 Old 10-22-2017, 09:54 AM   #1
meekerMS3's Avatar
Posts: 29   (View Stats)
meekerMS3 will become famous soon enough
Default Water/Meth Injection Advice
Hello All,
After reading numerous threads and researching as much as possible, I figured I would see if anyone can offer direct advice. I have a 08 MS3, no plans to go bigger than the K04, so just want to use the kit mainly for cooling purposes. (Mods: Cobb AP, fuel pump internals, TIP, SRI, TMIC, BPV, DP/RP, EBCS, one step colder plugs...protune scheduled for next Tuesday).
Just looking for current/up to date advice regarding the best kit to go with and any installation write ups out there.
I am leaning towards the Cooling Mist stage 2 CMGS kit with auto learn failsafe universal kit, and use the Damond Motorsports throttle body mounting plate. Just wanted to see if this is a good option or if there is something better to look into?
Thank you for any help/advice!
meekerMS3 is offline   Reply With Quote
The Following User Says NO Thank You to meekerMS3 For This Un-useful Post:
Thor Hammer (10-23-2017)
 Old 10-22-2017, 12:54 PM   #2
mituc's Avatar
Posts: 3,526   (View Stats)
Groans: 111
Double post FAIL?
WMI Advice
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 10-22-2017, 03:00 PM   #3
meekerMS3's Avatar
Yeah not sure how to delete it?
METH/WATER INJECTION - How it works JP@edgeautosport.com EdgeAutosport.com 9 04-02-2013 11:12 AM
Water-Meth injection EvilMonkey MazdaSpeed 3 - Engine, Transmission & Driveline 2 08-06-2008 09:41 AM
Page generated in 0.25259 seconds with 21 queries
