 Old 10-25-2011, 06:58 PM   #1
Default In-Tank Fuel Pressure Tester
so i made this handy dandy device for testing my ITFP. ive seen a ton of people who are having similar problems and this is the easiest way to test it. here's how im going to work this:
$50 deposit via paypal, you pay shipping both ways (also via paypal). if i get it back and its not broken, ill give u your 50 bucks back so its essentially free. send me a PM if your interested. also please return it within 7 days of getting it if someone else is waiting.
it just slips on your stock fitting on the CDFP so you dont have to drill/cut anything. if your cool like me you will tape it to the windshield and drive around to verify haha. you should have exactly 65psi at all times with no flutter (+/- 3psi is fine).
The Following 11 Users Say Thank You to superskaterxes For This Useful Post:
06Speed6 (10-26-2011), Alpha (10-25-2011), BlueStreak (10-25-2011), cabrone (10-25-2011), Ckmazdaspeed3 (11-02-2011), Constantin (09-12-2012), djuosnteisn (11-02-2011), jracer (10-26-2011), karl-hungus (10-26-2011), triplejumper18 (10-26-2011), vbt101 (11-02-2011)
 Old 10-26-2011, 03:30 PM   #2
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Ghetto fab!
2006 Mazdaspeed 6
 Old 10-26-2011, 06:10 PM   #3
Speeed3's Avatar
Posts: 484   (View Stats)
Speeed3 is the leader of the worldSpeeed3 is the leader of the worldSpeeed3 is the leader of the worldSpeeed3 is the leader of the worldSpeeed3 is the leader of the worldSpeeed3 is the leader of the worldSpeeed3 is the leader of the worldSpeeed3 is the leader of the worldSpeeed3 is the leader of the worldSpeeed3 is the leader of the worldSpeeed3 is the leader of the world
@BGofMD
Speeed3 is offline   Reply With Quote
 Old 10-26-2011, 07:16 PM   #4
^^^^^ lol why am i not surprised brian might need this. wtf hes a mazda tech he can just use the SST from work haha
 Old 10-26-2011, 08:36 PM   #5
Speeed3's Avatar
I got Brian a job with me he doesn't work at Mazda anymore but thats the problem he thinks he has with his car hes tried like 4 different fuel pumps his shits still not fixed.
 Old 10-27-2011, 12:11 AM   #6
BGofMD's Avatar
Posts: 312   (View Stats)
BGofMD has a reputation beyond reputeBGofMD has a reputation beyond reputeBGofMD has a reputation beyond reputeBGofMD has a reputation beyond reputeBGofMD has a reputation beyond reputeBGofMD has a reputation beyond reputeBGofMD has a reputation beyond reputeBGofMD has a reputation beyond reputeBGofMD has a reputation beyond reputeBGofMD has a reputation beyond reputeBGofMD has a reputation beyond repute
Groaned at 40 Times in 12 Posts
omfg please gimme now!!! i want my car to fing work its been four months already. Ill do this and give it back the same day is i get a free deposit XD
BGofMD is offline   Reply With Quote
 Old 10-27-2011, 03:03 AM   #7
paveltol's Avatar
Posts: 520   (View Stats)
paveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the world
Groaned at 23 Times in 2 Posts
Useful mod for checking tank pressure. Lots of MS6 here suffer from the fuel filter being clogged. Actually it is not a filter - it is just a plastic grid, installed inside fuel pump assembly. MS6 does not have any more fuel filters!!!
FYI, CX7 does have it.
Mazda 6 MPS Velocity Red, cp-e nano, cp-e TIP, BNR Stg3, Custom FMIC, cp-e HPFP, HKS Twin Power DLI2 ignition, HKS M35LF spark plugs, EGR block-off, catless 3" dp with welded in resonator, AutoExe Grounding Earth System, Grimmspeed BCS, AWR competition radiator, JBR SSP, 355mm 4-piston JBT Big Brake Kit, Rays RE30 wheels, Advan v103 tires, etc..
paveltol is offline   Reply With Quote
 Old 10-27-2011, 05:59 AM   #8
brian just come to my house and we can test it on the spot. unless your car isent driveable
 Old 10-27-2011, 02:20 PM   #9
BGofMD's Avatar
Nah my car is driveable grandma style. either my relief valve of my ITFP took a huge shit on me. This will rule out one. My idle FP is like 80-150 and wot doesnt go over 500psi on 4 different cdfp. what time you free tomorrow?
 Old 10-27-2011, 04:49 PM   #10
your RV took a dump. this JUST happened to rich and he had identical symptoms.
 Old 10-27-2011, 11:50 PM   #11
paveltol's Avatar
What is a RV?
Part number-?
 Old 11-02-2011, 12:27 PM   #12
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
Here's link for anyone who would rather just buy the adapter:
Central Florida Motorsports, Inc.- Ford Fiesta Focus Mustang Performance Parts & - Fuel Rail Adapter
They accidentally sent me one for a cobra made for 3/8" fuel lines instead of our 5/16"... but it was a simple swap. So just be sure they send you the right one. It should fit straight on to the oem hpfp nipple, and the line fits on it.
Anthony, what did you use for thread seal? Teflon tape?
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 11-02-2011, 12:42 PM   #13
yah just teflon tape. afaik your not supposed to use a sealant on NPT fittings as that's the point of the thread taper but i did it just to be safe.
 Old 11-02-2011, 12:54 PM   #14
Plumbers use PTFE tape or paste all the time on NPT fittings. Fluid can still seep out around the threads on NPT fittings without a sealant.
Thanks for the info guys. I'll be ordering the adapter soon as I already have a FP testing gauge.
 Old 11-02-2011, 01:00 PM   #15
Captain
Groans: 79
Lol, NPT didn't stop gobs of oil from pouring out my sandwich plate... so i'm not going to even risk it with gasoline. I'm gonna pick up some permatex #3 based off this chart:
http://www.permatex.com/documents/Ga...ngSelector.pdf
Unless some one has a better suggestion.
www.permtuning.com
 Old 11-02-2011, 01:04 PM   #16
Teflon tape is perfectly fine Dustin. PTFE is non-reactive.
 Old 11-02-2011, 01:26 PM   #17
Captain
Groans: 79
Mucho's gracias then.
Oh... and food for thought, that CFM adapter has 2 ports..... for those who may be interested in the giggle gas
www.permtuning.com
 Old 11-02-2011, 01:34 PM   #18
You know, that might not be a bad way to supply fuel for supplemental injectors...
Audi recalls A6, S6, RS6 over possible fuel tank issue Haltech Automotive News 0 05-09-2011 03:30 PM
VW awards U.S. fuel tank contract to TI Automotive Haltech Automotive News 0 04-08-2009 12:30 PM
HUMMER recalls '09 H3T for fuel tank that could fall off Haltech Automotive News 0 03-14-2009 09:20 AM
GMC Sonoma Stalls, Sugar in the Gas Tank, Correct Tire Pressure, Ford Escape Tire Shimmy: Mike Allen's Weekly Online Aut Haltech Automotive News 0 07-25-2008 02:30 PM
Page generated in 0.36717 seconds with 26 queries
