 Old 04-29-2008, 12:11 AM   #1
AG.
AG.'s Avatar
Posts: 659   (View Stats)
AG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the world
Default help please...
ok so i found a set of rx8 wheels on craigslist for cheap...like 300...problem is..there is only three of them...are these all weighted with eachother so i HAVE to get a set of four or can I just buy one rim and itll be fine....anyone? thanks..
2008 Sunlight Silver GT - Cobb SRI, HKS BOV Recirc, SU Test Pipe, TWM Shifter Bushings, 35%/5% Tint, Parrot Bluetooth Unit, Decals | To Come - Boost Gauge, Springs+Sways, CBExhaust, Wheels
AG. is offline   Reply With Quote
 Old 04-29-2008, 12:18 AM   #2
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
No, you dont need to buy matched sets bro.
 Old 04-29-2008, 12:20 AM   #3
sweetpickles's Avatar
Posts: 375   (View Stats)
sweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the world
you should be fine with buying 3 now and 1 later (assuming rx8 wheels are all the same size/offset front to rear). Wheels/tires are individually balanced so you should be golden once you get a 4th from wherever You can always have them re-balanced if they already have tires, otherwise it'll be done anyway when you buy new rubber for them.
sweetpickles is offline   Reply With Quote
Page generated in 0.23976 seconds with 21 queries
