 Old 08-11-2008, 12:14 AM   #1
Haltech's Personal Bitch
PDXImportRacer's Avatar
Posts: 275   (View Stats)
PDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond reputePDXImportRacer has a reputation beyond repute
Default 15x10 w/ -38 offset Will it clear the brakes?
I am looking at a set of wheels messuring 15x10. The have a negitive offset of 38 <-38>. The tire calc says this is 59mm further away from the strut. Is this enough to get away from the caliper?
PDXImportRacer is offline   Reply With Quote
 Old 08-11-2008, 06:04 AM   #2
Lymerock's Avatar
Posts: 1,436   (View Stats)
Im not sure the 15" part of the equation will clear the front brakes. 16" steelies barely fit.
as far as the 38 offset part, stock is 52.5, so the center of your rim will effectively be 14.5 mm further out than stock.
depending on how tall of a tire you plan to run, those might require fender mods, unless you are going -3" in diameter or something drastic like that
 Old 08-11-2008, 06:07 AM   #3
MZRDISI4
Lurkers
MZRDISI4's Avatar
Posts: n/a
negative offset won't work
 Old 08-11-2008, 06:29 AM   #4
Lymerock's Avatar
cant say wont work, unless you mean it wont work with stock fenders.
Im sure we could fit 275's or larger on the car if someone wanted to do some custom fender flare work.
stock wheels: Size,Bolt Pattern,Offset,Bore Jasnall MazdaSpeed 3/6 - Wheels & Tires 20 06-10-2014 12:53 PM
Agreement reached for FCC to clear XM-Sirius deal Haltech Automotive News 0 07-24-2008 08:30 AM
18x8.5 50mm offset...will they fit? Yahdy Ras MazdaSpeed 3/6 - Wheels & Tires 12 07-21-2008 04:35 PM
Clear Bra FastAttack MazdaSpeed 3/6 - Appearance 21 06-10-2008 10:47 AM
Offset high gas prices by turning your car into billboard Haltech Automotive News 0 06-07-2008 12:30 PM
Page generated in 0.24343 seconds with 21 queries
