 Old 03-25-2010, 03:56 AM   #41
Dizzel's Avatar
Posts: 168   (View Stats)
Dizzel has a reputation beyond reputeDizzel has a reputation beyond reputeDizzel has a reputation beyond reputeDizzel has a reputation beyond reputeDizzel has a reputation beyond reputeDizzel has a reputation beyond reputeDizzel has a reputation beyond reputeDizzel has a reputation beyond reputeDizzel has a reputation beyond reputeDizzel has a reputation beyond reputeDizzel has a reputation beyond repute
Originally Posted by Arrowpoint View Post
It's supposed to rain tomorrow so the pics won't be great but I'll go ahead a shoot a few for you. I can tell you that with the 225/45/18 and the 7.5 x 18 48 RPF1's the wheel wells look full. I took a tape measure and measured from the widest point on the tire to the outside edge of the wheel well and the tire is less than 1/2 inch short of being flush at the top. The space between the outside diameter of the tires and the inside edge of the wheel well ranges between 1 inch on the sides to 1 3/4 inches at the top.
Thanks for the info. I'll keep that in mind when comparing prices.
Dizzel is offline   Reply With Quote
 Old 03-25-2010, 07:43 AM   #42
Arrowpoint's Avatar
Posts: 364   (View Stats)
Arrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the world
Default Crappy flash pics of a dirty car.
I'm ashamed of myself but you wanted them soon!
Arrowpoint is offline   Reply With Quote
 Old 03-26-2010, 02:10 PM   #43
Dizzel's Avatar
The wheels look great! I hope your happy with them.
Quick question. How often do you carry a full load? At least once a month I carry four adults. In the spring I put the seats down and load it up with mulch. I was just wondering how often people use the utility of the car as opposed to just driving by themselves. I assume this would cause an extra rubbing concern. Unless the inner fender is really concave.
You could squeeze 235/40s on the 7.5 rim, but technically it's considered half inch below minimum. To me that's a safety issue so I wouldn't, but a lot of people do.
Is there some sort of guide I could see that would show the "safe" tire sizes in relation to wheel width?
 Old 03-26-2010, 02:23 PM   #44
bnoon's Avatar
Posts: 1,770   (View Stats)
On tire rack dot com you can click on a tire you like, click on "Specs" and there's a chart that shows recommended wheel widths for that and other sizes as well.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
bnoon is offline   Reply With Quote
 Old 03-26-2010, 10:43 PM   #45
Arrowpoint's Avatar
What I have learned from this thread and looking at the tires and wheels I bought is that wider is possible as long as the wheel diameter is not too large and the offset isn't too much or too little. The set I bought 225/45/18 wihi 48 pffset clears the struts in the front by around 3/4 - 1 inch and about 1 - 1 1/2 inches in the rear. If I had gone with 235/45/18 on wheels with a 48 offset I think I would be very close to touching the struts at least in front. So maybe 50 offset would be in order to move 235/45/18 tires outward a little. Too much outward and because of the 45 aspect ratio you would be risking rubbing on the wheel well so you would need to go to a 40 aspect ratio to reduce the tires diameter. One thing to keep in mind is that at lower speeds wider tires require more streering effort because you are working againt more fricton due to a larger area of tire against the pavement. At higher speeds this effect is reduced. Narrower tires have the opposite effect. they turn easer at low speeds but can be less sticky at High speads due to a smaller surface area against the pavment. I believe that the wheels and tires I got are the widest tires I would consider for my application. I do load it up with two to thee weeks provision and take long road trips in it
So if you plan to go with 235/18 i would advise 40 aspect ratio and a little more than 48 offset. Correct me if I'm wrong I'm just learning this stuff and I took an ambien about a half hour ago.
****I had to edit this after seeing that it made it appear that I bought 235 tires when in reality I bought 225. My bad.
 Old 03-27-2010, 09:48 AM   #46
spheed3's Avatar
Posts: 487   (View Stats)
spheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond reputespheed3 has a reputation beyond repute
Hey arrowpoint, how much clearance do you have in the fender well with the wheel at full lock? I have the same wheels on stock suspension looking at getting the same tires but I'm concerned about the larger tires making contact with my Rally Armor mudflaps.
Black Mica 08.5 GT
I'm parting out. Buy my stuff: http://www.mazdaspeedforums.org/foru...ing-out-59908/
spheed3 is offline   Reply With Quote
 Old 03-28-2010, 01:17 PM   #47
Arrowpoint's Avatar
I measured on the front left and with the wheel turned left all the way to the stop I have about .5 inches. With the wheel turned right to the stop about 2.5 inches. Keep in mind that there was a typo in my earlier post. These are 225/45/18.
