 Old 05-14-2014, 02:43 PM   #1
sriser66's Avatar
Posts: 380   (View Stats)
sriser66 is the leader of the worldsriser66 is the leader of the worldsriser66 is the leader of the worldsriser66 is the leader of the worldsriser66 is the leader of the worldsriser66 is the leader of the worldsriser66 is the leader of the worldsriser66 is the leader of the worldsriser66 is the leader of the worldsriser66 is the leader of the worldsriser66 is the leader of the world
Default Wierd Fuel Pressure Problem/ Rich at Idle
First of all, this post is going to be long and it does have logs to prove what I have seen 2 times now in the last month. I am beginning to think this car hates me. Here goes. After I got gas 2 times now, the car is extremely rich and dumping gas into the engine till the point of almost stalling out.
I have done a compression and leakdown test, both are good. The compression test came back at 170 across the board. I have replaced the upper o2 sensor in within the last 6 months, the purge valve and checked for boost and exhaust leaks.
I am currently being tuned by atvfreek, but I do not want to burden him with finding the answer. He has helped quite a bit on this journey and I know he is a busy man. When I get up to speed, the AFR stays at about 14.7, but if I let off the gas it goes right back to 9.6 or lower. I have to add that it only happens for about 5 miles and only when I get gas. Other times I start the car it does just fine. It is driving me crazy.
I have searched the forums and online and can not find anything remotely related to the issue. All the issues I see are not at all related. Here are the logs and I appreciate any suggestions. Here is a list of mods: GTX3071R, Turbosmart BPV, Grimmspeed EBCS, Autotech internals, CP-e TMIC, Ebay downpipe, Matt Damond Catch Can, NGK LTR7IX-11, HTP 3" Intake and TIP, Cobb AP, AWR RMM, Devils own Stage 1 70/30 Meth, EGR delete.
2006 MS6- GTX3071R, Freek Tuned, HKS BOV, Grimmspeed EBCS, Autotech internals, CP-e TMIC, Ebay downpipe, Matt Damond Catch Can, Densos ITV-22, HTP 3" Intake and TIP, Cobb AP v3, EGR delete, Throttle body coolant bypass, JBR 80 Duro RMM, JBR 80 Duro PMM, Devils own Stage 2 70/30 Meth, CP-e Safe Seals, Koni Yellows.
13.6 1/4 time on self tuned GTX3071r, still tuning in process.
383hp on dynojet with 198,000 miles on original clutch and original engine!!!!!!!!
Freektune for the win!!
sriser66 is offline   Reply With Quote
 Old 05-14-2014, 03:00 PM   #2
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Groans: 52
leaky injector, this is my first guess
 Old 05-14-2014, 04:05 PM   #3
mituc's Avatar
Posts: 3,507   (View Stats)
Groans: 111
These rich at idle threads keep popping up lately. I wonder wtf is going on. However, som of the guys with this problem managed to figure it out:
(SOLVED!!!!!!!!!)help me solve this AFR at idle!!
But this doesn't necessarily mean you have the same root problem, only similar symptoms. In that thread have been asked questions and advice given about what to check and look for. Take a look.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 05-14-2014, 06:01 PM   #4
sriser66's Avatar
Thanks for the info. I will check it out and I never thought of the injectors getting stuck. It just seems so random that it only happens when I get gas.
Sent from my SCH-I535 using Tapatalk
 Old 05-14-2014, 06:13 PM   #5
Enki's Avatar
Posts: 7,539   (View Stats)
Groans: 189
Protip: Don't top off the tank. Pull your evap line and see if it reeks of fuel; that's probably your problem.
 Old 05-16-2014, 09:52 AM   #6
Tubescorcher's Avatar
Posts: 52   (View Stats)
Tubescorcher is the leader of the worldTubescorcher is the leader of the worldTubescorcher is the leader of the worldTubescorcher is the leader of the worldTubescorcher is the leader of the worldTubescorcher is the leader of the worldTubescorcher is the leader of the worldTubescorcher is the leader of the worldTubescorcher is the leader of the worldTubescorcher is the leader of the worldTubescorcher is the leader of the world
I had same thing happen twice in the last two fill ups!! I didn't log it. After gassing car. I go to start it dies. When it does start AFR's go from normal 14.5 down to 9. Rough idol. Didn't throw a CEL. After letting car run 30 seconds then stopping and restarting it goes back to normal. Never happened before.
Tubescorcher is offline   Reply With Quote
 Old 05-17-2014, 03:25 PM   #7
sriser66's Avatar
I got gas again yesterday and did not top off the tank and it did the same thing. It is really weird. I also checked my exhaust bolts and we are good there.
Problem after problem: Running rich & Fuel cuts wherewuat 2010 MS3 - Troubleshoot/Diagnostics 30 01-30-2014 02:13 PM
Low Idle & WOT Fuel Pressure Fix khopwood77 2010 MS3 - Troubleshoot/Diagnostics 3 06-18-2013 01:45 PM
Low fuel pressure at idle event MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 53 07-02-2012 01:03 AM
60psi fuel pressure at idle! CCC MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 31 10-04-2011 06:28 AM
Low Fuel Pressure but Rich A/F Ratio akbrazil 2010 MS3 - ECU Computer Tuning 16 04-26-2011 06:04 AM
Page generated in 0.28547 seconds with 25 queries
