 Old 07-27-2008, 10:55 PM   #1
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
Default good tires for good handling
i want my car to handle really well...
would an 18 or 17 inch wheel work better?
what are some good tire recommendations for tires that won't brake the bank?
please recommend offsets along with tire sizes as well...i'm a n00b at this
 Old 08-02-2008, 02:26 AM   #2
speed3's Avatar
Posts: 504   (View Stats)
speed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant future
Groans: 56
Groaned at 43 Times in 21 Posts
stock tires are the best out their period. Ask any tire shop and they will tell you the same thing. As far as rims, Try to find rims that the offset is same as stock which is 52. I went with 17x8.5 48 offset with 235-45-17 and no rubbing at all. If u find something closer to 52 you can go more than 235.
2008 BM..MSCAI..8K HID..MAGNAFLOW CB..<----- SOLD
Current car: 1991 Sport 600 Z32. 487whp on 91 Octane
speed3 is offline   Reply With Quote
The Following 5 Users Say NO Thank You to speed3 For This Un-useful Post:
 Old 08-02-2008, 05:56 AM   #3
Lymerock's Avatar
Posts: 1,436   (View Stats)
stock tires are the best? I strongly disagree.
do 17's or 18's work better? hmm... impossible to break it down that simple
how about, 17's are cheaper than 18's and will provide a softer ride than lower profile 18's (generally speaking) due to a taller sidewall, but gives up a bit of steering response and turn in crispness to a shorter/stiffer sidewalled 18.
I run 245/40/18's on a 18x8 +50, if you want to run 245's you gotta be damn close to the stock offset of 52.5
if you want to run a 235, you can prolly run an offset as low as +45
if you want to run a 225, you might be able to get away with a +42
if you stick with the stock width, you might be able to get away with a +38, but it will look geeked and the stock width is perfect for a yaris.
buying rims/tires takes homework and a bit of knoledge about what the numbers mean but its not rocket science
The Following 3 Users Say Thank You to Lymerock For This Useful Post:
Demi (09-15-2008), phillyb (08-05-2008), SgtP (09-15-2008)
 Old 08-02-2008, 06:39 AM   #4
Demi's Avatar
Posts: 1,107   (View Stats)
Demi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the world
Groans: 61
Groaned at 16 Times in 11 Posts
You need to find a new tire shop. Thats far from true. Im running nt-555 on stock rims. Bumped it up to 225 40 18s. The difference in handling and acceleration traction was stunning.
Beginners guide to turbos<- New to this? Give it a look!
-And for the rest of you, if it comes from Autozone and doesnt replace something that broke off your car or make your cabin smell like Coco Butter, its fucking rice.
Demi is offline   Reply With Quote
 Old 08-02-2008, 11:37 AM   #5
twisted99's Avatar
Posts: 50   (View Stats)
twisted99 has a brilliant futuretwisted99 has a brilliant futuretwisted99 has a brilliant futuretwisted99 has a brilliant futuretwisted99 has a brilliant futuretwisted99 has a brilliant futuretwisted99 has a brilliant futuretwisted99 has a brilliant futuretwisted99 has a brilliant futuretwisted99 has a brilliant futuretwisted99 has a brilliant future
Groaned at 6 Times in 2 Posts
You need to be more specific on what type of weather you want handling. The stock tires are ok but by far not the best. If want dry weather handling for a great price I would look at the Falken Azenis rt-615s in a 225 or 235 width and look for a 7.5 inch wide rim. If you dont mind rolling your fenders go to a 8.0 inch wide rim and look at 245s or even 255s
twisted99 is offline   Reply With Quote
The Following User Says Thank You to twisted99 For This Useful Post:
 Old 08-02-2008, 12:25 PM   #6
speed3's Avatar
Groans: 56
I got the potenza 760 just because tread life is 340 compar to the stock ones that are 140. Is not always about super grip, How about the steering response? Or road noise. I'm sure they are better tires out their than stock that grip more, but ride quality is not going to be the same.
The Following User Says NO Thank You to speed3 For This Un-useful Post:
 Old 08-25-2008, 10:52 AM   #7
FCmaniac's Avatar
Posts: 330   (View Stats)
FCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond repute
Falken Azenis RT615's. I just got mine from Edge Racing. You can't get a better performance per dollar tire.
