Evo X Wheels So I recently picked up some evo x wheels that came with lugs + TPMS sensors and had my fenders rolled to put them on. When driving away there was some grinding noise so I went back and he checked it out and tried tightening them but nothing really happened...My studs are now stripped because the lug wasn't long enough. So my question is, before i buy the lugs and studs, is if I need longer studs than the OEM ones and if I should use the OEM evo lugs? And before I get yelled at, I googled and searched everywhere to see what I need to do and didn't find much of anything, so to those that can help me out it would be greatly appreciated as I would like to get my car back on the road ASAP |
I have evo x wheels on my speed and i'm using the oem mazda length lugs and they hold just fine. The problem you might be having is due to the lug nuts your using. You cannot use acorn style lug nuts like what the ms3 uses. These require special mag style lug nuts with the washer to hold these wheels in place to the hub because you'll see the contact point where the lug holds the wheel is flat. I had used my stock ms3 lugs for the first 50 miles and couldnt figure out why the wheels were all loose even though the lug nuts were tight. I then discovered you need mag style lug nuts. I picked mine up at NAPA for $2 each vs $8 each from the Mitsubishi dealer. So i'm going to assume that is your problem is you are using the wrong lug nuts. Even if you received lugs when you bought the wheels, they could have been the wrong lugs provided to you from the previous owner. Try replacing the lug nuts and see if that fixes your problem. Sent from my Transformer TF101 using Tapatalk 2 Quote:
Sent from my Transformer TF101 using Tapatalk 2 |
20 Mitsubishi OE Stock Factory Wheels Rims Mag Lug Nuts 12x1 5 1 5 Black | eBay Did you need extended studs or will I be fine with ordering the mazda ones and using the lugs in that link? |
They're also known as "shank style" lug nuts. ;) |
@Nliiitend1 thank you, so I do not need extended studs either? |
I don't think so. ...at least I've never heard any of the guys I know of who are running them (Evo Xs) mention that they needed longer studs... |
What size tire are you running on the wheels? |
1 Attachment(s) Quote:
Attachment 91538 |
http://www.esimaging.net/photos/i-Fs...-FsPc3SD-L.jpg Sent from my SCH-I535 using Tapatalk 2 |
im picking up my evo x's tmrw with tires 245/40. Is there any other stuff I should do other then fender roll in the rear and proper lug nuts? |
I bought spare lug nuts from ebay, OEM mitsus for $20 shipped. It's the cheapest route I found. I needed a couple extras but had a hard time finding them so I now have a whole set. OEM studs are right, extended will cause other issues. |
whats the fender roll situation while being dropped with 245 tires? |
i eneded up not going threw with it kid said he would sell me just the rims when he sells the tires...might just do 15mm spacers with my ms6 rims. |
im also on 245s fenders rolled and shaved, i only rub a little on bumps but no big deal, i love the 245s Sent from your Anus |
I will try to get out and get some pics later on today as well |
I have the acorn-style lugs on my gen1 with Evo X wheels and they fit just fine, weird. |
Sent from my iPhone using Tapatalk |
4 Attachment(s) Here's some pics that I was finally able to take over the weekend :cool: |
4 Attachment(s) some more |
:bigok:Those pics are awesome, no question I will be going for evo wheels as soon as I can find some for a reasonable price. |
Any idea on weight difference from stock gen1 rims to the Evo X's? |
Evo X GSR rim = ~21 lbs. |
Sent from my PC36100 using Tapatalk 2 |
I weighed my stock MS3 wheels with 225s and the total was 51 lbs. The X wheels with 245s was 43 lbs. http://i16.photobucket.com/albums/b4...C420DD82E0.jpg |
Gen Won rim = 7" Evo X GSR rim = 8.5" |
Yep, lighter, wider, and better-looking; win-win-win. |
Really should have asked all these questions in the 1 post, but what's the offset difference? Really thinking I'll end up getting a set of these. Sent from my LG-P880 using Tapatalk 2 |
X offset = +38 |
