 Old 02-24-2015, 08:00 PM   #1
JTD
JTD's Avatar
Posts: 49   (View Stats)
JTD is a jewel in the roughJTD is a jewel in the roughJTD is a jewel in the roughJTD is a jewel in the rough
Default Extended studs
Hey everyone,
I will be in the need of spacers and looking at extended lug options and was browsing through the Dorman OEM catalog and saw these.
I know the knurl is 12.8mm and ours is 12.9-13.00 from what I have read. Will this cause them to be too loose? It seems like a very small difference.
M12-1.50 Serrated Wheel Stud - 12.80mm Knurl, 54mm Length
Application Summary: Hummer H3 2010-06, Hummer H3T 2010-09
Application Attributes:
Style: Serrated Stud
Package Quantity: 1
Thread Size: M12-1.5
Knurl Diameter (In): 0.5039
Packaging Type: Bag
Shoulder Length (In): 0.3149
Stud Material: Steel
JTD is offline   Reply With Quote
 Old 02-25-2015, 11:10 AM   #2
nekret's Avatar
Posts: 421   (View Stats)
nekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the world
considering it's a press fit and a royal PITA if it spins, i'd keep looking.
2011 Mazdaspeed3 non-tech package
Drivetrain
CorkSport 3.5" MAF & TIP | CP-E FMIC | Synapse BPV | CorkSport EBCS (Interrupt) | Bosch 3 bar MAP | CorkSport HPFP Internals | CP-E Catted Downpipe | CP-E Triton 3" CBE | JBR Stage 2 OCC | Kozmic Primary EGR Delete | JBR Secondary EGR delete | NGK 6510 | TB coolant Bypass | JBR IM & TB Gaskets | Damond RMM, PMM, & TMM | JBR light shift weight | TWM Full Replacement Shifter | Cobb AccessPort V3 | FreekTune
Chassis
JBR Front & Rear Sway Bars | JBR Billet Rear Sway Bar Brackets | Whiteline Adjustable Front&Rear sway bar links | JBR Coilovers | Corksport BBK | Corksport Lower Tie Bar | Corksport Mid Chasis Brace
Rice
LED bumper reflectors | Morimoto LED Fog lights | VLEDs LED Highbeams | Independent Fogs | AP Engine & HPFP cover | CorkSport Pulleys | Corksport Leather Shift Knob | Corksport Steering Wheel | Damond front plate mount | Lukas LK-9750 2ch dashcam | Eonon GA7163 | thespeedline.com blue mirrors | thespeedline.com hood dampers
nekret is offline   Reply With Quote
 Old 02-25-2015, 12:57 PM   #3
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
Chevrolet spec studs have been used by others in the past with sucess.
I hugged rfinkle2
JSmith (02-25-2015)
 Old 02-25-2015, 02:58 PM   #4
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
Lots of good info here:
ARP wheel studs for MS3
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
Page generated in 0.25946 seconds with 23 queries