FCmaniac is offline   Reply With Quote
 Old 08-26-2008, 02:04 PM   #8
zpeedfreak's Avatar
Posts: 40   (View Stats)
zpeedfreak will become famous soon enoughzpeedfreak will become famous soon enough
Dunlop Direzza Sport Z1 Star spec.. hands down the best ones...
ones that are good and cheap right know are the kuhmo MX which tire rack have them a 111 each
zpeedfreak is offline   Reply With Quote
 Old 08-26-2008, 02:12 PM   #9
Lymerock's Avatar
for best dry weather road tire ill nominate the bridgestone Re-01
not cheap, but it is the defacto autocross street tire class (sts, stx, stu) tire for a reason
 Old 08-28-2008, 03:56 PM   #10
shamuspeed3's Avatar
Posts: 84   (View Stats)
shamuspeed3 has a spectacular aura aboutshamuspeed3 has a spectacular aura about
brigestone RE070a
they come stock on the new skyline gt-R
NOT CHEAP!
but i guess yeww get what yeww pay for
shamuspeed3 is offline   Reply With Quote
 Old 08-28-2008, 04:26 PM   #11
ms3jake's Avatar
Posts: 695   (View Stats)
ms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the world
Get some sway bars and coilovers while your at it. You said you want really good handling.
ms3jake is offline   Reply With Quote
 Old 08-30-2008, 12:10 AM   #12
MS3-oholic's Avatar
Posts: 124   (View Stats)
MS3-oholic has a reputation beyond reputeMS3-oholic has a reputation beyond reputeMS3-oholic has a reputation beyond reputeMS3-oholic has a reputation beyond reputeMS3-oholic has a reputation beyond reputeMS3-oholic has a reputation beyond reputeMS3-oholic has a reputation beyond reputeMS3-oholic has a reputation beyond reputeMS3-oholic has a reputation beyond reputeMS3-oholic has a reputation beyond reputeMS3-oholic has a reputation beyond repute
I have 235/40/18 Dunlop Direzza Sport Z1 Star Spec tires and they grip like crazy. I made my wife sick to her stomach on a 270 degree off ramp one day and the tires never made a noise. Tire Rack rated them higher than the Bridgestone RE-01. They do make more road noise than the stockers did but I can live with it.
MS3-oholic is offline   Reply With Quote
 Old 08-31-2008, 07:30 AM   #13
bani's Avatar
Posts: 335   (View Stats)
bani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond repute
Groans: 35
Groaned at 35 Times in 17 Posts
no.
the stockers are very good, maybe even great tires, but not the best.
when mine wear out i'll be replacing them with Goodyear Eagle F1 GS-D3 for better wet grip.
bani is offline   Reply With Quote
 Old 09-09-2008, 08:13 PM   #14
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
My S2000 had RE050's on it from factory. After I wore them out in 20k miles, I went with the Azenis RT-615's. The RE050's are a great tire, but after autocrossing on both, I gotta say the 615's had more dry grip and weren't much worse in the rain. The Azenis are an amazing tire for the price and it took alot of effort just to get them to squeal. Lots of grip.
 Old 09-10-2008, 08:22 AM   #15
builthatch's Avatar
Posts: 616   (View Stats)
builthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond reputebuilthatch has a reputation beyond repute
this is 10000% correct.
the previous gen azenis, and the latest 615 are just incredible tires.
неприкасаемый / '08 Mazdaspeed3 GT / '07 Si sedan / END OF AN ERA / 6'4", 333lbs
***week old AP FOR SALE!!!! click here*** SOLD SOLD SOLD
builthatch is offline   Reply With Quote
 Old 09-11-2008, 10:58 PM   #16
speed3's Avatar
Groans: 56
RE070A came stock on the 05-07 sti's. Excellent tires!
 Old 09-13-2008, 08:00 PM   #17
cosmicspd3's Avatar
Posts: 447   (View Stats)
cosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant future
I am actually looking at getting new tires as my stockers are almost gone at 17k miles. I am looking at consumer reports and here is the break down for ultra performance.
score out of 100, to get a better review you'll need to look at the CR.
