How do you like the effect on gearing with the 265's? |
9 Attachment(s) Found these on another Mazda site. Can't remember which one but they are 18x9.5 et42 wrapped in 275/35 Only on the right side of the car that's why its leaning. Attachment 61530Attachment 61531Attachment 61532Attachment 61533Attachment 61534Attachment 61535Attachment 61536Attachment 61537Attachment 61538 |
I run 245/40r17's on 17x8's. Wheels are +50 but I run 5MM spacers. Suspension is Koni Yellow with Swift Spec-r's. Rear fenders are currently rolled and I don't have any issues. |
245/35r18 s-Drives on a 18x9.5 +30 offset rim. H&R Springs, and a JBR RSB on stiffest setting. Rear Fenders Rolled thanks to @rgz :smileysex5: |
Change of setup... I'm now lowered on eibach springs with koni yellows (one full turn stiff in the back, a little more than 1 turn in front). Rears were pulled more, cracking the paint on the drivers side, and I still rub, even slightly more than stock. Rear sway is even more necessary now but that should be on tomorrow. Fronts rub under hard turning. Overall I'm a little disappointed with the wheels only because of the rubbing. I'm considering dropping to 235/40 tires next time around, or just pulling the shit out of the fenders and touching up the paint once that's all done. I will be racing this car so I want to keep the wide tires...we'll see where I go with it. It's also my daily so ride comfort is very important. Pain in the ass wheels....Anyone want some evo's? |
Yellows plus eibach sounds like some serious lows, and even more so I'm sure those Eibachs drop alot in turns. |
If stock springs solve the issue and youre having troubles finding cobbs im loving my corksports and the drop is similar in not being aggressive. Good luck homie |
I was actually going to ask you about the actual drop with the corksports was. The supposed drop is way too aggressive for me, but even the cobbs are rated at 1" all around but only go about .25" in the rear from what I hear. The problem with the eibachs, I think, is not necessarily the drop but the softness. I get the feeling that they're stiffer than stockers, but not by very much. Overall it's just frustrating, but not impossible to figure out. The big thing is that I don't want to spend much more money on this issue. Once I'm employed I'm thinking of selling the evos and picking up a set of milligrams for the greater offset, but I really dont' want to go through the trouble for an extra 7mm inset. Hopefully the stock springs will hold me over until I know exactly what I'm going to do. On the plus side though, the car currently looks fantastic lowered. |
@helmetfail I should have quoted or mentioned you earlier. What's your actual drop with the CS springs? Is it the full 1"+ as advertised? |
The spring rates between these and Eibachs are probably a substantial difference, they are a rough ride but quite firm indeed. I would suggest them to a friend but not a friend that totes around kids, get my drift? Keep in mind im on bilsteins |
I run 17x9 +45 RPF01s with 245/40R17 AD08s. Just had to run a 5mm spacer up front and have 5mm of room between tyre and strut! Planning on getting 255s next once the AD08s have gone to shit. :) |
Final update for now... Got my JBR rear sway in and put it on today. Cornering is very tight now and control seems better overall. I also put my OEM springs back in, so it's time to get into it... I pulled the eibachs from the rear and compared them to the OEMs out of the car. The length is nearly identical, but since teh drop is so much from the eibachs it means that they're quite a bit softer than stock. This is a horrible property for a drop spring and was the main cause of all the rubbing. With the stock springs back in the rear the ride is better with the new shocks than it was with konis and eibachs, the car is completely leveled and looks amazing now (eibachs still in front) and the rubbing over a few bumps that used to cause me problems is gone. I'm still considering cobbs at some point but I"m tired of spending money on this and I'm very, very happy with the ride and handling overall. If I start to auto-x I'll upgrade the springs definitely but for now I'm content. Finally. |
| All times are GMT -7. The time now is 09:42 AM. |
