deactivate TPMS??? dose anyone know of a way to deactivate the TPMS system??? first off rims and tires are not my specialty. i ended up bying some rims second hand good condition and 85% tread left on tires so no need to replace thouse yet. is there anyway to deactivate TPMS iv heard one of the sunroof circits. if no solution ill wait till i need new tires and replace w new or used sensors. i knew coming in that the light would come on im ok with it if no way to fix other then doing the mazda way. wow rambaling. dose anyone know of a way to deactivate the TPMS system??? |
i would like to know this as well- it'd be great if we could put this on a switch... |
you can swtich the monitor out with out dismounting the tire! all u gota do is get the tired guy to push the sidewall down so you can slip it in there i had to have this done when i painted my rims and forgot to the bring the monitor and they guy just put a reg valve stem in it! |
get a small tube, put all 4 sensors in it, pressure the tube to 35psi.. put in glove box.. |
im sure it wouldnt be hard to wire... ssinstaller? |
Just another thought. You can always take the light out. I did it and takes about 30 min. Good luck.. |
mmm. don't want to do that. |
Where’s the black electrical tape when I need it???? lol duck tape... lol bailing wire... yes i know its duct |
Just a heads up. When I changed out my stock rims with after market, Discount Tire added new sensors all the way around for $35 bucks. My suggestion would just go to Doscount, or a comparable tire shop, and have them installed, and you dont have to worry about it anymore.. |
| All times are GMT -7. The time now is 08:21 AM. |
