-   -   225 or 235 (http://www.mazdaspeedforums.org/forum/f319/225-235-a-72139/)
redMS308 02-11-2011 11:22 AM
225 or 235
I'm running Enkei EKM3 18"x7.5" with an offset of 45mm wheels and dropped on Eibach springs. Looking at replacing the tires with Hankook V12s, can i run a 235/40 tire without rubbing issues or should I stick with a 225/40"?
08.5MS3 02-11-2011 11:32 AM
I'm not too sure, but I'm almost certain you'll need a wider wheel to accomodate a 235 tire.
As for the 225, you should have an aspect ratio of 45 to keep the speedo calibrated with less error.
BReif61 02-12-2011 03:54 PM
08.5MS3,
I just bought 7.5" wide wheels and they came with 235 tires. They aren't stretched, but rather uncomfortably flush with the lip of the wheel.
08.5MS3 02-12-2011 04:10 PM
Good to know.
I know some people need to get their fender rolled when they are going wider...I'm not sure their offset or tire size, but I have read some. Keep that in mind OP.
nyghtryder 02-12-2011 04:23 PM
235's will fit a 7.5" rim just fine. Im running a 225/45 on rx8's with no rubbing, however im not lowered and expect to have to do a very minor roll in the rear only.
if you have the eibach kit thats a 2.5" drop i think its the pro kit youll have to do a slight roll.
RacerX78 02-12-2011 05:09 PM
235's should be just fine for a 7.5" or 8" wheel. You drop shouldn't affect clearance if you on the Eibach prokit's for the MS3. The only time you should have a issue is if your sitting on the MZ3 Sportline kit.
jax ms3gt 02-12-2011 05:22 PM
def not a 2.5" drop. They claim .8 front and .7 rear. I would say at the VERY most an inch in the front, .8 rear.
I had 225/40 and just went to 225/45 on stock rims so I am pretty sure with op offset you can def get by with 225/45 or 235/40.
redMS308 02-12-2011 06:43 PM
Thanks guys for all the feedback, the eibach springs I had are for the ms3 with the aprox. .8 and .7 drop. As of now I'm leaning towards the 235/40, spring can't come quick enough!
jax ms3gt 02-12-2011 07:26 PM
yeah eibach doesn't even have a 2.5" drop. At all.
Tire compound, tire itself is much more important than an extra centimeter of contact also..
Raider 02-12-2011 07:47 PM
Expect the need to roll the fenders.
RacerX78 02-13-2011 09:25 AM
I doubt he'll have to unless he has rims with crazy offset. the prokits minor drop and only slight extra width shouldn't cause a problem unless he hauling stuff in his trunk.
goob_os101 02-14-2011 12:59 PM
Originally Posted by BReif61 (Post 728031)
08.5MS3,
can you post some pics? I am about to buy some wheels that are 7.5" wide and I want to see if I should run 225 or 235.
Design 02-14-2011 01:03 PM
I responded to you on 247. Hankook doesn't recommend 235's with anything less than an 8" wheel. They are also known for a pretty wide section width. So with a 45mm offset, you're going to need to roll your rear fenders at least.
redMS308 02-14-2011 01:51 PM
I ended up ordering the 225/40 sized tires today, just don't want to have to get the fenders rolled. Thanks everyone for the helpful advice!
08.5MS3 02-14-2011 03:27 PM
Your speedo will be off more so than if you went with a 225/45.
Tapatalk
Design 02-14-2011 03:36 PM
There's very little clearance stock with that size (especially V12's). A drop + another 7.5mm will just exasperate the issue (IMO).
BReif61 02-14-2011 06:16 PM
I only have the flashy "Let's show off my new wheels on facebook" pictures on this computer. I can take some better pictures of the tires tomorrow. But the tire basically comes meets the wheel perfectly flush.
nyghtryder 02-18-2011 12:59 AM
its the mz3 sportline kit. alot of people ran them a little while back. since the ms3 is already an inch lower than a reg 3 it slammed the hell out of it.
Jon2000 02-27-2011 05:54 PM
I just bought Enkei EKM3's in hyper silver with Hankook V12's as well ...I considered the 235/40/18 option but chickened out and got 215/45/18. I didn't want ANY probs with the rear fenders.
nyghtryder 03-19-2011 12:48 PM
you lowered? you could have easily ran a 225/45/18 on stock suspension. ive had mine on for about 5 months with no issues.
Jon2000 03-20-2011 01:21 PM
^ I'm lowered on Cobb springs ...probably could have done the 225/45/18 but I'm OK with the stock size.
jester1341 03-25-2011 08:27 AM
I'm at stock ride height and on stock wheels, a friend has a 'new' set of 235/40R18s for cheap....... Will they fit without rubbing??
John
Page generated in 0.18280 seconds with 11 queries
