Like Tree6Likes
  • 4 Post By g00s3y
  • 1 Post By CamShaft
  • 1 Post By Cheapspeed
 Old 09-05-2016, 11:26 AM   #1
CamShaft's Avatar
Posts: 28   (View Stats)
CamShaft will become famous soon enoughCamShaft will become famous soon enough
Default Big Rock and Destroyed Tire opens doors
The other day while driving home from work, I smoked a big bloody rock, slightly smaller than a tennis ball, thunderfucking the sidewall and putting a minute dent on the lip of my wheel. A bit of a piss off to say the least. Since I was approaching a logging truck on a narrow road at that exact moment, swerving wasn't an option.
Until I sort out my plan of action I threw on my Winter steelies since the snow'll be flying next month anyway.
On my Gen 1 I've been running Marangoni Mythos 225/40/18 on 18x7.5 inch wheels, stock suspension. Offset I'm unsure of.
Initially I figured I'd wait until spring, try to sell my 3 good tires and replace them all with Nitto NT555's in the same size. Upon further consideration I've decided that doing so would be retarded, seeing that I plan to make plus 350whp in due time, so I'd might as well set this up right the first time. Tires are too often a performance mod that's taken for granted.
If I ran a 245/40/17 with a offset of 48, my clearance should be fine seeing that the diameter of the tire would be extremely close to what I'm currently running and based on my homework. I have no qualms about rolling my fenders either.
My predicament is that I'd like to run Nitto NT555R's on the front and NT555's on the rear with a modest half inch suspension drop. Unfortunately those tires only come in 245/45/17 which is half an inch larger in diameter, which I think may potentially pose clearance issue. I think I may have to pick a different tire set up....
I'm also finding it difficult to find a 17x8 inch wheel I like with the offset I'm looking for.
Good thing I've got months of winter approaching to do further research and come to a decision.
Here are a couple picks of the damaged goods.
"When one door closes, another opens"
CamShaft is offline   Reply With Quote
 Old 09-05-2016, 12:03 PM   #2
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Drugs are bad, mkay?
The Following 2 Users Say Thank You to g00s3y For This Useful Post:
KiwiFlavor (09-06-2016), Vansquish (09-05-2016)
 Old 09-05-2016, 04:04 PM   #3
_SPEED3GT_'s Avatar
Posts: 38   (View Stats)
_SPEED3GT_ is a name known to all_SPEED3GT_ is a name known to all_SPEED3GT_ is a name known to all_SPEED3GT_ is a name known to all_SPEED3GT_ is a name known to all_SPEED3GT_ is a name known to all
What in the.....
A "minute dent"....
_SPEED3GT_ is offline   Reply With Quote
The Following User Says Thank You to _SPEED3GT_ For This Useful Post:
 Old 09-05-2016, 04:08 PM   #4
thems3driver's Avatar
Posts: 235   (View Stats)
thems3driver is the leader of the worldthems3driver is the leader of the worldthems3driver is the leader of the worldthems3driver is the leader of the worldthems3driver is the leader of the worldthems3driver is the leader of the worldthems3driver is the leader of the worldthems3driver is the leader of the worldthems3driver is the leader of the worldthems3driver is the leader of the worldthems3driver is the leader of the world
Groaned at 4 Times in 1 Post
Originally Posted by _SPEED3GT_ View Post
What in the.....
A "minute dent"....
Lol I thought the same shit. Was like new slang?