1. *Michelin Pilot Sport PS2 - 85
2. *Pirelli P-Zero - 84
3. BFGoodrich g-Force T/A KDW2 - 78
4. *Bridgestone Potenza RE 050 A Pole Position - 77
5. *Michelin Pilot Exalto PE2 - 76
6. *Continental ContiSportContact 3 - 76
7. Dunlop SP Sport Maxx - 76
8. *Goodyear Eagle F1 GS-D3 - 73
* = CR recommended
Best bang for the buck are the KDW2's and the PE2's. The PE2's had the best tread life. I think I'll be getting those specially since they are $173 a piece at tirerack. Tread pattern is similar to the #1 and stock. My friend has the kdw2's on his SC cobalt and says they handle very well in wet/dry conditions, the side wall wasnt as stiff compared to his stock pzeros but on the road tour (twisty high speed driving) says they handled very well. So yeah... kdw2 or pe2's for me
Anyone try any of those?
2009 Cobalt SS
Originally Posted by northvibe
ABS is really for lazy americans
cosmicspd3 is offline   Reply With Quote
 Old 09-13-2008, 08:47 PM   #18
well considering the potenza RE050A's came on the FERRARI ENZO im pretty sure they are good tires. grated the ferrari versions had a higher speed rating and what not it was still the same tire.....uber poor treadwear but otherwise a great tire.
i went with the pirelli p-zero nero M+s. best all seasons tire out there for the money.
 Old 09-13-2008, 09:17 PM   #19
lidokrantz's Avatar
Posts: 663   (View Stats)
lidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the world
Lots of great tires out there, as mentioned..... but as stated it depends on how long you want them to last as well as how they perform in the rain, and looks may be a factor...it is to me anyway,. But my 2 favorites are the Toyo R1R that just came out and Bridgestone RE01R. For grip these are some of the best, but will wear quickly on the street. And they look great. But R tires for the street are questionable.
Current.. 2009 BMW 135i Twin Turbo, Sedonna Red Metallic, M Sport Pkg, Premium Pkg, Cold Weather Pkg with heated seats, Xenons,M Sport steering wheel, BMW Factory Sport Exhaust..300hp, 300 Tq.. in reality..320 hp 320 tq stock
SOON: BMS JB3....tune, ICarbon rear diffuser, ....all under warranty...
Past/Sold...2007 MazdaSpeed3,CP-E TBE, CAI, Advan Rs Gunmetal, TWM STS with bushings TWM Desert Eagle shift knob,, Defi Amber boost gauge, HKS BOV with CP-E flange..also tried CP-E Nano SRI (MazdaSpeed CAI, Rota TQ Hyperblack, are FOR SALE 4 months old)
lidokrantz is offline   Reply With Quote
 Old 09-14-2008, 12:29 AM   #20
5_Alive's Avatar
Posts: 66   (View Stats)
5_Alive is just really nice5_Alive is just really nice5_Alive is just really nice5_Alive is just really nice
Just because an uber tire comes on a really expensive supercar doesn't mean it will work for you as well.. A lot of times, manufacturers have a tire designed specifically for that specific car.. other times, they design the car to work with a really good tire that's available, and set the car up to work perfectly with that available tire..
My old SS/SC Cobalt had the Pirelli P-Zero's on it.. it was the shittiest thing on the planet... no grip, horrible rain traction, squealed like a pig.. but to a guy in a Ferrari, it works..
The Falken is one of the better tires out there right now for the money..
I've also had previous history with the Nexen N3000, and that tire was amazing..
Buy what is within' your budget and your needs..
Toppin' out is not an option..
5_Alive is offline   Reply With Quote
 Old 09-15-2008, 10:22 AM   #21
Demi's Avatar
Groans: 61
I will continue to groan your comments in tire threads because you dont know what youre talking about, and hopefully that will keep newer folks from thinking you do. God knows there is nothing that pisses me off more than people that talk just to talk. There is no shame in being ignorant, but to spread the ignorance because you want to be included in a conversation makes you the worst kid of poster, and the reason that people need to be careful when buying advice online.
