couple ms6 wheel questions I found some rota torques that I really like but the hub bore on them is 73mm, I know that stock bore is 67.1 but will these still work?? Also they are 18x8's 35et. Will I have any issues running these with a 245 40 tire?? Thanks! |
Nobody knows?? |
you wiill need hubcentric spacers to make them work. and 35 is a REALLY low offset. if you are at stock ride height u might be ok but any lower and u will need a roll. try mazda6club forums for more MS6 specific questions |
| All times are GMT -7. The time now is 07:53 AM. |
