 Old 08-13-2015, 11:44 AM   #1
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
Default Water Meth runninf leaner instead of richer?
Hey guys, I've just recently installed the Snow Performance Stage 1 kit on my 2009 speed 3 running a 50/50 mix of deionized water and 99% pure methyl hydrate. I've verified that the pump is primed and sprays out of the nozzle instantly once energized. I know that the AFR at WOT is suppose to richen up, but I'm getting the complete opposite. I'm targeting 11.8:1 and when not spraying meth the car hits 11.76- 11.83. But with the meth turned on it will average at 11.94 sometimes 12:1. What seems to be causing this slightly leaner condition? Btw I'm using a 175ml/h nozzle which is the smallest one that came with the stage 1 kit. Thanks.
- 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress)
 Old 08-13-2015, 06:58 PM   #2
sheston's Avatar
Posts: 1,847   (View Stats)
Post a log.
Where did you put the nozzle? Pre-throttle body spacer? cold pipe?
 Old 08-13-2015, 07:32 PM   #3
Boost_creep's Avatar
Posts: 829   (View Stats)
Boost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the world
The 175ml nozzle should not affect your afr at all. To be honest, it's probably barely cooling your intake charge. Lol. I suggest putting the 375ml nozzle in for a k04 car.
Boost_creep is offline   Reply With Quote
AEM V2 Water/Meth SFWD 1934 2010 MS3 - Fuel, Nitrous & Water Injection 28 06-22-2014 04:04 AM
COMPARISON: Labonte Stage 2 Water/Meth Kit vs. AEM Water/Meth Kit The Great NY Mazdaspeed Forums User Reviews 2 01-19-2013 08:48 AM
Oil in your Water/Meth mix? evidence MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 07-21-2010 04:42 PM
AEM Water/Meth Kit trickytwelveinch MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1 07-17-2009 01:22 PM
Water/Meth Bravnik MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 10 05-03-2008 06:39 AM
Page generated in 0.24633 seconds with 22 queries
