  • 1 Post By mrlilguy157
 Old 03-24-2008, 05:57 PM   #1
mrlilguy157's Avatar
Posts: 606   (View Stats)
mrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the world
Default Why Different Designs In Pumps?
to the pump stuff - all names aside, Autotech APR mrlilguy or CP-E, lets talk about the designs.
The APR design: a thicker piston from top to bottom, which allows for more volume of fuel to enter the pressure chamber of the pump per stroke. What you get is higher pressures throughout and more volume pressurized. Their new internals are pictured here:
As you can see, the APR internal upgrade utilizes new seals, a drilled retainer nut, a new piston, a stiffer spring, and new bore, all while maintaining the same factory Hitachi retainer.
I have no pumps with me right now, so I cannot work out the math, but will do so once I return to Dallas. That way you guys can understand the new volume displacement by the upgraded pumps, which will also show that the upgrade kit that I utilize outflows the APR design, which is used by CP-E.
Moving onwards...
The other guys, Autotech, have a different design, noted as 'plunger style'. This allows for the stock retainer to be used, as well as the stock seals. When APR decided to go with a complete thicker diameter piston, they HAD to drill the retainer nut to allow the new piston to fit through, which also requires the use of new seals. Both designs are acceptable - both do the job, both seal the compression/pressurization chamber from the head of the motor (where possible fuel/oil dilution could occur). The plunger style, once again, allows for the stock seals and retainer to be used. Also, the stock spring is used. Although many have presented controversy about this, the mass difference in the Autotech design, is minimal, further proven in this post.
Here is a picture of the plunger design, as well as the new retainer.
Looking closely, you can see that the bottom end of the pistons diameter is larger than the top end - which defines 'plunger style'.
Look again, here, at my amateur photography and out of focus pictures:
Clearly, the larger end of the piston is shown. This, just like APR's design with a larger diameter full length piston, has a larger diameter part of the piston where it matters, just longer than the stroke of the actual piston as the tri-lobe of the intake camshaft forces the piston in and out out the pump, to create pressure.
As stated, I'll work the exact math for you guys to prove the new volume displacement and flow percentages, between APR and Autotech designs. Also, dada stated earlier in this thread that the Autotech designs were never tested. They were before production began on a diesel pump tester up the road, which proves the mathematic equations to be true, just like Physics. You do the math and figure out your solution, or you can do the mechanical experimentation and lab work to further take note of data, to get your answer. Autotech opted not to purchase and build an $80,000 test rig, and use one up the road from their facility in Aliso Veijo, CA.
As to the debate with the increased mass of the new piston (in either design) as well as the spring force, I will quote myself from another thread, in which I also added more details for futher clarification:
Originally Posted by ptperformance View Post
It looks like the spring for the pump upgrades may be bouncing off the lobes under very high RPM. The additional weight of the bigger piston may be over working the stock spring, looks like a better spring may be needed as well.
The mass difference between my piston and the stock piston is about a gram, if not less. I don't have a scale next to me at the moment, but I'll be sure to measure and take some picssssss. Also, the car's RPM isn't really increasing. Redline is still near 7k rpms. My buddy JC has a monster of a 2.0t GTi and drives it up to 8k, using this pump, and no side effects have presented themselves
Originally Posted by Direct from Brian@Autotech (AutotechRD)
Brett[@APR], you keep bringing up the fact that we didn't use a special return spring to match our pump. With an already marginal contact wear situation, a stronger spring would, in my opinion, create the an increased chance of abnormal wear on the fuel pump lobes of the camshaft. Keep in mind that the piston in our pump didn't increase in weight as much as yours, either.
Thanks for looking out though!
Originally Posted by dadasracecar View Post
Interesting. My cp-e pump came with a bigger spring presumably for reasons you've articulated. I'll see if I can dig up a side by side comparison pic.
Yes indeed it did, for the whole piston in the APR pumps is larger diameter and larger mass, from beginning to the end. Therefore, APR found it necessary (and I agree) to include a new, stiffer spring for the increase movement in mass. After weighing in, the new retainer and piston assembly weighs approx. a whopping 1.25g heavier.
Originally Posted by palerider View Post
What the hell is this big spring all about? Do I have one? I did Ants spring mod.... does that count?John? John?....lol
A stiffer spring is suggested for a significant increase in mass.
edit: Pics found.
