Like Tree2Likes
  • 1 Post By Sid3wayS
  • 1 Post By WetzMS3
 Old 10-28-2013, 09:59 AM   #1
Mavrik92's Avatar
Posts: 4   (View Stats)
Mavrik92 is an unknown quantity at this point
Default 18 x 8.5 + 30 offset.
I just purchased a set of XXR 522's that are 18 x 8.5 + 30 offset, tires size is 225/40/18 I'm looking to install them with BC Coilovers. I understand for Gen 1 it will work if I get my fenders rolled in which I plan on doing. Should I be aware of anything else that I may need to do for these wheels to not cause me problems in the future if anyone can help answer my questions it would be greatly appreciated.
Mavrik92 is offline   Reply With Quote
 Old 10-28-2013, 10:01 AM   #2
killer-ms3's Avatar
Posts: 1,187   (View Stats)
killer-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the world
Groans: 32
you sure they arent 8.75?
Nator FL, bitch
GTX3071 EWG w/ Supporting Mods and some Mef
Tuned by THE FREEK
killer-ms3 is offline   Reply With Quote
 Old 10-28-2013, 10:03 AM   #3
Mavrik92's Avatar
They're 8.5, checked the backside of the rim.
 Old 10-28-2013, 10:04 AM   #4
speed_freak91's Avatar
Posts: 1,189   (View Stats)
speed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the world
Groans: 34
Best bet would be to search threads through the wheels section and look at other peoples threads with same size wheels. You can also look at most peoples sig's that may have your setup. Its what I did to figure out my setup.
speed_freak91 is offline   Reply With Quote
 Old 10-28-2013, 10:11 AM   #5
Spectrix's Avatar
Posts: 323   (View Stats)
Spectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the world
Groaned at 7 Times in 3 Posts
That is a pretty aggressive fitment.
There are a a couple of extra factors such as your desired ride height and the camber settings once you get an alignment. I suspect you'll experience scrubbing everywhere, though the rear fender is going to be the worst culprit.
2008 Gen1 MS3
Cobb AP ~ Autotech HPFP Internals ~ HTP 3" Intake ~ Custom Testpipe ~ Cobb RSB ~ Sticky Tires.
Self tuned on E85
Spectrix is offline   Reply With Quote
The Following User Says Thank You to Spectrix For This Useful Post:
Vansquish (10-28-2013)
 Old 10-28-2013, 10:20 AM   #6
Mavrik92's Avatar
I've been looking and haven't had much luck very few people running this offset and size.
Looking to cover the wheels gap if I can. I want a clean look not a crazy aggressive one. I also dont want to put camber plates in if possible. But if I roll the fenders do you think I should be good to go?
Last edited by Mavrik92; 10-28-2013 at 10:20 AM. Reason: MSF Database - Automerged Doublepost
 Old 10-28-2013, 10:23 AM   #7
dale_gribble's Avatar
Posts: 4,720   (View Stats)
If you don't have adjustable rear camber arms, you will need them. Since you are sticking with the 225s, that buys a lot of room vs. 235s or 245s.
+30 is pretty damn aggressive. However, fully rolled rear fenders and -1.5 to -2.0 of rear camber should fit that setup. Fronts should be ok. You will definitely get some poke with that setup which is meh and you aren't going bigger tire, so no performance benefit. Your rims will be very vulnerable to curbs/potholes/etc., but I am guessing you already know that.
MINI H1 6.0 - CAR LED TAILS
rfinkle2 (11-21-2013)
 Old 10-28-2013, 10:29 AM   #8
btstarcher's Avatar
Posts: 4,851   (View Stats)
Groans: 112
Because stance yo.
Sell them and get something that fits. Sure, you can MAKE these fit, but really, do you want to?
SnailTune in progress
The Following 3 Users Say Thank You to btstarcher For This Useful Post:
chaser27 (10-28-2013), Jap11g (01-15-2014), ms6mil (02-16-2014)
 Old 10-28-2013, 10:34 AM   #9
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
IMO, you are going to have to pull the fenders big time on the gen1 or run some camber that is definitely form > function.
