 Old 05-17-2012, 09:46 AM   #41
goob_os101's Avatar
Posts: 697   (View Stats)
goob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the world
Groaned at 10 Times in 7 Posts
How do you like the effect on gearing with the 265's?
goob_os101 is offline   Reply With Quote
 Old 05-21-2012, 11:22 AM   #42
BobtailedSnail's Avatar
Posts: 1,375   (View Stats)
BobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the world
Found these on another Mazda site. Can't remember which one but they are 18x9.5 et42 wrapped in 275/35 Only on the right side of the car that's why its leaning.
ImageUploadedByTapatalk1337624324.504851.jpgImageUploadedByTapatalk1337624341.311400.jpgImageUploadedByTapatalk1337624361.762623.jpgImageUploadedByTapatalk1337624387.612515.jpgImageUploadedByTapatalk1337624405.280082.jpgImageUploadedByTapatalk1337624469.478594.jpgImageUploadedByTapatalk1337624492.648440.jpgImageUploadedByTapatalk1337624509.228619.jpgImageUploadedByTapatalk1337624528.314298.jpg
2006 Mazdaspeed 6 GT-unDISI swap in progress
1969 Nova-540BBC-S400's-TH400-sitting on 29.5x10.5
Skreets be calling...
BobtailedSnail is offline   Reply With Quote
 Old 05-21-2012, 11:52 AM   #43
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
I run 245/40r17's on 17x8's. Wheels are +50 but I run 5MM spacers. Suspension is Koni Yellow with Swift Spec-r's. Rear fenders are currently rolled and I don't have any issues.
daafisch is offline   Reply With Quote
 Old 05-21-2012, 12:14 PM   #44
silentwolf8's Avatar
Posts: 1,986   (View Stats)
silentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the world
Groans: 44
245/35r18 s-Drives on a 18x9.5 +30 offset rim.
H&R Springs, and a JBR RSB on stiffest setting.
Rear Fenders Rolled thanks to @rgz
ZOOM ZOOM left the Room
2013 SPW STi // COBB SRI w/Box // COBB BPV // UR Catless DP// UR CBE // COBB Lowering Springs // COBB Sway Bars // +1 NGK // DW65c FP
AWDTuning Tuned
silentwolf8 is offline   Reply With Quote
 Old 05-21-2012, 12:27 PM   #45
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
Change of setup...
I'm now lowered on eibach springs with koni yellows (one full turn stiff in the back, a little more than 1 turn in front). Rears were pulled more, cracking the paint on the drivers side, and I still rub, even slightly more than stock. Rear sway is even more necessary now but that should be on tomorrow. Fronts rub under hard turning.
Overall I'm a little disappointed with the wheels only because of the rubbing. I'm considering dropping to 235/40 tires next time around, or just pulling the shit out of the fenders and touching up the paint once that's all done. I will be racing this car so I want to keep the wide tires...we'll see where I go with it. It's also my daily so ride comfort is very important.
Pain in the ass wheels....Anyone want some evo's?
Blue Pu.
 Old 05-21-2012, 12:29 PM   #46
Groans: 44
Change of setup...
paint cracking? is that from the fender rolling? (you not use heat gun to heat up fenders and paint)
AWDTuning Tuned
 Old 05-21-2012, 12:32 PM   #47
anavrinIV's Avatar
Groans: 63
It is. I used a heat gun when I rolled them flat and did the first pull and all was fine, but when I worked on them a second time (without an actual roller) it cracked. It sucks, but this isn't a show car and paint can be fixed.
Blue Pu.
 Old 05-21-2012, 12:36 PM   #48
Groans: 44
ah gotcha.
AWDTuning Tuned
 Old 05-21-2012, 12:54 PM   #49
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Change of setup...
What specs are you running currently? As far as tires and wheels..
Yellows plus eibach sounds like some serious lows, and even more so I'm sure those Eibachs drop alot in turns.
 Old 05-21-2012, 02:11 PM   #50
anavrinIV's Avatar
Groans: 63
18x8.5 +38 with 245/40 tires. The drop is more than I wanted but I got the springs free. I"m thinking about trying stock springs on all 4 corners to see if that at least solves the rubbing. If not, I may order some cobbs in the near future...minimal drop and stiffer springs. If that doesn't work I'm selling everything and torching the car.