^^^^that is the stocker and the retainer^^^^^^^
that is the piston we use, without the retainer. the retainer weighed in near 4.25grams (no scale is perfect). btw - the cloth weighs 7g
As shown, the increased mass for the plunger style, is almost negligible (1.25grams), where as the APR design - larger diameter piston has increased mass from top to bottom - has an increased mass throughout, resulting in probably 4 or 5grams heavier. This, although doesn't sound like a lot of weight, is moving at 3strokes per revolution of the intake cam, which is a lot of mass to be thrown around at such high speeds.
Also, a new design has surfaced from VF-Engineering. They make good stuff, but have rough customer service as I used to directly deal with them.
Here's a picture:
Notice that even though half of the piston is the increased diameter, they still retain the stock spring, and use an aftermarket retainer.
There is another company that is in the production phase of their kit. They have a pump from me, and perhaps they'll show something new and impressive. Honestly, I have no concern in switching manufacturers for any reason. All of the pumps designs have been proven to work.
Another point of comparison is here:
The contact point on the cam follower unit, with the new pump upgrade. APR decided to use the factory Hitachi pump retainer unit, great idea, thats nice.
The contact area with the Autotech upgrades to the cam follower unit is the same, as shown in the picture. Notice that the very center circle of the retainer which is pictured 'closer' to you, is the only point of contact on the cam follower unit:
I hope this all makes some sense and shows you that both pump upgrades will do the job, and both are extremely effective solutions. The only difference which can actually be proven to create a different end result, is the larger diameter of the piston, which Autotech surpasses APR, but only by the smallest margin. Both companies did their homework on the design, and both companies have hundreds upgrades performing flawlessly for over hundreds of thousands of miles.
So, in conclusion to all of this explaining - Thumbs up to both designs. CP-E's pump will get the job done, and so will mrlilguy's. Both are taking orders and both are shipping soon. Last week CP-E said 2 weeks, I would think that would mean next Monday. mrlilguyCDFP's will go out this week.
Furthermore, if there is any questions or concerns, let me know through PM's.
Also, PTP has been developing their own upgrades and this is the information I've got from his forum, as well as clarifications on differences:
The stock parts are coated with a "secret sause" coating. We have no idea what it is but... we will be ti-nitride coating ours (this is what they coat dril bits with). The "others" no coatings at all that I have seen.
my fuel pumps go through a thorough hardening process and are ridiculously polished and heat-treated to provide very extremely frictionless characteristics.
CP-E's fuel pumps have a 'DLC' coating which stands for 'diamond-like coating'. I don't like the acronym, but the parts are definitely coated and look almost like black chrome.
The weight of the retaining hardware from the "others" is 3 to 8 grams more then the stock assembly (some come with a new spring others do not). Ours will be using titanium retainer and moly locks that come back 2 to 4 grams ligher then the stocker. This will give less load on the spring to keep it from bouncing off the cam lobe at high RPM's.
The complete piston/bore/retainer assembly on the upgraded parts which I provide vs. stock is about 4 grams heavier, for the COMPLETE ASSEMBLY. The stock retainer vs. the titanium retainer and locks I use is actually less in weight, just like what youre going to offer.
As far as the CP-E pumps go, I don't know the right specs but I do know that they use the stock retainer, but the piston is 'significantly' heavier than stock, so there is a stiffer spring supplied with their kits.
Price... now this is all over the place with the others, anywhere from $800 to $349. We have targeted our pump to be priced at $299 and so far it looks good to hit that target mark (waiting on the ti-nitride process quote).
Current Price breakdown:
mrlilguyCDFP: $549 for the mail in upgrade or core exchange/$899 for a brand new fuel pump with upgraded parts.
CP-E: $622 (via StreetUnit) for the mail in upgrade or core exchange/$997 for a brand new fuel pump with upgraded parts.
PTP parts (from what has been said): $299 for a do it yourself kit.
Westbound likes this.
