 Old 09-06-2016, 11:06 PM   #1
AveryPlaysBass's Avatar
Posts: 293   (View Stats)
AveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond reputeAveryPlaysBass has a reputation beyond repute
Groaned at 6 Times in 4 Posts
Default BFG aint fer me
Recently, after a 5 hour drive to and from Austin, I can say that maybe the Sport Comp 2's were not the best tire for me. I do a lot of highway driving, have passengers regularly and do not track the car at all. The BFG's are great in the dry and very stable in the wet but their sacrifice in road noise and comfort is not something I can live with, especially knowing there are many more road trips in my future.
So, due to budget constraints my choices are
Hankook V12 $362, Hankook S1 $367, Kumho Ecsta 4X II $349, and finally Firehawk Indy 500 $325. Which set will have a noticeable difference in terms of ride/noise and treadwear?
[SIGPIC][/SIGPIC]It's OK to cry" - Lil B
2012 MS3 w/Tech Package
Engine: CS SRI/Tip, AutoTech internals, Damond Banjo Bolt, JBR Boost Tubes, E-Focus Mount, CS Racepipe, Tuned by FREEKTUNE
Trans: CS insert, CS bushings, Damond Shifter Plate
Suspension: Koni Orange with OEM springs, Konig Controls 17x7 with 225/45 Conti DW's
Appearance: CP-E Relocation Plate, Smoked Taillights, Bumper Guard, CS Steering wheel/Shift knob/E-brake handle,dumb stickers
AveryPlaysBass is offline   Reply With Quote
 Old 09-06-2016, 11:59 PM   #2
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Get a Michelin tyre if you want grip and comfort. The pilot supersports are as good as a decent road tyre can get.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
AveryPlaysBass (09-07-2016)
 Old 09-07-2016, 02:22 AM   #3
alden's Avatar
Posts: 400   (View Stats)
alden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant futurealden has a brilliant future
A friend of mine had the Firehawk Indy 500 on his speed, no complaints. They seem to be holding up fairly well to some decently aggressive driving around town. I've been in the car a few times with him and didn't notice much in terms of road noise, although I've also never been on a trip in his car and that's really the only time you would notice a lot of road noise. As far as the others, I'm not sure. Supersports are great...and expensive.
alden is offline   Reply With Quote
The Following User Says Thank You to alden For This Useful Post:
 Old 09-07-2016, 07:36 AM   #4
broda's Avatar
Posts: 375   (View Stats)
broda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the world
That's odd. I experienced minimal to no extra road noise from my Sport Comp 2's.
broda is offline   Reply With Quote
 Old 09-07-2016, 10:46 AM   #5
nekret's Avatar
Posts: 421   (View Stats)
nekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the world
I've had the Firehawk wide oval indy 500 on my speed3 for roughly the last 30K. They do last quite a while even with some occasional abuse. I will say though that their performance in even slightly cooler (below 50) weather is pretty lack luster.
For road noise they are pretty decent until you get to about half their tread life and they get pretty loud, wet performance is pretty average but dry (warm) performance is pretty darn good for a cheap street tire. FWIW they are pretty good deal but if you can spend more it will yield a better experience.
2011 Mazdaspeed3 non-tech package
Drivetrain
CorkSport 3.5" MAF & TIP | CP-E FMIC | Synapse BPV | CorkSport EBCS (Interrupt) | Bosch 3 bar MAP | CorkSport HPFP Internals | CP-E Catted Downpipe | CP-E Triton 3" CBE | JBR Stage 2 OCC | Kozmic Primary EGR Delete | JBR Secondary EGR delete | NGK 6510 | TB coolant Bypass | JBR IM & TB Gaskets | Damond RMM, PMM, & TMM | JBR light shift weight | TWM Full Replacement Shifter | Cobb AccessPort V3 | FreekTune
Chassis
JBR Front & Rear Sway Bars | JBR Billet Rear Sway Bar Brackets | Whiteline Adjustable Front&Rear sway bar links | JBR Coilovers | Corksport BBK | Corksport Lower Tie Bar | Corksport Mid Chasis Brace
Rice
LED bumper reflectors | Morimoto LED Fog lights | VLEDs LED Highbeams | Independent Fogs | AP Engine & HPFP cover | CorkSport Pulleys | Corksport Leather Shift Knob | Corksport Steering Wheel | Damond front plate mount | Lukas LK-9750 2ch dashcam | Eonon GA7163 | thespeedline.com blue mirrors | thespeedline.com hood dampers
nekret is offline   Reply With Quote
The Following User Says Thank You to nekret For This Useful Post:
 Old 09-07-2016, 12:00 PM   #6
I guess compared to my older Kumho's they had additional noise and rode stiffer. I mean they're not bad for short rides but on long drives they're pretty annoying.
 Old 09-07-2016, 12:20 PM   #7
Unfortunately my budget is $400. If I could get some PSS for that I definitely would but as of right now I'm just utilizing the rebates the manufacturers have going.
 Old 09-07-2016, 01:52 PM   #8
Amaroms3's Avatar
Posts: 68   (View Stats)
Amaroms3 is a splendid one to beholdAmaroms3 is a splendid one to beholdAmaroms3 is a splendid one to beholdAmaroms3 is a splendid one to beholdAmaroms3 is a splendid one to beholdAmaroms3 is a splendid one to beholdAmaroms3 is a splendid one to behold
+1 for the Indy 500 got them off tire rack for 450 few months back. Good budget tires with traction look up there review/track test on tire rack. Just to be clear these are the Indy 500 not wide oval Indy 500. Also the wife dailys the speed with my 2 kids back and forth to school with these on and no complaint about road noise.
Amaroms3 is offline   Reply With Quote
 Old 09-08-2016, 10:03 AM   #9
nekret's Avatar
So one trick to get some nice tires at a low cost is to check out ebay. every once and a while discount tire will offer some pretty decent discounts. I got 4 245/40/18 Michelin PSS shipped to my door for $600. Still not as affordable as the Firestone tires but they'll feel so nice (assuming I ever get my evo wheels back from powder coating).
Drivetrain
Chassis
Rice
AveryPlaysBass (09-08-2016)
Aint this some !!!!!! qtrmile beast MazdaSpeed 6 - Engine, Transmission & Driveline 6 10-21-2012 11:34 AM
You aint no racecar unless your does this bewsted JAMES BARONE RACING 19 08-14-2012 04:49 PM
Supra aint got shit atenza_freak Members Rides Gallery 29 01-17-2011 05:09 AM
Page generated in 0.30456 seconds with 25 queries
