 Old 02-02-2012, 02:58 PM   #1
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
SleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the world
Groans: 52
Groaned at 54 Times in 39 Posts
Default Getting tires need reccomendation
I'm going to be picking up a set of XXR 527's with a +35 offset so I'll be needing new tires as well. I've been looking at the Hankook Ventus V12's and the Continental DW's. Both seem to have good reviews and more seem to be leaning towards the Continentals. I'm looking to run atleast a 235/40/18 and the Continentals actually come out about $30 cheaper as well.
I was having a hard time finding out the actual milage rating on each tire but from a few calculations I did the V12's look to last about 20k miles and the DW's about 25k miles.
Advice? Opinions?
2009 CWP Speed3
SleeperHatch is offline   Reply With Quote
 Old 02-02-2012, 05:02 PM   #2
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
FWIW, I'm running the DW in a 225/45 for about 6000 miles now, and if I was to go get new treads today, it would be the same DW but in a 235/40.
Surprisingly sticky bastards wet or dry, and still #2 in the tire rack ratings for Max Performance Summer
Consumer Survey Results By Category
340hp / 371tq
rfinkle2 (02-15-2012)
 Old 02-02-2012, 05:05 PM   #3
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
Advice? Opinions?
If you're doing your calculations based on treadwear ratings you may find them to be sort of useless.
Different manufacturers use different standards for their ratings so, for instance, a 200 treadwear tire of one brand is not equivalent to a 200 treadwear tire of another manufacturer.
Just FYI in case you weren't aware...
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
The Following 4 Users Say Thank You to Nliiitend1 For This Useful Post:
ak_spray (02-15-2012), IshiKage (02-02-2012), rfinkle2 (02-15-2012), silvapain (02-15-2012)
 Old 02-02-2012, 05:52 PM   #4
Groans: 52
Yeah thats actually what I was referring to. I see now I though it was more of an industry standard thing. Also I was thinking about getting another pair of tires, possibly the RS-3's for track days and then using the v12's or dw's for my daily tire. Advice or opinions on that?
2009 CWP Speed3
 Old 02-02-2012, 05:58 PM   #5
Nliiitend1's Avatar
Groans: 67
With one set of wheels?
More options are never bad, though I run an "autocross/trackday" type street tire as my summer daily...
2008 MS3 GT
2016 MX-5 Club
 Old 02-02-2012, 06:00 PM   #6
TRSpeed's Avatar
Posts: 1,537   (View Stats)
TRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the world
Cale I have V12 they are great! So far 8k on them and they look almost like new. And you remember them pulling hard on you haha *wink*
Sent from my DROID2 GLOBAL using Tapatalk
2008.05 True Red Mazdaspeed3
Lex Tuned
GTX3071r | 38mm Tial WG | Hallman MBC
Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod |
Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM |
Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs
TRSpeed is offline   Reply With Quote
 Old 02-02-2012, 06:01 PM   #7
TRSpeed's Avatar
As for track tires get Star Specs, or Nt05 or rs3
Lex Tuned
 Old 02-02-2012, 06:39 PM   #8
Groans: 52
I would use the stock rims for the track tires...what is your tire as of now for the summer daily?
Sent from my Epic Win Avatar
2009 CWP Speed3
 Old 02-02-2012, 06:39 PM   #9
donkeyballs's Avatar
Posts: 62   (View Stats)
donkeyballs has a reputation beyond reputedonkeyballs has a reputation beyond reputedonkeyballs has a reputation beyond reputedonkeyballs has a reputation beyond reputedonkeyballs has a reputation beyond reputedonkeyballs has a reputation beyond reputedonkeyballs has a reputation beyond reputedonkeyballs has a reputation beyond reputedonkeyballs has a reputation beyond reputedonkeyballs has a reputation beyond reputedonkeyballs has a reputation beyond repute
I'm running falken azenis RT 615k's and they have a ton of grip but they wear fast. They work good in wet but they suck if its under 50*.
donkeyballs is offline   Reply With Quote
 Old 02-02-2012, 06:47 PM   #10
MS6FL's Avatar
Posts: 1,753   (View Stats)
MS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the world
Groans: 43
NT05
“From a business standpoint, the Boss 302 shouldn’t have happened. But it happened. My dream for the car was that it would make a lot of money for a guy street racing. It should be a car that winds up on YouTube doing something illegal. I’ve been waiting 20-plus years to launch a car like this.”-Jim Farley
MS6FL is offline   Reply With Quote
 Old 02-02-2012, 06:49 PM   #11
Groans: 52
How fast is fast? Lol
2009 CWP Speed3
 Old 02-02-2012, 07:02 PM   #12
TRSpeed's Avatar
Fuck you gale I told you to get star specs! Or NT05
Lex Tuned
 Old 02-02-2012, 07:08 PM   #13
I don't think i even got 4k out of them but my car spins like a mofo lol. I can honestly say they hooked about the same as my BFG DR's. It depends on your power level and how you drive though.