Blue Pu.
 Old 05-21-2012, 02:47 PM   #51
helmetface's Avatar
Groans: 219
Lol sorry to hear about you troubles. I wonder how similar mine will be..
If stock springs solve the issue and youre having troubles finding cobbs im loving my corksports and the drop is similar in not being aggressive.
Good luck homie
 Old 05-21-2012, 02:56 PM   #52
anavrinIV's Avatar
Groans: 63
I was actually going to ask you about the actual drop with the corksports was. The supposed drop is way too aggressive for me, but even the cobbs are rated at 1" all around but only go about .25" in the rear from what I hear. The problem with the eibachs, I think, is not necessarily the drop but the softness. I get the feeling that they're stiffer than stockers, but not by very much.
Overall it's just frustrating, but not impossible to figure out. The big thing is that I don't want to spend much more money on this issue. Once I'm employed I'm thinking of selling the evos and picking up a set of milligrams for the greater offset, but I really dont' want to go through the trouble for an extra 7mm inset. Hopefully the stock springs will hold me over until I know exactly what I'm going to do.
On the plus side though, the car currently looks fantastic lowered.
Blue Pu.
 Old 05-22-2012, 06:22 AM   #53
anavrinIV's Avatar
Groans: 63
@helmetfail
I should have quoted or mentioned you earlier. What's your actual drop with the CS springs? Is it the full 1"+ as advertised?
Blue Pu.
 Old 05-22-2012, 01:27 PM   #54
helmetface's Avatar
Groans: 219
@helmetfail
From memory the advertised drop is rated at 1.2" in the front and 1.0" in the rear. However i dont think i dropped a full inch on either.
The spring rates between these and Eibachs are probably a substantial difference, they are a rough ride but quite firm indeed.
I would suggest them to a friend but not a friend that totes around kids, get my drift?
Keep in mind im on bilsteins
 Old 05-22-2012, 01:57 PM   #55
Dru
Dru's Avatar
Posts: 23   (View Stats)
Dru is a glorious beacon of lightDru is a glorious beacon of lightDru is a glorious beacon of lightDru is a glorious beacon of lightDru is a glorious beacon of lightDru is a glorious beacon of light
I run 17x9 +45 RPF01s with 245/40R17 AD08s. Just had to run a 5mm spacer up front and have 5mm of room between tyre and strut! Planning on getting 255s next once the AD08s have gone to shit.
Dru is offline   Reply With Quote
 Old 05-22-2012, 03:27 PM   #56
anavrinIV's Avatar
Groans: 63
I think I'm going to order the cobbs then. For now my OEMs are going back on the rears only (supposedly stiffer than the eibachs...I can't find any reliable info on eibach spring rates) and soon I'll order some new springs. Reportedly the cobbs give ~1/2" up front and almost nothing out back, but they're pretty stiff. I don't carry small children and my girlfriend can deal with it or leave...whichever is fine with me. Plus I can adjust the damping on the konis except that it's completely trial and error with the rears and you have to pull them to change it...
Blue Pu.
 Old 05-23-2012, 11:22 AM   #57
anavrinIV's Avatar
Groans: 63
Final update for now...
Got my JBR rear sway in and put it on today. Cornering is very tight now and control seems better overall. I also put my OEM springs back in, so it's time to get into it...
I pulled the eibachs from the rear and compared them to the OEMs out of the car. The length is nearly identical, but since teh drop is so much from the eibachs it means that they're quite a bit softer than stock. This is a horrible property for a drop spring and was the main cause of all the rubbing. With the stock springs back in the rear the ride is better with the new shocks than it was with konis and eibachs, the car is completely leveled and looks amazing now (eibachs still in front) and the rubbing over a few bumps that used to cause me problems is gone. I'm still considering cobbs at some point but I"m tired of spending money on this and I'm very, very happy with the ride and handling overall. If I start to auto-x I'll upgrade the springs definitely but for now I'm content. Finally.
Blue Pu.
Page generated in 0.37643 seconds with 26 queries