I have 18x8.5 +38's on my gen2 and the fenders are rolled flat. The gen2 is said to have a lot more room than a gen1 and a 30 offset is going to need a decent pull and major trimming of the wheel well linings etc.
btstarcher (10-28-2013)
 Old 10-28-2013, 10:36 AM   #10
Mavrik92's Avatar
I got a great deal on them and couldn't pass them up but if I have to buy camber plates. Its not so much stance, it's because I have a MZ3 and not a speed unfortunately. Do you think I could run them without plates and won't into problems if I don't go as low as intended?
Thank you everybody for the advice and help!
Last edited by Mavrik92; 10-28-2013 at 10:36 AM. Reason: MSF Database - Automerged Doublepost
 Old 10-28-2013, 12:58 PM   #11
rfinkle2's Avatar
Groans: 298
You would be better off on a different forum for that info. I don't mean anything by that, but I don't know of too many gen1 guys who are running very aggressive fitments.
You could get a lot more feedback and tips from another Mazda 3 forum.
The Following 3 Users Say Thank You to rfinkle2 For This Useful Post:
CWP_MS3 (10-28-2013), dale_gribble (10-28-2013), Quigs (10-28-2013)
 Old 10-28-2013, 01:09 PM   #12
killer-ms3's Avatar
Groans: 32
@Sid3wayS; is running a +30 on a 18x8.5 on a gen2
I wouldnt suggest it on a gen1 tbh
Nator FL, bitch
Tuned by THE FREEK
The Following User Says Thank You to killer-ms3 For This Useful Post:
rfinkle2 (10-28-2013)
 Old 10-28-2013, 01:12 PM   #13
Tyhackman15's Avatar
Posts: 1,742   (View Stats)
Tyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the world
I running 17x8 with 32 offset with 235s on a gen1 and at stock height I needed a roll and a touch of camber to clear. And it sits perfectly flush with the fender. I wouldnt go wider or more aggressive IMO
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
SOLD 2008 MS3 17x8 Evo 9's, 235 v12
1995 Miata 1.8L w/ FMII GT2560R @11psi, FM stage 2 clutch/flywheel, FM Frame rail braces, FM high capacity radiator/fans, RB Sway bars, Racing beat exhaust, Fat cat Coilovers, Jongbloed 15x9, Wilwood 4 wheel BBK, Rollbar, Hardtop, TDR Racing seat
2001 Saab 9-3 Viggen 2.3T Stage 3+ bro, SRI, 3" DP, ETS FMIC, 17x8 BBS RK2's, Full chassis bracing / sway bars, Forge BPV, Winter/DD
Tyhackman15 is offline   Reply With Quote
 Old 10-28-2013, 01:18 PM   #14
Stretched 225s are a lot more forgiving than 235s for fitment. Seems to be what a lot of the herrafrush guys do. When there is no sidewall because the sidewall is like at a 45 degree angle due to stretch, more shit will fit. Appropriate tires with a more straight up/down sidewall are a lot less forgiving for aggressive fitment wheels.
Though I ask myself, MZ3, so why am I doing this? OP, you are on the wrong forum for aggressive fitment.
Tyhackman15 (10-28-2013)
 Old 10-28-2013, 01:22 PM   #15
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 10-28-2013, 01:23 PM   #16
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
Roll and pull at minimum, camber would help a lot. the 225s puts your tire edge better than mine when I had 245s on +38s but I still needed a roll and pull to clear. On stock springs rubbing was inevitable, and constant over any kind of bump or dip. Stock camber arms.
Good luck.
Blue Pu.
 Old 10-28-2013, 01:29 PM   #17
Groans: 34
inb4baseballbatrolledfenders
 Old 10-28-2013, 01:29 PM   #18
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
18x9 +30 with a fat 235 but that aint fitting on no gen 1. Atleast not for a daily. MAYBE with some stretched ass tires but meh.
Your set up like Rob said Will need a major roll and pull. And dont be expecting to be hellaflush either unless you plan on cambering the fuck out of the rear. The front you shouldnt have an issue
oakley990099 likes this.
TEAM LUXURY
Sid3wayS is offline   Reply With Quote
The Following User Says Thank You to Sid3wayS For This Useful Post:
 Old 10-28-2013, 01:33 PM   #19
killer-ms3's Avatar
Groans: 32
You're always giving yourself that extra half inch....
@Sid3wayS;
Nator FL, bitch
Tuned by THE FREEK
Sid3wayS (10-28-2013)
 Old 10-28-2013, 01:43 PM   #20
btstarcher's Avatar
Groans: 112
Is the NA Mazda 3 the same as the MS3 when it comes to wheel fitment?
