  • 1 Post By IshiKage
 Old 02-14-2012, 12:13 PM   #1
abiezerf's Avatar
Posts: 725   (View Stats)
abiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the world
Groans: 46
Default Upgraded HPFP?
Ok, I need to know if I have an upgraded HPFP.
I am not sure because I bought this car used and all signs point to yes, but I have not had a chance to remove the FP and visually check. Relevant mods are intake, downpipe/racepipe, and FMIC.
Attached are three WOT logs that I did right before I realized my turbo was broken. I am getting a new turbo soon, but I need to know if, based on these logs, I have an upgraded FP, or if it is stock. I need to know because I am planning on going BT and want to see if I need to add that to my expense list. Please take a look at logs and let me know.
PS. Boost is low in logs due to broke turbo with leaky oil.
Current Build:
Liquid Silver Metallic Pu - JBR Shifter Bushings, Cobb AP, JBR Chome Molly
JBR SSP, ProSport Premium Boost Gauge, 25% e85 Tune
PTP HPFP Internals, CorkSport Intake/TIP, Cobb Sport Springs
Sold:
2008.5 Black Mica GenWon - Fully Bolted
abiezerf is offline   Reply With Quote
 Old 02-14-2012, 12:15 PM   #2
Boost Addict's Avatar
Posts: 1,327   (View Stats)
Its going to be hard to tell with you only running 8lbs of boost. More boost = less fuel.
At this boost level you seem fine, but as soon as you get a new turbo and run ~18lbs it may fall.
FREEKTUNE
 Old 02-14-2012, 12:17 PM   #3
speed23's Avatar
Posts: 1,480   (View Stats)
I would say upgraded as you are hitting 1700-1800psi and stock is normally closer to 1600psi
 Old 02-14-2012, 12:18 PM   #4
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
Go with PTP
Mustspeed2010 likes this.
2015 Mazda 6
 Old 02-14-2012, 12:59 PM   #5
abiezerf's Avatar
Groans: 46
Originally Posted by IshiKage View Post
Go with PTP
??? Huh? Why the random comment?
Current Build:
Sold:
 Old 02-14-2012, 01:01 PM   #6
EdgeAutosport.com's Avatar
Posts: 6,209   (View Stats)
OP just take them out it will take you <30 minutes
 Old 02-14-2012, 01:56 PM   #7
abiezerf's Avatar
Groans: 46
If I do take them out, how will I know they are upgraded?
Current Build:
Sold:
 Old 02-14-2012, 02:21 PM   #8
IshiKage's Avatar
Groans: 278
skimmed. muh bad. looks like you do have a UGFP based on your logs with the mods you have but take a pic of the internals and we will be able to tell you if they are upgraded.
2015 Mazda 6
Upgraded HPFP w/o Tune? f-castrillo 2010 MS3 - Engine, Transmission & Driveline 36 09-10-2011 07:14 PM
upgraded hpfp question fishin53 2010 MS3 - Fuel, Nitrous & Water Injection 9 08-31-2011 06:17 PM
Upgraded HPFP on stock tune Meder MazdaSpeed 3/6 - ECU Computer Tuning 21 02-01-2011 04:05 PM
Page generated in 0.28701 seconds with 25 queries
