 Old 03-15-2008, 08:00 PM   #1
yup24z's Avatar
Posts: 56   (View Stats)
yup24z is a jewel in the roughyup24z is a jewel in the roughyup24z is a jewel in the roughyup24z is a jewel in the rough
Default Do 225/45/18's really rub?
On stock suspension....anyone ever hear of this size tire rubbing? Really dont want to go to a smaller diameter tire with a 225/40. Any help would be great.
2008 Black Mica MS3--Corksport DP, Turbo XS Racepipe, Custom 3inch Catback, Cobb SRI, Turbosmart Mbc @ 18psi, ATP BCD, Prosport Boost Gauge, Dashhawk, 6000k HID's, 5% tint
Stock Dyno: 227hp/241tq
Dyno w/ Cobb SRI/Corksport DP/TXS RP/MBC @ 18psi- 279hp/315tq
yup24z is offline   Reply With Quote
 Old 03-15-2008, 08:01 PM   #2
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
It's kind of hard pressed to believe if you have either a 48 or 52mm offset wheel. Im going to try to stuff the widest tire i can with coilovers. Ill see what the tire store has in store for me when the car gets it alignment after i install the coilovers.
 Old 03-15-2008, 08:28 PM   #3
NYpest's Avatar
Posts: 1,889   (View Stats)
NYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the world
I'm lowered 1.5" with 225/45 no rubbing with + 50 rx8s or +48ssr
NYpest is offline   Reply With Quote
 Old 03-15-2008, 09:07 PM   #4
TarmacMS3's Avatar
Posts: 4   (View Stats)
TarmacMS3 is on a distinguished road
I've been doing a lot of research for the wheel/tire set up I wanna run but have come up with nothing. Seems like folks with these cars run super safe with wheel and tire combos. I'd like to try a wheel in the range of 8.5"-9" with a 245/40 tire. I think fender rolling may be in the cards.
Any thoughts?
TARMAC FACTION PERFORMANCE ENGINEERING SERVICETM
TarmacMS3 is offline   Reply With Quote
 Old 03-15-2008, 09:11 PM   #5
yup24z's Avatar
What's the offset of the stock rims? Do you know?
 Old 03-15-2008, 09:14 PM   #6
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Any thoughts?
8.5 do fit but with a 52mm offset and that gives you VERY LITTLE clearance on the strut. If you go coilover, you're screwed with that offset because every Coilover setup varies with regards to strut variation.
I went safe, 18X8 48mm. Im still rolling my fenders when it goes in for alignment. I would like to see someone make a fender extension. You could have to cut into the fenders a bit, but the wheel possibilities would be endless.
 Old 03-15-2008, 09:14 PM   #7
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
i believe they are 45mm
 Old 03-15-2008, 09:26 PM   #8
TarmacMS3's Avatar
Hmmm, fender extensin wouldn't look bad, IF it was tasteful. I'm not really big on body mods though. May have to go back to the drawing board on this wheel/tire issue.
FYI, I'm looking at Volk CE28 or Advan RS.
 Old 03-15-2008, 09:33 PM   #9
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
i almost dropped $3K on Volks until they didnt offer the offset i needed. Than i realized, its not worth it.
 Old 03-15-2008, 10:18 PM   #10
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
stock is +53 I'm pretty sure
 Old 03-16-2008, 12:34 AM   #11
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
No way! for a 7.5 inch wheel?
 Old 03-16-2008, 05:18 AM   #12
Jesse MS3GT's Avatar
Posts: 356   (View Stats)
Jesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the world
its 52.5 says so on mazdas website
There will always be someone faster than you, smarter than you, or better than you in some way. They key is to maintain a presence beside those lesser than you to appear superior
35psi, super cams, ported head, titanium valve springs, titanium rods/pistons, flux capacitor, 88mph mod, cryogenic tranny with welded differential
Jesse MS3GT is offline   Reply With Quote
 Old 03-16-2008, 05:24 AM   #13
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
If thats the case, why are aftermarket wheel companies only offering +45mm offset on 7.5 wheels?
 Old 03-16-2008, 05:34 AM   #14
aaronc7's Avatar
Groans: 370
I think stock is 18x7 +53 (52.5)..my wheels are 18x7.5 +45
 Old 03-16-2008, 07:47 AM   #15
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Well shit, that would explain it i guess. I keep thinking they are 7 inch stock.