 Old 10-28-2013, 01:57 PM   #21
7th Initial's Avatar
Posts: 316   (View Stats)
7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world7th Initial is the leader of the world
Groaned at 20 Times in 4 Posts
Like everyone else has said a roll is deffenetly needed. You might need to shave the rear bumper depending on how low your really wanting to go.
90 Miata Shift extender // Megan EZ Streets // M2 exhaust // Racingbeat intake // Turn Signal Intakes // Autokonexion GT Panels // Autokonexion Aero Fronts // Rota Kyusha 15x9 -15 205/50/15 // Sickspeed lugs // Custom Diffuser // GV Lip
08 Mica MS3 SURE TIP // SURE Intake // Custom Diffuser // Shifter Extender // AUTOTECH HFFP // APV3 // COBB Knob // YellowSpeed Coils // 17x9 RPF1s
08 True Red MS3 SOLD COBB SRI // CS-CA Box // RaceLand Coils // BC Racing BR Coils // Varrasteon ES221 // 5ZIGEN lugs // SURE RMM // TurboSmart Duelport // SU TestPipe // CNT CB // JRB SSP // JRB Knob // CXRacing FMIC // SUPER Tones // 2Nine Rear Diffuser // Nextmod lip // STI V-limited // Prosport BG
7th Initial is offline   Reply With Quote
 Old 10-28-2013, 02:49 PM   #22
Quigs's Avatar
Posts: 1,152   (View Stats)
Quigs is the leader of the worldQuigs is the leader of the worldQuigs is the leader of the worldQuigs is the leader of the worldQuigs is the leader of the worldQuigs is the leader of the worldQuigs is the leader of the worldQuigs is the leader of the worldQuigs is the leader of the worldQuigs is the leader of the worldQuigs is the leader of the world
Yes, you could have passed them up. It's actually real easy:
Them: "Hey man, I got these mad tight knock-off JDM ballerness rims, yo. You should totally rock this shit on your whip."
You: "No."
I would never decide on a wheel set up (especially one that doesn't fit well without a lot of work and no performance gain) just because it was a "great deal." Just my opinion. But, it does sound like you did it without much research, which also makes the decision a little silly.
EDIT: Nevermind, I missed the MZ3 part...I guess sillyness is all you can do since there's no performance there anyway. In that case: go for it, make it look good, and post up the end result!
2009 Mazdaspeed3
Bolted, Mounted, Hypnotic Tuned
2000 Mazda Miata MX-5
NASA TTE build ongoing
Quigs is offline   Reply With Quote
The Following 2 Users Say Thank You to Quigs For This Useful Post:
Jap11g (01-15-2014), MazdaBoy2.3 (11-19-2013)
 Old 10-28-2013, 03:00 PM   #23
ArmanRus's Avatar
Posts: 1,566   (View Stats)
ArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the world
IIRC when I still had my NA 3 from reading around the rears are the same but the MS3 fronts are roomier. If that's the case he will have problems with the fronts too.
ArmanRus is offline   Reply With Quote
The Following 2 Users Say Thank You to ArmanRus For This Useful Post:
btstarcher (10-28-2013), rfinkle2 (10-28-2013)
 Old 11-19-2013, 11:53 AM   #24
SpecialK's Avatar
Posts: 830   (View Stats)
SpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the world
Will 18x9.75 with a 20 offset work?
Sent from my SCH-I545 using Tapatalk
2006 Mazdaspeed 6 Zoom Zoom Boom Feb/2014 - fixed 3/30/2014
Motor:
2012 Block / V2 AP / Autotech HPFP / HTP 3" intake / AEM dryflow filter / Fidanza Flywheel / NGK 6510 Step Colder Plugs / TurboSmart BPV / Catless M2 DP / JBR SSP / CPE RMM
Suspension:
Poly SwayBar Bushings / CP-e Rear Diff Mount / BC Coilovers / 245/40/18 on 18x8" RX8 Wheels
Visual:
25% Tint On All Windows / 25% Tint Side Markers / Front Grill Plasti-Dipped Black / Stockers Plasti-Dipped Black / Black Mad M on Trunk / De-Badged / Heavy Shift Knob
Fluids:
Motocraft gold in gearbox / Redline in TC and diff / Oil - Rotella T6 /
SpecialK is offline   Reply With Quote
The Following 2 Users Say NO Thank You to SpecialK For This Un-useful Post:
MazdaBoy2.3 (11-19-2013), Status Update (11-19-2013)
 Old 11-19-2013, 12:06 PM   #25
Ya, 18x10s with +20 should work. If you stretch 185/40R18s and sawzall your fenders those will fit. In for pics.