Current Installed: Autotech Internals | Cobb AP v3 | JBR SSB | JBR RMM 80A Duro | Pioneer HU - Alpine speakers - Alpine sub (cause fuck BOSE) | Goodyear F1 Asymmetric | CS Intake + TiP | Forge BPV v2.0 | Swift Springs Spec R | Redline MTL 80
Future Installs: CS Race Pipe | CP-E TMIC | WMI
Rice Maker Mods (not power mods): Daily Driven, Mazdaspeed Decals, Cobb x2, JBR Decal, Stratified Tuned Decal, RVinyl yellow fog overlays, Plastidip rear valance, G2 caliper pnt, 35W Kensun slim HID, CS LEDs Fogs | Footwell blue LEDs | Dual ported box | Foglight Covers dipped | Red Vinyl Wrapped Tail Lights
thems3driver is offline   Reply With Quote
The Following User Says Thank You to thems3driver For This Useful Post:
_SPEED3GT_ (09-05-2016)
 Old 09-05-2016, 05:22 PM   #5
CamShaft's Avatar
Minute" is a word most commonly used to describe a measurement of time equaling 60 seconds, but with a different prunciation can also mean infinitesimal, insignificant, minuscule, tiny, trace ,exact, exacting, excruciating, precise, scrupulous . So....in this particular context: very small.
Now....if you gentlemen spent a a fraction of the time (a minute Perhaps?), searching the dictionary, as you do forums , reading about cars, you'd have easily found the definition of that word with little confusion. HAHAHAHA
Seriously though guys, I don't read the dictionary either.....and perhaps the use of that word to describe my wheel is a bit of an understatement.
Cheapspeed likes this.
The Following User Says Thank You to CamShaft For This Useful Post:
Cheapspeed (09-06-2016)
 Old 09-05-2016, 06:44 PM   #6
g00s3y's Avatar
Groans: 438
Crack is whack.
 Old 09-06-2016, 05:15 AM   #7
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
To keep the stock rolling diameter you want a 245/45/17. So that solves that problem.
17x8 +48 won't have clearance issues but I'd run a wider wheel if you're planning at least 245s. I run 17x8 +48 and only have clearance issues in the front at the strut, no problem in the rear. You'll need that roll but shouldn't need much pull if any. If you go coilovers you may need more front spacer (I use 5mm).
For tire choice, that's up to you but I wouldn't mix them. These cars are hard on tires and you'll get pretty bad wear if you never rotate them.
Blue Pu.
CamShaft (09-06-2016)
 Old 09-06-2016, 05:15 AM   #8
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Groans: 29
It's pronounced "my-newt" in this context.
CamShaft likes this.
The Following 2 Users Say Thank You to Cheapspeed For This Useful Post:
MSMS3 (09-06-2016), Yatta (09-06-2016)
 Old 09-06-2016, 07:23 AM   #9
CamShaft's Avatar
Thanks for the intelligent input, @anavrinIV;
You're absolutely right about the 245/45/17's being the same (within 0.1 of an inch) size as the stock tire size diameter. I completely forgot that they come with 215/45's. So that solves that issue. So I'll stick with my plan to run NT555R's up front and NT555's in the rear. The reason for the mixing is that the 'R's are drag radials meant to be ran with the others. I plan to convert my speed3 to a strictly summer time toy so roasting tires off will be part of the game, and I think that once I get the power levels I plan to, the drag radials will be a wise choice to get the traction down.
And I think for wheel choice, I'm going to go with some black Enkei T6S wheels.
 Old 09-06-2016, 08:08 AM   #10
anavrinIV's Avatar
Groans: 63
Meant to say I run 17x9 +48, not 17x8
Blue Pu.
2016 Mini Clubman opens its many doors to the world Haltech Automotive News 0 06-24-2015 09:40 AM
Fiat opens doors at Abarth factory on Google Street View Haltech Automotive News 0 10-16-2014 09:10 AM
Ford opens the doors on its Swedish rally skunkworks Haltech Automotive News 0 09-19-2014 03:20 PM
Sultan of Michigan opens doors to his collection for charity [w/video] Haltech Automotive News 0 06-16-2011 05:20 PM
BMW opens its factory doors a little wider -- for a C-Note Haltech Automotive News 0 05-08-2010 10:10 PM
Page generated in 0.32333 seconds with 26 queries