Black Mica '07 Mazdaspeed3
Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing
Reppin' ProtegeGarage for life!
mrlilguy157 is offline   Reply With Quote
The Following 12 Users Say Thank You to mrlilguy157 For This Useful Post:
breakfstincluded (10-19-2011), cocoanton (07-01-2010), Crossbow (04-09-2008), jlarson1983 (03-25-2008), kosh (04-24-2008), NYpest (03-24-2008), roth4fun (12-13-2009), SgtP (04-13-2008), SLS MS3 (03-25-2008), Westbound (02-08-2019), xcoldricex (07-20-2008), xfeejayx (03-30-2011)
 Old 03-24-2008, 08:02 PM   #2
CMESCOOT's Avatar
Posts: 429   (View Stats)
CMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the world
You are the man!!! I am seriously pacing around like a little kid, waiting to get mine in the mail!
CMESCOOT is offline   Reply With Quote
 Old 03-24-2008, 08:18 PM   #3
NYpest's Avatar
Posts: 1,889   (View Stats)
NYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the world
same here
NYpest is offline   Reply With Quote
 Old 03-24-2008, 08:28 PM   #4
lol. Give me some thanks
The Following 3 Users Say Thank You to mrlilguy157 For This Useful Post:
javanc (03-26-2008), jlarson1983 (03-25-2008), NYpest (03-24-2008)
 Old 03-24-2008, 08:36 PM   #5
CMESCOOT's Avatar
Brother, I couldnt begin to tell you, on behalf of all of us in the MS3 community just how appreciative we are for your hard work and integrity! I know I sent my pump in a long time ago, and could have easily been "snowed" by getting my new pump back in the time initially stated on the thread. However, you were honest enough to recognize the slight chance that the tollerances of the new pumps may not be as promised. I would much rather wait until I KNOW that I am getting a 2nd to none product than to bolt on a potentially damaging piece. Thanks!!! Take your time and get 'em right....but HURRY THE HELL UP!! LOL
 Old 03-25-2008, 11:56 PM   #6
jlarson1983's Avatar
Posts: 887   (View Stats)
jlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the world
man looks like you know your ish about these pumps!
jlarson1983 is offline   Reply With Quote
The Following User Says Thank You to jlarson1983 For This Useful Post:
NYpest (03-26-2008)
 Old 03-26-2008, 12:10 AM   #7
thank you sir. I've got more info I'd like to post up, but I haven't had time to do a write up about it yet.
Pumps are available now if you're interested!
edit: I hope you saw all of the pics.... looks like my host is down at the moment
 Old 03-26-2008, 12:27 AM   #8
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
I have a question on future pumps. Are they going to be available with blue leds?
 Old 03-26-2008, 09:25 AM   #9
ACTUALLY... thats something we're in development with. The pump is already grounded, so I would just need to tap into the solenoid electrical for a positive feed
The Following User Says Thank You to mrlilguy157 For This Useful Post:
NYpest (03-26-2008)
 Old 03-28-2008, 02:10 PM   #10
ATE BALLER's Avatar
Posts: 3,227   (View Stats)
ATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the world
So what about PTP's pump? Any speculation on that yet? It's sounding like it's a whole newly developed design, from scratch. He's also talking about other modifications to the fuel system as well. Any thoughts?
Originally Posted by StreetUnitMark View Post
I don't think I could go one day without some sort of meat in my mouth.
ATE BALLER is offline   Reply With Quote
 Old 03-29-2008, 01:10 AM   #11
I am curious to see what he comes up with. John has lots of great ideas, but unfortunately I cannot comment until an actual design is seen, materials are chosen, and products are in production.
As far as I'm concerned, my cam-driven fuel pump upgrade is more than enough for the fuel system. Anything beyond the CDFP upgrade (from any company) is not needed at this point. The cars are running great and there is plenty of fuel and pressure available. This design has a dyno chart showing well over 400 crank horsepower, and soon to be well over 400whp.
This chart is from a personal friend of mine, who has the fastest build 2.0t GTi in the VW market. He's on stock internals and a 3071r as well. The fuel systems are the same, the pumps are the same with different low pressure inlets/outlets, and he's a 2.0t. His dip in the tune is not something he is going to deal with daily. He works directly with Revo and is building their big turbo file. He is the test car and test bed.
His fuel mods include new injectors and the fuel pump upgrade. Thats it. No intank fuel pump upgrade or inline lowpressure pump upgrade.
yes, the car has a different name over it. "Volkswagen". Yes, Hitachi/Bosch is the fuel system, just like a Mazda. That is why I use and refer to the VAG cars so often.