The Following 4 Users Say Thank You to dale_gribble For This Useful Post:
btstarcher (12-28-2013), CWP_MS3 (11-19-2013), Jap11g (01-15-2014), magicka (11-20-2013)
 Old 11-19-2013, 12:10 PM   #26
SpecialK's Avatar
Lol I'm looking to trade old rims for new. I got some 18x8.5 with 5x100 from my old car.
Really? What suspension mods u have?
Motor:
Suspension:
Visual:
Fluids:
Last edited by SpecialK; 11-19-2013 at 12:10 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-19-2013, 12:11 PM   #27
ranger2183's Avatar
Posts: 122   (View Stats)
ranger2183 is the leader of the worldranger2183 is the leader of the worldranger2183 is the leader of the worldranger2183 is the leader of the worldranger2183 is the leader of the worldranger2183 is the leader of the worldranger2183 is the leader of the worldranger2183 is the leader of the worldranger2183 is the leader of the worldranger2183 is the leader of the worldranger2183 is the leader of the world
nah he'll be fine, I'm running 20x11 with +10, I just bought tires made out of sandpaper so it'll eventually custom form the fenders
Corksport: OCC, SSP, counterweight, shifter bushings, SRI, TIP, Catback, DP, RP, TM insert, lowering springs
CXRacing: FMIC Cobb: Accessport
Autotech: HPFP Internals CP-e: RMM
TurboSmart: BPV Denso: 1 step colder plugs
Prosport: Evo Boost w/ VentPod
Rfinkle E85 Tuned 33%
ranger2183 is offline   Reply With Quote
The Following 2 Users Say Thank You to ranger2183 For This Useful Post:
 Old 11-19-2013, 12:13 PM   #28
SpecialK's Avatar
What is the widest tire I can stuff in there with what offset with no fender rolling and no rubbing?
Motor:
Suspension:
Visual:
Fluids:
 Old 11-19-2013, 12:21 PM   #29
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
MazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the world
Groans: 51
Groaned at 29 Times in 22 Posts
Yes. Yes it will.
Wink.
I used to go zoom zoom with my speed....
Now i drive a slow stockish Focus ST...
MazdaBoy2.3 is offline   Reply With Quote
The Following User Says Thank You to MazdaBoy2.3 For This Useful Post:
ranger2183 (11-19-2013)
 Old 11-19-2013, 12:25 PM   #30
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
Go here please:
Mazdas247
Quigs likes this.
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
Quigs (11-19-2013)
 Old 12-28-2013, 03:25 PM   #31
Jap11g's Avatar
Posts: 287   (View Stats)
Jap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond repute
Groaned at 7 Times in 5 Posts
Ultimate will it fit thread. Read it.
JP
Jap11g is offline   Reply With Quote
The Following User Says Thank You to Jap11g For This Useful Post:
:: Gusto :: (02-15-2014)
 Old 02-16-2014, 05:28 AM   #32
bunta's Avatar
Posts: 42   (View Stats)
bunta has a spectacular aura aboutbunta has a spectacular aura about
From what I remember reading the mazdaspeed3 have wider fenders in the front compared to the regular 3. The rears I'm not sure of.
bunta is offline   Reply With Quote
Question about offset on the MS6 Caligula MazdaSpeed 3/6 - Wheels & Tires 24 04-26-2013 06:14 PM
+35 offset obijack Wheels & Tires - BLACK 28 01-16-2013 04:56 AM
Offset Q? dadon1985 2010 MS3 - Wheels & Tires 2 11-14-2010 10:27 PM
Gen 2 offset mzdaspeed3 2010 MS3 - Wheels & Tires 5 02-12-2010 10:59 PM
will an 38 offset be ok? SLOMS3 MazdaSpeed 3/6 - Wheels & Tires 11 10-10-2008 12:57 PM
Page generated in 0.50190 seconds with 39 queries