 Old 03-18-2008, 07:22 AM   #16
NYpest's Avatar
yes +52
 Old 03-19-2008, 04:03 PM   #17
Young Roids
Lurkers
Young Roids's Avatar
Posts: n/a
What would be perfect would be the volk re30 in 18x8.5 with a 52mm offset. would be goregeous.
 Old 03-19-2008, 04:05 PM   #18
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
i run 235/40/18s no rubbing at all
 Old 03-19-2008, 05:09 PM   #19
aaronc7's Avatar
Groans: 370
Do you have any good pics of 235/40s on stock wheels. Curious if there's any sidewall bulge etc
 Old 03-25-2008, 09:44 PM   #20
TRU-BOOST's Avatar
Posts: 801   (View Stats)
TRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the world
would never fit. stock is 7" with 52.5 offset. you cant run a rim that is 1.5" wider and keep the same offset. you would need liek a 40 offset with 8.5" rims
TRU-BOOST is offline   Reply With Quote
 Old 03-25-2008, 11:49 PM   #21
jlarson1983's Avatar
Posts: 887   (View Stats)
jlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the world
we just installed 225/45/18 on a stock speed and no rubbing
jlarson1983 is offline   Reply With Quote
 Old 03-26-2008, 10:08 PM   #22
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
Rubbing depends of course not only tire size, but also on wheel offset and width, as has been mentioned.
Even taking all of that into account, you must also remember that not all "225" section width tires are really the same width. There is quite a bit of variation among brands/models.
I'm sure that most 225/45s will fit on stock MS3 wheels with stock suspension with no worries. It's when you start messing with different parts of the equation that you might run into problems.
 Old 03-27-2008, 07:34 AM   #23
kneedragger241's Avatar
Posts: 67   (View Stats)
kneedragger241 has a spectacular aura aboutkneedragger241 has a spectacular aura about
Just my guess here, but it seems like most of the offsets offered in aftermarket wheels work perfectly for the Honderr crowd. *shrug*
2007 True Red Mazdaspeed3
I'm on the MySpace
kneedragger241 is offline   Reply With Quote
 Old 03-28-2008, 05:18 PM   #24
Young Roids
Lurkers
Posts: n/a
There is a dude on 24/7 with a set of 18x8.5 53mm offset. It fits on stock suspention but it is very close fit on the inside where the wheel clears the strut. I consider his setup the ultimate wheel setup I have seen on the MS3 to date. He would only be out done by some re30s in 8.5 width.
 Old 04-02-2008, 09:40 AM   #25
AutoXRacer's Avatar
Posts: 1,590   (View Stats)
AutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond repute
I want to run 235/40 on my RX-8 wheels...but all this talk on various forums about rubbing has got me going crazy!!!!
The stock 225/45 on the RX-8 are too narrow since the side walls taper in...
I was hoping the 235s would give a nice square fit. I will be buying Kumho MXs or Falken Azenis, and I know they run wider than all the other brands. So, I'm wondering if the 225 in a MX or Azenis tire will square off or the 235 be too wide and cause rubbing.
I just don't understand why there is so much variances within the stock setup of this car with rubbing issues; some don't rub, others do...??????
2008 Stage 3 Roush Mustang
302E 5.0L Stroker 647rwhp-620 rwtq
AutoXRacer is offline   Reply With Quote
 Old 04-02-2008, 10:43 AM   #26
Nliiitend1's Avatar
Groans: 67
It's like that with every car, in my experience. Unfortunately when you're working as close to the edge as we're trying to with these cars, you sometimes have to just try it for yourself. Equally unfortunate is that it can cost a lot to find the right setup by the time you're all said and done...
 Old 04-02-2008, 02:11 PM   #27
Crossbow's Avatar
Posts: 709   (View Stats)
Crossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the world
Where exactly are the rubs occuring? The rear fender lip? On the front struts? If its just the rears, couldn't you just roll the rear lip?
Crossbow is offline   Reply With Quote
 Old 04-02-2008, 02:30 PM   #28
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Rear lips.. Im rolling mine when i do the alignment.. Im going for 235's myself before summer.
