| MazdaSpeed 3/6 - Wheels & Tires HaveMazdaSpeed 3 - Wheels & Tires - Have a question about wheels or tires? Need a calculator to figure out offsets? We have them in here |
![]() | | #1 | ![]() |
![]() Join Date: Sep 2012 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 75
__________________ 2007 Black Mica Mazdaspeed6 GT - Stockness |
![]() Join Date: Dec 2011 Location: Orland Park il
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 99
Groaned at 4 Times in 2 Posts
| Not Ranked : 0 score Nothing would happen usually the ms6 is fwd under light driving Sent from my myTouch_4G_Slide using Tapatalk 2
__________________ GT3076/ catless dp/ FMIC/ 3.5" CP-E Intake/ 3" Exhaust/autotech internals/ built block/ 3-port/denso itv22/ 6th-port |
![]() Join Date: Nov 2008 Location: Edmonton, Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,648
| Not Ranked : 0 score I thought it was only FWD at very slow speeds or with the e-brake engaged. I would stick within about 2/10 , maybe 3/10 tire wear between front and rear axles. |
![]() | | #4 | ![]() |
![]() Join Date: Nov 2010 Location: 93401
Rep Power: 364 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 480
| Not Ranked : 0 score It's awd like 99% off the time, 1% is reverse and low load low speed like under 10mph. There is a video of a guy who monitored the diff solenoid and it was pretty much always on. As for the tire wear issue I'm pretty sure there is a tolerance number somewhere in the manual, if not it's online. It will be in a decimal number, so you can't compare that to the guys estimated percentage. I would just get new tires if your feeling unsure about it. Sent from my Incredible 2 using Tapatalk 2
__________________ CP-E TIP and Cai - Corksport 3" catless DP - Magnaflow CBE - KMD fuel pump internals - Cobb AP - Fat Cat Motorsports Coilovers! |
| Inner tire wear much | Dmurray06 | 2010 MS3 - Wheels & Tires | 23 | 11-29-2012 09:20 PM |
| Tire Wear Concerns | marco427 | Gen2 MS3 General Discussion | 18 | 10-07-2012 06:06 PM |
| wtf insane tire wear!!! | superskaterxes | MazdaSpeed 3/6 - Wheels & Tires | 42 | 07-26-2010 10:33 PM |
| Bad Inner Tire Wear | MattJackson86 | MazdaSpeed 3/6 - Wheels & Tires | 3 | 03-09-2010 07:43 PM |
| Bad inner tire wear | cm-jp1 | MazdaSpeed 3/6 - Suspension & Brakes | 27 | 12-05-2009 08:19 PM |