The Following User Says Thank You to Arrowpoint For This Useful Post:
spheed3 (03-28-2010)
 Old 03-28-2010, 04:11 PM   #48
spheed3's Avatar
Thank you, I think they should clear just fine. Time to order some tires
Black Mica 08.5 GT
 Old 03-29-2010, 01:24 PM   #49
Dizzel's Avatar
Thanks for the continued info Arrowpoint. I like how you wheels look and think the smaller size will help control the price.
Can any wheel be fitted with the TPMS or do you need a wheel designed for it?
 Old 03-29-2010, 01:41 PM   #50
Arrowpoint's Avatar
I'm not one hundred percent sure, Dizzel. But I would think so since it's just a valve stem with a transmitter built into it. It doesn't appear that tire rack did anything but install them in place of the regular valve stems.
File Type: jpg vdo_pp_sensor_TPMS_300dpi_13x18cm_zoom.jpg (33.6 KB, 15 views)
 Old 03-30-2010, 10:18 AM   #51
Dizzel's Avatar
That's what I thought. I really want the Enkei EKM3 in gunmetal but as of right now tire rack is only offering it in bright silver. After all this up sizing excitement I am now being beat down by price. May only increase width to 7.5.
 Old 03-30-2010, 01:44 PM   #52
bnoon's Avatar
...with a 48 offset I think I would be very close to touching the struts at least in front. So maybe 50 offset would be in order to move 235/45/18 tires outward a little.
Just to correct you, going from a 48 offset to 50 offset moves the tires/wheels INWARDS, not OUTwards as you stated. There are people running 18x8 50 offset RX8's with 245's on them and not touching the struts, so your 235 statement is wrong all around. Also depends on if the tires used have rim protection beads though too since those stick out more on the sides. Brand of tire and series of tire change things also...
2002 BMW M3 - Sold!
 Old 03-31-2010, 05:05 AM   #53
Arrowpoint's Avatar
Default Re: Enkei RPF1 18x7.5 5x114.3 48 off set
Thanks for the correction, Bnoon. When you consider all these variables, I don't know how anyone can know what fits other than a tire tech who has learned by trial and error. It seems like it should be simple but to me anyway its not. It would be cool if someone with access to different tires and wheels could build a photo data base of what fits.
Sent from my SPH-M900 using Tapatalk
 Old 04-12-2010, 03:26 AM   #54
Ms3speed's Avatar
Posts: 172   (View Stats)
Ms3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud ofMs3speed has much to be proud of
Groaned at 10 Times in 4 Posts
Default 18x8 40et
Hey guys I have 18x8 Motegi sp10 wheels with a 40et from what I have been reading It seems like I might have some trouble with lowering it. I am at stock ride height now with 225/40 tires and no problems at all but I have some H&R sport springs that I am dieing to put in but I don't know if I need new wheels or not I was looking at getting some Eneki Ev5s in 18x7.5 45et will I need to roll my fenders still with the 225/40tires? H&R springs are 1.3"f, 1.2"r for the drop -thanks-
Ms3speed is offline   Reply With Quote
 Old 12-01-2010, 08:15 AM   #55
jbauer's Avatar
Posts: 11   (View Stats)
jbauer will become famous soon enoughjbauer will become famous soon enough
Looks good. Black would have looked better on the MGM, but i'm partial to the black RPF1's since that's what i have. The wife got them as a gift a year or so ago. Love the rims but i do wish they were wider. I may switch to a 17x9 in time.
Still congrats on them though.
jbauer is offline   Reply With Quote
 Old 12-02-2010, 04:02 AM   #56
dastpe's Avatar
Posts: 1,644   (View Stats)
you will likely need a small roll in the rear. no big deal.
 Old 02-20-2011, 10:38 PM   #57
Duk
Duk's Avatar
Posts: 31   (View Stats)
Duk has much to be proud ofDuk has much to be proud ofDuk has much to be proud ofDuk has much to be proud ofDuk has much to be proud ofDuk has much to be proud ofDuk has much to be proud ofDuk has much to be proud of
This was a really good read =) Im about to purchase some zr+520 in the same offsets, looks more flush then i thought it would =) !
Duk is offline   Reply With Quote
Enkei RPF1 19x8 Radar_This Wheels & Tires - SILVER 40 05-02-2011 05:52 AM
Enkei RPF1 Wheels!!! Race Roots Mazdaspeed3/6 General Discussion 19 02-03-2010 06:09 PM
enkei rpf1 17x9 +45 245/45/17 steven88 MazdaSpeed 3/6 - Wheels & Tires 22 04-23-2009 12:36 AM
Page generated in 0.36965 seconds with 28 queries