 Old 04-10-2008, 01:41 PM   #12
mazdaspeedjay's Avatar
Posts: 99   (View Stats)
mazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the world
you'd da man lil'guy. Anyone out there looking for a pump this is the man to see i've installed his pumps on other friends cars and will be ordering mine in the near future and by far these are the best. You simply don't see other companies out there putting as much time and research and developement and even taking the timet o come out on a forum and explain what your buying , why you should buy it, and why his is the best and have and post the techinical data to back up what he claims. I really wish more companies would go that extar mile and put in that extra effort that you and people like john from pt do.
My car: 2008 Mica black Mazdaspeed3 sport model:
-Currently Serving in the United States Marine Corps. as a Machine Gunner ( 0331 ):
-Afghanistan southern heldman province Oct.09'-May.10'
MODS: COBB Short air intake, ONE OF THE FIRST PEOPLE TO HAVE THE ACCESS PORT BETA TESTER, Cobb access port, CP-E Catted Down pipe ( now no cat.'s ), Custom Exhaust,Turbo X's Hybrid BOV , Coil Pack spring mod, MY Very own Intercooler Cover mod, 8000K HiD Head Light upgrade, Stri electric boost gauge, EGT and turbo timer, AEM UEGO Wide band A/F Gauge, CP-e Dog bone lower mount with race bushing, Red Calibers, yellow fog lights. CP-E fuel pump upgrade.
mazdaspeedjay is offline   Reply With Quote
 Old 04-11-2008, 01:43 AM   #13
thank you for the praise, comments like that keep me motivated.
 Old 04-14-2008, 01:33 PM   #14
Jspeed6's Avatar
Posts: 6   (View Stats)
Jspeed6 is an unknown quantity at this point
....where do I go to order? price? procedues? this is something I am now looking to do in the next week or so. I am essentially running a full bolt on car and was looking to order an ems the same time I grab the CDFP. thanks in advance for your assistance.
"Stock"
Jspeed6 is offline   Reply With Quote
 Old 04-14-2008, 01:43 PM   #15
PM sent
 Old 08-11-2008, 03:20 PM   #16
Pictures are gone from the thread - can you please put them back. Thanks!
 Old 08-11-2008, 03:23 PM   #17
Also how does the control system handle/deal with the increased flow of the pump?
 Old 08-11-2008, 03:28 PM   #18
im on a plane. i'll do it when i get home.
 Old 09-09-2009, 03:58 PM   #19
skipunk11's Avatar
Posts: 224   (View Stats)
skipunk11 has a reputation beyond reputeskipunk11 has a reputation beyond reputeskipunk11 has a reputation beyond reputeskipunk11 has a reputation beyond reputeskipunk11 has a reputation beyond reputeskipunk11 has a reputation beyond reputeskipunk11 has a reputation beyond reputeskipunk11 has a reputation beyond reputeskipunk11 has a reputation beyond reputeskipunk11 has a reputation beyond reputeskipunk11 has a reputation beyond repute
Groaned at 23 Times in 12 Posts
I installed the PTP fuel internals and got noticably higher PSI's. I had fuel cutouts-No more, and the throttle is MUCH smoother.
He also has a PCV install to help cut out smoking and help with oil pressure. I have both and both I am VERY happy with.
skipunk11 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f303/why-different-designs-pumps-427/
Knock Knock... - COBB Forums This thread Refback 09-08-2008 06:17 AM
Knock Knock... - COBB Forums This thread Refback 09-07-2008 09:02 PM
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 03-29-2008 01:25 AM
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 03-26-2008 10:08 AM
Are your pumps currently available? Death-From-A-Mile Mazdaspeed3/6 General Discussion 20 08-16-2013 08:05 AM
Change your C30's character with official swappable designs Haltech Automotive News 0 04-03-2008 11:40 AM
Elemental Designs 11Kv.2 10" sub KaiserSoze MazdaSpeed 3/6 - Car Audio & Electronics 0 03-30-2008 05:03 PM
Pumps are available for now - and for awhile! mrlilguy157 Mazdaspeed3/6 General Discussion 29 03-25-2008 10:36 PM
Page generated in 0.43749 seconds with 29 queries
