| MazdaSpeed 3/6 - Wheels & Tires HaveMazdaSpeed 3 - Wheels & Tires - Have a question about wheels or tires? Need a calculator to figure out offsets? We have them in here |
![]() | | #1 | ![]() |
![]() Join Date: Apr 2012 Location: Temecula, CA
Rep Power: 5431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,552
(Thread Starter) | Not Ranked : 0 score Is the mazdaspeed engine decoupled from this factor (tire rolling diameter of the tire) for the tune, or does it play a part? and what part does it play? Even though most of us change tires typically within 1" or so from stock, I am curious if there is any connection. Has this been discussed before? I couldn't find anything. Perhaps the +/- 5% tire size change is in the weeds and doesn't even make a difference. Maybe the tune doesn't even consider speed as a factor of the tune and only uses rpms? This isn't discussing tire/wheel weight; purely the impact that a larger or smaller tire circumference may have on the car's tune. |
| Police - Grammarhead ![]() Join Date: Sep 2009 Location: Metro Detroit, MI
Rep Power: 3749 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,748
Groans: 1,911
1) As you noted, the larger diameter has an impact on the wheel-speed. While wheel-speed is not generally a large factor in the tune... 2) RPM, obviously is. Moreover, much of the basis on which our ECU seems to perform its calculations is based on Load in relationship to RPM. 3) Load ABSOLUTELY CHANGES when you increase the diameter of the wheel. Basic mechanics teaches us that the larger the diameter of the wheel, (generally) the larger the inertia of the wheel. This means that in order for our engines to turn larger-diameter wheels, they have to work significantly harder than when the wheels are stock sized or smaller. As a result, you may see significantly higher load values when you log after fitting taller/wider wheels and tires. As a result, it's certainly possible that you could hit whatever load-cap remains in our ECU earlier with larger wheels than with smaller ones. 4) If memory serves, I think there are only a couple of tables that have anything to do with ECU calibration for wheel-speed. The most pertinent (and possibly overlooked) would be the gear ratio tables. If you calculate the change in wheel-diameter properly and can account for it in those tables, you might be able to re-calibrate your speedometer to account for the modification. This might (though I seriously doubt it will make much of a difference) change how the car's load calculations are run.
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! ![]() | |
| The Following User Says Thank You to Vansquish For This Useful Post: | dale_gribble (11-26-2012) |
![]() Join Date: Sep 2009 Location: Rosemead, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 717
Groans: 27
| Not Ranked : 0 score changing tire sizes effects gearing ....not sure about a tune, possible
__________________ 08 MS3 () Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, Autotech CDFP internals, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, NGK iridiums IX () Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms () Centric Slotted Rotors/ Posi-Quiet pad () Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90 |
![]() | | #4 | ![]() |
(Thread Starter) | Not Ranked : 0 score All I know so far is my mileage improved about 10% since I put back on stock diameter tires. All of my baseline logs are at 70-90F before the tire change, and it has been cooler here so I haven't been able to run a comparative log run. |
![]() | | #5 | ![]() |
Groans: 1,911
I'd guess that with such a combination, your mileage might improve, BUT, that would also hinge on how hard the engine is working (calc load) at lower RPM to maintain the same speed. I know that when I switched from my stockers 18x7.5 with 225-40-18's to my RX8s (18x8 with 225-45-18), my fuel economy also decreased by ~10% (33mpg highway down to 30mpg).
![]() | | #6 | ![]() |
![]() Join Date: Nov 2010 Location: rockledge fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,125
| Not Ranked : 0 score Afaik load is a function of air pressure and volume for a given rpm as measured by the engine's sensors. The only impact wheels and tires could have is rolling resistance and inertia. Tapatalking
__________________ DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob Megan Racing Coilovers 13.7@ 96 w/1.8 60ft (SRI, AP) 13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's) ![]() |
| impact questions | snOhio | 2010 MS3 - Wheels & Tires | 6 | 08-30-2011 04:39 PM |
| Pairing new tire and old tire bad for front diff? | smakdown61 | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 01-24-2011 08:55 PM |
| Anyone fine tune there shifter and tune out a second gear grind? | stevessvt | MazdaSpeed 3 - Engine, Transmission & Driveline | 15 | 10-21-2009 12:06 AM |
| Titan Tire ships world's first 63-inch tire | Haltech | Automotive News | 3 | 07-31-2008 02:45 PM |
| GMC Sonoma Stalls, Sugar in the Gas Tank, Correct Tire Pressure, Ford Escape Tire Shimmy: Mike Allen's Weekly Online Aut | Haltech | Automotive News | 0 | 07-25-2008 02:30 PM |
