 Old 08-11-2017, 02:30 PM   #1
evanreynolds1116's Avatar
Posts: 54   (View Stats)
evanreynolds1116 is just really niceevanreynolds1116 is just really niceevanreynolds1116 is just really niceevanreynolds1116 is just really nice
Default 235/40 Help
My 07 stock tires are well past the end of their life. Looking at getting 235/40's and putting 18x8 Konig Runlite's on them (+45 offset). I've been looking through the forums but I can't get a good answer on if I will rub or not with those tires. I've never bought tires that weren't stock size so this is all new to me. My suspension is stock right now but I am looking at getting some Eibach springs and wondering if that'll still be fine with those tires.
Currently looking at Pirelli P Zero a/s Plus... let me know if you have any other suggestions around that price range ($152.10/ea)
Also anyone have any previous experience with those Konig wheels?
2007 MazdaSpeed 3
Cobb AP v3 | Corksport HPFP | Cobb TIP | Corksport CBE | Corksport DP w/ High Flow Cat | cp-e Stage 2 RMM | MAZDASPEED CAI |
evanreynolds1116 is offline   Reply With Quote
 Old 08-11-2017, 02:55 PM   #2
Shwaykid's Avatar
Posts: 646   (View Stats)
Shwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the worldShwaykid is the leader of the world
I run 235/45/17 +45 which are the same overall diameter that you're looking to get. I needed to roll the rear fenders after I got lowering springs.
Pretty sure you'll be fine if you stick to stock suspension. Might rub a bit if you load the back end up with stuff/passengers.
2008 Mazdaspeed3 GT
JBR TRU 3.5 Aluminum WP // Corksport TBE // JBR OCC Stage 2 // AP v3 (Tweaked [by me] E40 Tune) // Autotech Internals // Stratified EBCS // TWM Full Replacement w/ Type R Knob // CP-e Stage 2 RMM // JBR/Damond Full EGR Delete // Synchronic DV // NGK 6510s // FMIC [TR8 w/ JBR Pipes] // CorkSport Adjustable Struts/Lowering Springs // Progress RSB
Jet Black Wax (06/24/2017)
Better compression than Silaramic (02/20/2016)
Shwaykid is offline   Reply With Quote
 Old 08-12-2017, 08:34 PM   #3
cyber-ms3's Avatar
Posts: 197   (View Stats)
cyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond repute
Groaned at 6 Times in 2 Posts
not all 235 40 tires are the same width. I had 235/40/18 Super sports on Evo X wheels which were pretty wide and they rubbed slightly even with a roll and slight pull on stock springs. Now I'm on HTR ZIII's and there is less rubbing. Section width and tread width need to be compared also.
cyber-ms3 is offline   Reply With Quote
Page generated in 0.24617 seconds with 21 queries