 Old 09-15-2008, 03:24 PM   #22
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
there's a tradeoff for everything, and our stock tires are far from being the best in any category.
i currently run toyo t1-r tires in 235/40/18.
for dry performance: about the same as stock tires.
for wet performance: WAY better traction.
for comfort: noticeably more comfortable ride.
for treadwear: i'm pretty darn optimistic that these tires will have noticeably better wear than the stockers...but this is only a guess based on the 280 rating.
for rolling resistance: significantly more than stock...lost 3 mpg on mixed driving.
the price of these tires were $170 a pop as compared to $200+ each for the stock tires. overall, i'm probably going to be spending slightly more for the toyo T1-Rs even though i will be spending less on tires (initial cost and replacement cost) because of the added gas costs, but the bottom line is that if performance and comfort were my only considerations, it's not even a contest between the toyos and the stock potenzas...
this is just one example of tires which perform better than our stock tires. as demi said, you need to get a new tire shop, because they were definitely not straight with you about what's available....=/
 Old 09-15-2008, 03:28 PM   #23
pewpew
Originally Posted by bani View Post
no.
+1
our stockers actually have downright unimpressive wet traction compared to what's available. as soon as it gets wet out, you really start losing traction on any kind of moderately hard acceleration.
 Old 09-15-2008, 09:07 PM   #24
Demi's Avatar
Groans: 61
The stockers have poor traction (wet and dry), slow response due to loads of sidewall flex and a piss poor tread life. I will say that the road noise is minimal for a "performance" tire. Please note that this is in comparison to some of the inexpensive performance tires available, not to the crap you can buy off the rack. If thats what were are comparing then yes, the stockers are totally tits.
 Old 09-16-2008, 04:32 AM   #25
5_Alive's Avatar
Weird? I haven't had any trouble in the rain with my stock tires.. I have 34,000km on my car, so roughly 21,000 miles..
Mostly highway driving, a lot of spirited.. They may be good for another 6-8k miles if I'm good with them.. I haven't yet hit the treadwear bars yet, but close to..
To be completely honest, you need to buy what suites your needs.. If you want a tire that is going to be comfortable with good tread rating, buy a Yokohama Avid Touring tire.. those are nice..
If you want a great summer tire, I don't know.. lots of people in the thread appear to be agreeing that the Falken is a really good tire, same as myself..
 Old 09-16-2008, 06:19 AM   #26
pewpew
it's not that the stockers are BAD in the rain, it's just that if you compare it to the competition, you don't actually have to look very far to find tires who perform noticeably better under wet conditions. all we're saying is that you can do better for your money no matter what your standards are!
 Old 09-16-2008, 08:04 AM   #27
I'm a caveman
gtlaw's Avatar
Posts: 758   (View Stats)
gtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the world
Groans: 68
this forum needs a sticky thread where people post pics of their cars with the info on wheel specs, tire size, and suspension mods. it would be a great resource.
gtlaw is offline   Reply With Quote
 Old 09-16-2008, 08:15 AM   #28
kingpin748's Avatar
Posts: 2,611   (View Stats)
kingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the world
Groans: 78
Groaned at 48 Times in 31 Posts
Falken Azenis RT-615
Terrible wet weather driving but I don't care.
I should qualify that. If you're driving like an asshole in the rain it's not that great.
In reality I love lenny
kingpin748 is offline   Reply With Quote
 Old 09-16-2008, 08:41 AM   #29
I'm a caveman
gtlaw's Avatar
Groans: 68
they aren't that bad. azenis are the only tires I've owned in the last five years until I bought this MS3 four months ago. BTW the old RT-215's were better
 Old 09-16-2008, 10:40 AM   #30
Funky's Avatar
Posts: 319   (View Stats)
Funky has a reputation beyond reputeFunky has a reputation beyond reputeFunky has a reputation beyond reputeFunky has a reputation beyond reputeFunky has a reputation beyond reputeFunky has a reputation beyond reputeFunky has a reputation beyond reputeFunky has a reputation beyond reputeFunky has a reputation beyond reputeFunky has a reputation beyond reputeFunky has a reputation beyond repute
Groaned at 7 Times in 5 Posts
They stockers are good tires; you wont know that until you buy a cheaper set and realize what you're missing. BUT they are very expensive, and I believe you can get better tires for less $.
All I can say is DONT buy Sumitomos, and DEFINITELY consider Dunlop Z1 Star Specs. They are the #1 ranking tires in Tirerack tests and customer reviews. I just got them, and the sidewalls are rocksolid. They also stick very well which mean that they have the whole package taken care of...