 Old 04-02-2008, 03:15 PM   #29
Crossbow's Avatar
Ah ok. That's an easy enough fix. Want me to see if tireswap is still renting out his roller? Maybe you could get a bunch of CA guys together and do a rear fender rolling meet. Would pay for the rental!
If you're interested, I'll send you a pm with his email. The cost is 75 dollars with/heat gun, and a 300 deposit.
Same one as in this How-To Article I did back in 2004.
Mazda6Tech - Fender Rolling: A Photographic Journey
 Old 04-03-2008, 04:41 AM   #30
AutoXRacer's Avatar
I've read front strut and rear lip...
I'd rather not roll my rear quarter...
Hey Haltech, what size wheels are you going with for those 235s...?
 Old 04-03-2008, 06:55 AM   #31
I just got some 225/45-18 Potenza S03's and they aren't rubbing anything.
Of course, they are just sitting in my kitchen at the moment hahahaha!
I'm on the MySpace
 Old 04-13-2008, 09:41 PM   #32
Anklh's Avatar
Posts: 166   (View Stats)
Anklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond repute
I had rubbing on the left rear tire with 225/45/18 on my SSR's..that is until I purchased the Tire Rack fender roller. When the SO'3s are gone I am moving up to 245/40's
SSR stats are: 18x8 48 off
Anklh is offline   Reply With Quote
 Old 03-26-2014, 09:59 AM   #33
damimgoood's Avatar
Posts: 20   (View Stats)
damimgoood is on a distinguished road
How did those 225/45 grip ?
damimgoood is offline   Reply With Quote
The Following User Says NO Thank You to damimgoood For This Un-useful Post:
ArmanRus (03-30-2014)
 Old 06-20-2015, 07:37 PM   #34
ssspencerjr's Avatar
Posts: 11   (View Stats)
ssspencerjr is an unknown quantity at this point
I'm curious about this tire size.
I'm looking at getting the Enkei Raijin's in 18x8 for my car... stock suspension. Stock tires are 215/45 r18. According to TireRack.com those particular wheels cause the rear fenders to need rolling due to the wheels 45mm offset. Does anybody have this setup with stock tire size? Does the sidewall get pulled out and look bad?
And also, is 225/45 a better size for a 18x8 wheel? And would I have proper clearance on my car?
I really want those wheels I just don't know if the 225s are better than the 215s and which size (if any) give proper clearance with that size wheel.
Thanks in advance to whoever can help me out.
ssspencerjr is offline   Reply With Quote
 Old 06-20-2015, 08:10 PM   #35
ArmanRus's Avatar
Posts: 1,566   (View Stats)
ArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the worldArmanRus is the leader of the world
Groans: 42
I would do 18 x 8 +45 with 235/40 tires. That will put you much closer to the OEM diameter so you're speedo won't be off by much. If it does rub in the rear (I highly doubt it will), it's very easy to do a mild roll on the fenders.
ArmanRus is offline   Reply With Quote
 Old 06-20-2015, 08:12 PM   #36
Thanks for the information. How does this affect ride and performance with a narrower sidewall?
 Old 06-20-2015, 08:28 PM   #37
ArmanRus's Avatar
Groans: 42
It won't have a narrower sidewall (don't forget that it's a ratio) from a 215/45/18. Well technically it is narrower by 2.8mm, but that's splitting hairs. A 245/40/18 will be much, much closer, but you will might want a wider wheel with a proper offset for that.
Good luck!
 Old 06-20-2015, 08:29 PM   #38
Good luck!
Wider than 8 inches?
 Old 06-20-2015, 08:34 PM   #39
ArmanRus's Avatar
Groans: 42
Yeah. People usually run 18 x 8.5 for 245/40 tires. This is the set-up I have but if you're not willing to do extra work, stick with 18 x 8 and 235/40.
The Following User Says Thank You to ArmanRus For This Useful Post:
ssspencerjr (06-20-2015)
 Old 06-20-2015, 08:35 PM   #40
Thank you. I'll probably do the 235/40 setup It seems to be the max tire for the same overall dimensions per your advice.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f319/do-225-45-18-s-really-rub-201/
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 03-25-2008 09:57 PM
Page generated in 0.55429 seconds with 35 queries
