 queries
