-   -   Backspacing Question (http://www.mazdaspeedforums.org/forum/f319/backspacing-question-33107/)
MidwestSpeed3 07-20-2009 08:11 PM
I know this isn't the necessarily the right forum, but I wanted to get the greatest exposure. I found a set of wheels, but I am not 100% certain they will fit. They are 17x8, 5 x 4.50 or 5 x 114.3, +45 offset. I know all these are good, but the thing I am worried about is the backspacing, which is 6.22" and I am not sure what the MS3 needs. Below is a link to the wheels on tirerack.
Enkei Racing RPF1 Black Painted
Please advise if these will fit or not. Thanks.
nutsac76 07-20-2009 08:33 PM
if you want 17's its a step down but the backspacing is too much by .12 of an inch they make them for our car but you have to follw the fitment guide on the tire rack website.
MidwestSpeed3 07-20-2009 08:57 PM
Damn, so these won't fit? That's too bad because I found a damn good deal on a used set. Bummer....
nutsac76 07-20-2009 09:04 PM
they will fit but the link you have is for a set of 17's. and the linked ones are for rwd. hence the extra spacing in the rear. you might rub a little in the back if not stock height.
MidwestSpeed3 07-20-2009 10:01 PM
I am quite aware of them being 17's, 17x8 is actually what I have have been looking for. Lighter, wider, and taller sidewall for better ride quality.
I am slightly confused on how the backspacing affects the fitment. I know +45 offset will fit fine, as I have +42 17's that I run during the winter. Trying to get an understanding of this, but I haven't found anything that is helping my knowledge of this.
Any help would be appreciated.
MidwestSpeed3 07-20-2009 10:13 PM
So I searched for wheels for a Mazdaspeed3 on tirerack, and it brought up results with 6.10" and 6.33", so my intuition says that means a 6.22" would fit. Although, I am sure that there is something more to it than this.
Anyone else have any input?
jamesthebikeguy 07-21-2009 06:28 AM
you will be fine.
next time check out the wheel & tire forum
Page generated in 0.17300 seconds with 11 queries
