  • 1 Post By dale_gribble
 Old 03-08-2016, 04:30 PM   #1
GEE1989's Avatar
Posts: 182   (View Stats)
GEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant future
Default Where to weld in meth bung cobb fmic
I am going to be running two nozzles in my meth kit. 1 in the throttle body spacer and another just after the intercooler outlet. With the cobb pipes, the outlet is on the passenger side. I haven't installed this yet due to waiting on my engine to come back from being built. I am wondering where I would have room in this pipe to mount a nozzle. uploadfromtaptalk1457479819956.jpg
Sent from my SM-G920P using Tapatalk
08 MS3
Corksport turbo, built motor, meth injection, and FREEKTUNED
GEE1989 is offline   Reply With Quote
 Old 03-08-2016, 07:03 PM   #2
Boost_creep's Avatar
Posts: 829   (View Stats)
Boost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the world
I mounted mine right before the throttle body, after the bpv.
Boost_creep is offline   Reply With Quote
 Old 03-08-2016, 07:14 PM   #3
dale_gribble's Avatar
Posts: 4,720   (View Stats)
I don't think you want it before the BPV OP. Also, I'm not sure what you'll gain going that far back. If you are running TB spacer, run one pre TB, maybe a few inches before, and one in your spacer. Read my thread about meth injection locations.
blackms3_71 likes this.
MINI H1 6.0 - CAR LED TAILS
Vader (03-09-2016)
 Old 03-09-2016, 04:14 AM   #4
blackms3_71's Avatar
Posts: 2,250   (View Stats)
blackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the world
I run my nozzle in my coupler on my cobb kit. Works pretty well.
COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned
blackms3_71 is offline   Reply With Quote
 Old 03-09-2016, 05:10 AM   #5
GEE1989's Avatar
My thinking was to spray a little earlier to get cooler bat's cause the meth will have pulled the heat out and then the tb spacer would act more as aux fueling. But I did read your thread. So maybe one at the bpv and then I'm trying to figure out how far back to put the second nozzle to zapp the temps as much as possible
The longer the meth is in the air, the more effectively it would act as chemical intercooling and evaporate into the air
Im no expert but that's what my thought process was
08 MS3
Last edited by GEE1989; 03-09-2016 at 05:10 AM. Reason: MSF Database - Automerged Doublepost
 Old 03-09-2016, 06:39 AM   #6
GEE1989's Avatar
I saw how the cobb pipes cross where that meth bung is mounted. Does that not interfere with the piping route there?
08 MS3
 Old 03-09-2016, 06:49 AM   #7
Code Monkey's Avatar
Posts: 7,673   (View Stats)
After the BPV and as far away from the throttle body as possible (which in our case will still be relatively close).
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
dale_gribble (03-09-2016)
 Old 03-09-2016, 08:05 AM   #8
Nope. No interference.
 Old 03-09-2016, 12:10 PM   #9
GEE1989's Avatar
Thanks @dale_gribble for that article you wrote on the meth injection. Im gonna tap two meth bungs with smaller nozzles in the pictures I have where the x is. Im gonna use do elbow connectors. Do these look like good spots before I get them welded?uploadfromtaptalk1457550605751.jpguploadfromtaptalk1457550613670.jpg
08 MS3
 Old 03-09-2016, 03:55 PM   #10
Thanks @dale_gribble for that article you wrote on the meth injection. Im gonna tap two meth bungs with smaller nozzles in the pictures I have where the x is. Im gonna use do elbow connectors. Do these look like good spots before I get them welded?Attachment 222690Attachment 222691
That looks good to me!
Weld in O2 bung YokiMazoku 2010 MS3 - Engine, Transmission & Driveline 12 07-05-2010 05:31 PM
O2 sensor bung, is AEM = innovate for bung size? marcusdigi MazdaSpeed 3/6 - Turbo Induction 5 07-19-2009 08:16 PM
Cobb DP Bung Size BreakTheStatic MazdaSpeed 3 - Engine, Transmission & Driveline 5 12-29-2008 07:53 AM
Page generated in 0.31144 seconds with 25 queries
