 Old 03-29-2015, 10:24 AM   #1
Speed1719's Avatar
Posts: 25   (View Stats)
Speed1719 is infamous around these partsSpeed1719 is infamous around these parts
Groaned at 39 Times in 11 Posts
Default Anyone running 18x9 +38? On a speed 3
Just got my Advan RS 18" rims 18x9 with a 38offset. seems like when I go over bigger bumps I get a rubbing sound. Will getting coilovers solve this issue? Or spacers.
Thanks
Speed1719 is offline   Reply With Quote
 Old 03-29-2015, 11:31 AM   #2
tegxsi's Avatar
Posts: 1,273   (View Stats)
Groans: 87
Did you read the sticky thread?
The Ultimate "Will They Fit" Thread - Everything you need to know about wheels, spacers and tires for your MS
2018 Audi RS3
2007 Acura TSX 6MT
tegxsi is online now   Reply With Quote
 Old 03-29-2015, 03:20 PM   #3
tparker14's Avatar
Posts: 180   (View Stats)
tparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond repute
Definately read the thread posted above.. With spacers and/or coilovers you would most likely make rubbing worse
tparker14 is offline   Reply With Quote
 Old 04-05-2015, 08:54 AM   #4
msantana101's Avatar
Posts: 1,517   (View Stats)
msantana101 is the leader of the worldmsantana101 is the leader of the worldmsantana101 is the leader of the worldmsantana101 is the leader of the worldmsantana101 is the leader of the worldmsantana101 is the leader of the worldmsantana101 is the leader of the worldmsantana101 is the leader of the worldmsantana101 is the leader of the worldmsantana101 is the leader of the worldmsantana101 is the leader of the world
I'm on ksports with an 18x9 +35 and I only rub on the fronts on huge dips/bump in the freeway. I don't rub against the coil however and I also do not need spacers. Running a 235/40/18 and only the rears are rolled btw for reference.
FreekTuned
msantana101 is offline   Reply With Quote
 Old 04-05-2015, 08:58 PM   #5
Speed1719's Avatar
Perfect thanks a lot for the feedback I appreciate it
The Following User Says Thank You to Speed1719 For This Useful Post:
msantana101 (04-26-2015)
H&R Coil overs on Speed 6 anyone running these? JDMCRX MazdaSpeed 3/6 - Suspension & Brakes 11 06-19-2014 08:52 PM
Anyone running 18x9.5 on stock springa out there??? xTRELLx 2010 MS3 - Wheels & Tires 11 07-23-2013 03:08 PM
Anyone Running Rota DPT 18x9.5 08sedanman 2010 MS3 - Wheels & Tires 12 06-05-2012 09:17 PM
anyone running 255 40 rs3 on there speed 3? Cwhite MazdaSpeed 3/6 - Wheels & Tires 3 05-22-2011 08:32 AM
Speed 3 1/4 mile times. Whos running what? racebitz Mazdaspeed3/6 General Discussion 1 10-23-2008 10:44 AM
Page generated in 0.26205 seconds with 23 queries