 Old 02-02-2012, 07:14 PM   #14
TRSpeed's Avatar
Gale = Noob
Tires= 1k life lol
Lex Tuned
 Old 02-02-2012, 07:19 PM   #15
08cosmic3's Avatar
Posts: 2,920   (View Stats)
08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world
Groaned at 54 Times in 43 Posts
V12's make a good daily tire. Good tire for the money and they seem to always have rebate offers on them. I have Bridgstone RE-11's on FD wheels as my Deals Gap set up and love them, they are pricey though.
EBTEC Manley Built // GT3071R // FreekTuned // Freek 3.5" Intake // Ported IM // Perm Plate Dual CC // Catless DP // CNT CB // Tokay V 1's // Autotech // AEM Failsafe // TR8 IC// GFB // JBR 88 RMM // DM PMM // JBR 70 TMM // ACT 6 puck prolite fly // Cobb RSB // 6 pc chassis braced // Koni FSD's // Cobb Springs // EGR Full delete // SWAS switch // SS brake lines // 100% Methanol Injection D14
____________________________________________Dragon Slayer _________________________________________________
08cosmic3 is offline   Reply With Quote
 Old 02-02-2012, 10:25 PM   #16
Groans: 52
Ok so I'm thinking v12's for daily tire and nt05 or rs3 for track depending on price
2009 CWP Speed3
 Old 02-02-2012, 10:40 PM   #17
Nliiitend1's Avatar
Groans: 67
I'd feel weird putting "track tires" on my 7" wide OEM wheels, personally...
The I just ran through a set of Hankook RS2s that I got when they were on closeout after being discontinued.
Before that, I rant a set of NT05s and before that, a set of Kumho XSs. All of these were on RX-8 wheels.
I'll probably be going back to the NT05s for my next set unless I can find a really good deal on some RS3s (only because I've yet to try them out). The NT05s are a phenomenal tire for the money, and they suit my driving well.
2008 MS3 GT
2016 MX-5 Club
 Old 02-02-2012, 10:44 PM   #18
Groans: 52
Honestly I was thinking the same thing my pops was telling me to do that instead of swapping tires on the same rim when I wanna go to the track. My buddy runs RS-3s on his s2k as a daily tire and loves them.
2009 CWP Speed3
 Old 02-03-2012, 02:09 AM   #19
TRSpeed's Avatar
Cale hurry and get your shit for March 3rd Nator Drag Nigga
Lex Tuned
 Old 02-04-2012, 04:18 PM   #20
Changeling's Avatar
Posts: 20   (View Stats)
Changeling is on a distinguished road
Groaned at 6 Times in 2 Posts
23K miles and I'm down to 3/32 on the same size DW's. I do love the tires though. I couldn't tell they were wearing so thin until Discount Tire measured. The "D" and "W" are still in tact too, so I was like WTH?
Changeling is offline   Reply With Quote
 Old 02-15-2012, 05:53 AM   #21
dastpe's Avatar
Posts: 1,644   (View Stats)
Advice? Opinions?
I actually run sumitomo htr z3 and like them a lot. decent all around tire, just a little treadnoise in corners.
as far as running 235 on a +35...what width? 8",8.5",9"?
 Old 02-15-2012, 06:07 AM   #22
jwright32's Avatar
Posts: 86   (View Stats)
jwright32 is just really nicejwright32 is just really nicejwright32 is just really nicejwright32 is just really nice
I have had my set of hankook v12's now for about 9k miles, and they still look good. I expect to be get another 10k or so from them. Traction has been good i feel, but i think i want to try the DW's on my next set.
-- 2010 Celestial Blue Mazda Speed3 -- Cobb AP, CP-E Nano SRI ,18x8.5-e48 Rota G-Force [Hankook V12 Evo 245/40/18], Sure Motorsports Shifter Busings, JBR 80a RMM, JBR SSP, DDM 35w 6000k HID Lows/ 35w 3000k Fogs, UR Testpipe, Res. Delete, TWM M1 Abrams shift knob
jwright32 is offline   Reply With Quote
 Old 02-15-2012, 06:11 AM   #23
If your looking for a tire that's sticky as hell in the wet or dry and ever so slightly softer in the sidewall to ease that daily driver commute, the DW is your huckleberry
340hp / 371tq
 Old 02-15-2012, 06:20 AM   #24
obijack's Avatar
Posts: 1,830   (View Stats)
obijack is the leader of the worldobijack is the leader of the worldobijack is the leader of the worldobijack is the leader of the worldobijack is the leader of the worldobijack is the leader of the worldobijack is the leader of the worldobijack is the leader of the worldobijack is the leader of the worldobijack is the leader of the worldobijack is the leader of the world
Groaned at 70 Times in 24 Posts
toyo proxes 4 or t1r's.
