Like Tree16Likes
 Old 02-18-2016, 06:36 PM   #41
sheston's Avatar
Posts: 1,847   (View Stats)
@dale_gribble; I like them. I run several things contrary to the smart guys on here, and don't think we all have to agree. For DD, I've found that the wider, the better as far as on road handling (I believe that is what you said as well). My last tire, I went with a tall, soft sidewall (too tall, rubs everywhere) and wide tread on the stock wheels in search of better straight line grip. May have worked, but I do seem to have more cornering speed.
As far as looks, I love the way these look and hate the way a 205 would have looked (probably what the experts say to mount up)..... exaggeration
 Old 02-20-2016, 10:49 AM   #42
maddocx240's Avatar
Posts: 823   (View Stats)
maddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the worldmaddocx240 is the leader of the world
Groaned at 45 Times in 21 Posts
I'm gonna run the sumitomo z111 myself. I wanna see how they perform.
maddocx240 is offline   Reply With Quote
 Old 02-22-2016, 08:07 AM   #43
shamie's Avatar
Posts: 952   (View Stats)
All the haters just need to GTFO. This is not his race car its his driver. This setup looks great and works - not slammed or hella flush or any of that shit. Looks aggressive while still very tasteful.
The Following User Says NO Thank You to shamie For This Un-useful Post:
Neverlift (02-22-2016)
 Old 03-07-2016, 06:50 PM   #44
dale_gribble's Avatar
Posts: 4,720   (View Stats)
I've been running this setup now for weeks and I really, really like it. I will say that I am not a track guy and I don't have before/after laptimes for validation. My observations are empircal.
I will say that there was no steps back compared to my last 235/40 setup. I settled on 38psi for the tires, and I like them best there. The high speed stability at the end of a 100mph+ 4th wot pull is noticeable. The car feels heavier at high speed if that makes sense. It just feels more planted and I fell more confident driving it at high speed. I don't know how else to explain it.
After a few canyon runs and high speed highway interchanges, there was no giveaway there either. It just feels super solid. The tires aren't even hinting that they are starting to get loose like before (i.e. very light squeal). I haven't noticed a change in response in recovering from one turn to another. It just goes where I tell it.
So, speaking of high speed stability, it feels more stable. In regards to turning/cornering, I don't feel that I gave anything up. Any handling changes are in the noise and outside my ability to notice.
The car did lose 1-2mpg though, and I did see about a 10whp drop in my VD runs afterwards; so the extra 3-4 pounds a corner seems to have cost a little power. IRT to 60-100 times, that works out to about a tenth of a second.
MINI H1 6.0 - CAR LED TAILS
 Old 03-09-2016, 07:13 PM   #45
sheston's Avatar
That's kind of weird. I went with 245/45 18s (I know, way too big, rubs a bunch) on the stock wheels. For some reason I'm getting almost 10% improvement in mileage, not even correcting for the further than recorded distance covered.
For your 60-100 mph runs, have you tried correcting the speed for the diameter difference?
 Old 12-08-2016, 07:57 PM   #46
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Reviving,
I'm looking at getting 18x8.5 +50 with those same tires but 245/40.
Based on your experience, will I have to roll with stock ride height.
One day when I decide to go lower, I'm thinking roll/pull is unavoidable.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 04-29-2017, 09:09 AM   #47
Tye1's Avatar
Posts: 3   (View Stats)
Tye1 has a little shameless behaviour in the past
To @dale_gribble ::: You sir... are my hero! Good lord almighty! I thought 255 was pushing it for the stock body! Well done and many kudo's! I will be following in those foot steps soon!
Tye1 is offline   Reply With Quote
18x8.5 +38 on Gen 1 MS3 matto MazdaSpeed 3/6 - Wheels & Tires 16 05-24-2011 06:46 AM
18x8.5 on 235/40/18 ms3boost MazdaSpeed 3/6 - Wheels & Tires 10 04-15-2009 07:00 AM
18x8 +40 Fit? SSLow3 MazdaSpeed 3/6 - Wheels & Tires 8 03-14-2009 06:08 PM
Page generated in 0.28792 seconds with 26 queries