Funky
Funky is offline   Reply With Quote
 Old 09-16-2008, 06:32 PM   #31
Demi's Avatar
Groans: 61
Like wise, you wont know how bad they suck until you buy some better tires. You can get 4 triple nickles for $550. I love em, but dont buy them if you live in a wet area. They are much worse than the stockers in wet conditions, but MUCH better in dry. I live in AZ, so wet performance isnt much of a concern here. My stockers were running out of tread markers at 16000 miles.....it should be noted however that a good deal of those miles were autobahn.
 Old 01-29-2009, 07:24 PM   #32
Otacon_X's Avatar
Posts: 76   (View Stats)
Otacon_X will become famous soon enough
What about the Yokohama tire line?
2006 VR Mazdaspeed6
Otacon_X is offline   Reply With Quote
 Old 02-02-2009, 09:09 AM   #33
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
I just want to chime in with my thoughts about the new Kumho XS.
I've been driving on these now for almost 2000 miles (235/40R18 on RX8 wheels), and so far I'm very impressed. Dry grip seems to be as good if not better than the Falken RT-615, and wet grip is better.
I'm excited to see what they can do on an autocross or open track course. I'll keep everyone updated!
 Old 02-02-2009, 09:15 AM   #34
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
Man I probly gonna switch to 215 tires again my steering feels so heavy with the 235 on and I bet its wearing out my power steering..
 Old 02-02-2009, 09:17 AM   #35
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Well if you arent using at least 8 inch wheels, you are feeling the pain.
 Old 02-06-2009, 06:43 AM   #36
tutuga's Avatar
Posts: 86   (View Stats)
tutuga is a name known to alltutuga is a name known to alltutuga is a name known to alltutuga is a name known to alltutuga is a name known to alltutuga is a name known to all
225/40/18 Yokohama Parada Spec-2 - amazing grip wet & dry
Dunlop Direzza Star Spec is pretty good too
tutuga is offline   Reply With Quote
 Old 02-08-2009, 08:12 PM   #37
Corndogler's Avatar
Posts: 45   (View Stats)
Corndogler is just really niceCorndogler is just really niceCorndogler is just really niceCorndogler is just really niceCorndogler is just really nice
The Azenis rt615 in 225 40, will fit on the stock rims just fine correct? Also, what is the best place to get them?
Corndogler is offline   Reply With Quote
 Old 02-20-2009, 02:20 PM   #38
FAUXSPD's Avatar
Posts: 21   (View Stats)
FAUXSPD will become famous soon enough
Is noise a variable in these considerations? I've had loud tires on previous vehicles and it sucked ...
FAUXSPD is offline   Reply With Quote
 Old 02-20-2009, 04:15 PM   #39
ms3077's Avatar
Posts: 4,024   (View Stats)
ms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the world
Groans: 974
Groaned at 738 Times in 373 Posts
On my second set and couldn't agree more plus they're only like $133 per tire. Oh, and they're like the only 225/40/18 Ultra High Performance summer tire that fit on the stock rim according to manufactory specs.
Yes, other 225/40/18's will fit on the stock rim but if you look at the Manufactory recommendations for 99% of these tires they mandate a rim wider than 7 inches, otherwise if the tire fails you're SOL not to mention it could dangerous.
ms3077 is offline   Reply With Quote
 Old 02-20-2009, 04:34 PM   #40
Qluber's Avatar
Posts: 267   (View Stats)
Qluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud of
* = CR recommended
I had a set of Michelin PE2 Exaltos on my modded Mini Cooper, they were by far the best tire I have ever owned, traction wise, they absolutely stuck like glue, I absolutely tore the Dragon up with those things, never chirped a tire, ever..........
08.5 BLACK MICA GT,
CP-e CAI,
Black Forge bov
DEBADGED
Magnaflow Catback
Corksport Test Pipe
TRZ Rear Mount
1 Step Colder NGK's
Qluber is offline   Reply With Quote
my dyno... u think its good? Buildabong Mazdaspeed3/6 General Discussion 24 06-11-2008 11:46 PM
Very good website speed3 MazdaSpeed 3/6 - Turbo Induction 7 03-31-2008 10:57 AM
MS3 lookin good! ZooZoom MazdaSpeed 3/6 - Appearance 11 03-25-2008 05:50 PM
Page generated in 0.58959 seconds with 49 queries