2004 Dodge Dakota- SLT 4.7L V8- Burgundy
2013 Kawasaki Ninja 636 (Zx6r)- Green/ Black
2014 Honda Grom-Red
2014 Yamaha Grizzly 350- Blue
2007 Yamaha Raptor 700 GYTR- White-
obijack is offline   Reply With Quote
 Old 02-15-2012, 06:26 AM   #25
Nliiitend1's Avatar
Groans: 67
Both of those tires are old news and have been eclipsed by several of the newer offerings available.
2008 MS3 GT
2016 MX-5 Club
 Old 02-15-2012, 11:28 AM   #26
Groans: 52
Right now I'm between the rs3's and star specs
2009 CWP Speed3
 Old 02-15-2012, 11:51 AM   #27
Onelovesoccer's Avatar
Posts: 1,364   (View Stats)
Onelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the world
Groans: 116
Groaned at 13 Times in 7 Posts
i just got the v12s for $150/tire on tires-easy.com. they were rated higher than the DWs in a few reviews i came across. they are certainly stickier. but the DWs sound like good tires too and will last longer.
i feel like RS3s or Star Specs are going to perform amazing. RS3s will be more sticky but won't last as long.
2010 Liquid Silver w/ Tech Package
270whp/324wtq corrected Dynojet 3/24/12 (93 FREEKPerm)
Cobb AP (91 RichTune) | CS SRI/TIP | cp-e S2 RMM | SURE Shifter Bushings | JBR SSP/Counterweight | UR TP | UR CBE | AT Internals | Denso ITV22s | 35% tint | Sonic Tuning HIDs | MD OCC | JBR TIGs | TSW Nurburgring 18x8.5+45 245/40/18 v12 evo2
Onelovesoccer is offline   Reply With Quote
 Old 02-15-2012, 12:55 PM   #28
mzr0818's Avatar
mzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the world
Groans: 221
Ventus v12's on for 30k miles and 4/32" now all the way around. goos sticky tire for daily use
I was ok until 4500 rpm and then Jeff Raped my face
EMWNM 2013
Beating Black women one 5.0 at a time...
2008 mazdaspeed 3 true red
Tuned by Nishan
, 33% E85, GTX3067r Boost?, Yeah I got some., Port and polish manifold, XS power Tubular Exhaust Manifold, Wiesco pistons, K1 rods, L19 head studs, ARP crank studs, Cobb three port EBCS, Forge BPV, CXRacing FMIC with TR8 core, cobb AP V2, EBC redstuff full, DBA 4000 rotors 6x6 slotted, HTP 3" full intake, JBR 88d rmm, JBR 80d pmm, JBR 80d tmm, CNT catted DP, Magnaflow CBE, KMD internals, Koni Yellows, Moog endlinks, Moog lower control arms, OZ ultraleggera 18x8, Mich Pilot Super Sports 235/40/18, Hotchkis RSB, NGK step colder plugs.
Build in progress. Track whore in the making.
mzr0818 is offline   Reply With Quote
 Old 02-16-2012, 04:51 PM   #29
obijack's Avatar
As far as tred wear compared to grip its hard to beat the t1r's. I had
225/40/18 and paid 122 per tire.
2014 Honda Grom-Red
The Following User Says Thank You to obijack For This Useful Post:
bazzarino (03-18-2012)
 Old 02-28-2012, 11:14 PM   #30
kylec_2003's Avatar
Posts: 175   (View Stats)
kylec_2003 has a reputation beyond reputekylec_2003 has a reputation beyond reputekylec_2003 has a reputation beyond reputekylec_2003 has a reputation beyond reputekylec_2003 has a reputation beyond reputekylec_2003 has a reputation beyond reputekylec_2003 has a reputation beyond reputekylec_2003 has a reputation beyond reputekylec_2003 has a reputation beyond reputekylec_2003 has a reputation beyond reputekylec_2003 has a reputation beyond repute
Anyone ever run the BF Goodrich g-force KDW's? I ran them on my last car and liked them but I didn't corner as hard in that car.
Corksport SRI/TIP | CP-E Stage 2 RMM | JB SSP/Bushings | DDM HID 6K Hi/Low beams | Cobb AP | CP-E HPFP | 5% Tint | UR Test Pipe | ITV 22's | Turbo Smart 50/50 BOV |
kylec_2003 is offline   Reply With Quote
MS6.. back tires 30% tread, front tires 90% tread.. will this cause an issue with driveline damage? squale MazdaSpeed 3/6 - Wheels & Tires 7 04-27-2010 09:54 AM
Winter Rims/Tires Package or just Tires? Amber3 MazdaSpeed 3/6 - Wheels & Tires 12 12-02-2009 12:20 AM
Q Tires testing Celsius retractable-stud snow tires Haltech Automotive News 0 04-01-2008 10:40 AM
Page generated in 0.47911 seconds with 33 queries