Hey guys, I've been riding on my Evo X wheels for over 15k miles and I love them. Have the rear fenders rolled and the bumper bracket shaved. THe entire time I've been riding on slightly stretched OEM (215/45R18) size tires since they were still in good shape ever since I got the wheels. Recently I started having tire pressure issues, one wheel in particular was giving me the most issues since I had to constantly add pressure once every three to four days. It turns out the grommet for TPMS valve stem was cracked, and the washer was bent. Remaining three deflate at a lower rate, but deflate nontheless. I transfered all OEM TMPS sensors onto EVO wheels which I'm now not so sure was the right thing to do. Do you guys have any tire pressure issues with stock TMPS on these wheels? Also planning to go to 235/40R18, I'm hoping the right fit tire will prevent these slow air leaks, but I'm also curious on Mazda to EVO X TPMS fitment. Thanks.:burnout: |
I bought mine with tires, TMPS, and what was supposed to be the right lugs for 680 off craigslist. I wasn't the biggest fan of the stretch as I'm running 205/35s i think, but the only other option at the time was the oem 245s but I don't think that those would've worked with a drop. I think for my next set I am going to go for 225 or 235. After driving on the stretched tires though, I do not mind it that much because I have the oem wheels for the canyon or whatever. Also with a roll all around I rubbed for the first time up front the other day on a nice long sweeping right on ramp |
I'm running 215/45 on evo X wheels for now. Stock tpms. No issues. I had my tpms rebuilt at discount tire. I'm going with a wider summer tire though once it warms up.. Sent from my SCH-I605 using Tapatalk 2 |
So is the consensus that we use our mazda oem TPMS and just rebuild it on the new wheel? |
4 Attachment(s) So a little update on my side. Removed the problematic TPMS and discovered that the washer which seats the rubber grommet is deformed around TPMS housing. Anyone who transferred TPMS themselves have ever seen this deformation? The grommet is in fact damaged either due to deformation or over-tightening of the bolt. See attached pics. So now I'm running without TPMS on one wheel with a generic valve stem and guess what? I'm still leaking air on that one wheel. I'm starting to think that the problem is not just TPMS but also the tire stretch. I drive aggressively at times and possibly during hard cornering, the tire tends to unseat itself...either its because its already an old tire or it may not have been installed properly in the first place. What do you guys think? I want my current tires to last for at least three more months. I will be buying 235/40R18 tires soon...hope the issue will go away. |
Luckily mine came with the tpms sensors so that was one less worry; as for the aggressive driving, I dont know if thats the issue cause I hit the canyon the other night and had rubbing issues before traction issues and they held air after. Still dont like to drive hard on the stretch though, I feel like the lip is going to rub on the ground :wall: |
Your car is so clean. I hope to get mine there one day. Was going to go with some black wheels, might look in this direction now. :35: |
Alright so let me recap just so I'm clear for when I put my evo x enkeis on. #1 use oem evo lugs or shank lugs #2 use your oem Mazda studs #3 if you're dropped roll/shave fenders #4 also if you want to stay dropper without rub run 225s or lower #5 proper tpms install I have some evo x wheels I'm putting on my car. Plan on running 225/40s on bc coils. Not supper dropped and trying to obviously avoid all rubbing without running too much camber. Guess I need to pick up some lugs now. |
Um..with regards to #3 , my understanding is that regardless of being dropped or not if one would want to run 235 or more width tires then they need to roll/shave. With regards to #4 , I think some members here that are running EVO wheels and are dropped and are rolled/shaved run more than 225 without issues. |
cool. I would really like to run 235s. Pretty sure I can run 235 35s on it. I have a used tire shop that hooks me up and I planned on test fitting some tires then buying a new set of what ever I like. |
:yo:If anyone happens to run into a stud problem, I have some leftovers that the dealer won't take since I did not return them within a certain period of time |
Has anyone used the stock mitsu TPMS sensors? I checked on Rock Auto and there is a generic TPMS that shows up for both the Evo X and the Speed so I'm assuming we use the same frequency. If so, what did you have to do to get them to sync? When I replaced the TPMS on my old 3Sport I had to do some procedure involving the brake. Also, when you roll you front fenders what happens with the splash guard? |
Sent from my SCH-I535 using Tapatalk |
How many people run theses without TPMS? Is the only downside the warning light on the dash? |
Rolling the fronts? I thought only the rears have to be rolled. |
| All times are GMT -7. The time now is 09:17 AM. |
