235/40/18 What's up fellow speeders? I just purchased a set of rota tarmac 3! For my tr speed 3 I lowered on h&r springs will I have rubbing issues with 235/40/18 toyo proxes? Any help u guys can give thanks |
I had 235/40/18's on my 18x7.5 et42 (iirc). didnt rub. I had cobb springs still being used on subparpunk03's car... and hes on kw coilovers dropped pretty low... |
Re: 235/40/18 Quote:
What is ur off set? I run 8.5 OZs 45 offset and rub in the back. No lowering Edit: run in the back on the outside..fuck, fender roll here I come! |
235/40/18 T1Rs + 18x8@50mm was ok with stock shocks + cobb springs or BC coils. unfortunately, as soon as i added the camber links to dial in the negative camber in the rear, it started rubbing. basically, unless you mess with rear camber, 235s will be fine with a reasonable offset. |
roll the rear fenders /thread |
So basically running RX8 rims (18x8) w/ a 235/40/18 will work. Hrm I konw that the offset is 50 already, I was thinking to throw on a 10-15mm spacer on it to get a flush look. I think I shouldnt have problem even with a full load AND camber correction because of the extra spacing...right? Or am I doing it wrong? lol |
I guess its back to 225 or 215 for me :( Booruns... OR fuck going with hella flush... |
I run 18x8.5" +45mm 235/40/18 Nitto NT555...didn't start to rub in the beginning but as I worn down my shocks over last season, it started to rub more and more and I will be getting my fenders rolled regardless of which suspension I end up with... |
any pics of your car headon (to see how close you are with flushness) just wanna get a gauge of how close you are with that tiresize and offset |
Wheel offset refers to the distance between the centerline of the wheel and the vertical plane of the wheel's hub-mounting surface (with positive values denoting a hub-mounting surface that is closer to the outside edge of the wheel, and negative values denoting a hub-mounting surface that is closer to the inside edge of the wheel). Backspacing is the distance between the vertical plane of the wheel's hub-mounting surface and the inside edge of the wheel. What you seem to be describing above is neither. You basically described "wheel width/2." ;) |
^^sorry....you are correct...I got my measurements mixed up... |
What kind of clearance did you have on the inside with the 18x8.5 +45 and 235s? |
offset is 48 |
I guess with a 48 offset you are 3mm better off than I. In my case that would prob be enough to clear but other guys don't have any trouble at all running 235s so IDK. I'm trying to find a good roller around here but haven't found one that bolts up to the hub yet and I don't trust myself with the other kind. |
i ordered the wheels i should have them in a week from monday so we will see i will post pics and comments as soon as i get them mounted |
| All times are GMT -7. The time now is 09:07 AM. |
