 Old 04-12-2013, 11:42 AM   #41
Sines's Avatar
Posts: 1,102   (View Stats)
Sines is the leader of the worldSines is the leader of the worldSines is the leader of the worldSines is the leader of the worldSines is the leader of the worldSines is the leader of the worldSines is the leader of the worldSines is the leader of the worldSines is the leader of the worldSines is the leader of the worldSines is the leader of the world
Should have bought a pu.
09 CWP MS3 318WHP 349TQ
Sure Aeros // Sure Sidewinder // JBR 70 Duro Rmm // JBR Heavy Shift Knob // JBR EGR Delete // JBR TMM 88 Duro // JBR RSB // JBR SSP //JBR REAR CAMBER ARMS // Cobb AP Finkle Tuned 93/E85 Mix // Autotech HPFP Internals// Koni Yellows // H&R Springs // CNT Catted DP// NGK Iridium IX // Turboxs FMIC//
Sines is offline   Reply With Quote
 Old 04-12-2013, 11:42 AM   #42
Police - Grammarhead
Vansquish's Avatar
Groans: 1,911
Default http://www.mazdaspeedforums.org/forum/images/styles/mazda/editor/color.gif
Jesus, tittyfucking, Christ. WTF dude? Your car looks like ass. You don't understand what "performance" means. You clearly have no mechanical sympathy or sense, and your grammar is atrocious. Of these issues, I've (partially) fixed the only thing I can.
I'm going to be back in Michigan in the next few weeks, and I'm sorry to hear that you've taken one of the few surviving Michigan MS6s and turned it into such a hideous piece of shit. It's people like you give Mazda owners a bad name.
Go find some of your kin over at M247 and get that shit out of here.
Originally Posted by davincent View Post
Hey guys,
I am new to the communi(deleted "c")ty(deleted "and"). Hi to everybody!!!
I am in the Detroit area. Is (deleted "so") anyone nearby?
Okay, so I am looking to buy a set of Rota Grids for my Speed6 in the summer,(inserted space) but the only 18-inch wheels they make with a low ET are 18"X9.5" et38, or et20. They look(deleted "it's") so sexy on these cars but, I really don't have a (deleted "the")clue (deleted "that") if they're going to (deleted "this" deleted "gonna") fit (deleted "in") on my '06 Mazdaspeed6 or not. I have seen (deleted "saw") a lot of threads talking about this, but some (inserted space) say they will (deleted "it") fit (inserted space) (you will just need a fender roll(deleted "ed") and no rub at all), (inserted space) some (inserted space) say they will (deleted "it") fit, but take a lot of work (roll(deleted "ed") and pull(deleted "ed") the fenders), still others just say it's stupid to put those on because they will (deleted "it") rub(deleted "s") like shit. (deleted "~")
(deleted "So") I don't know what I should do about this, but I really like those rims, (inserted space)so cananyone (deleted) help me here?
I have (deleted) H&R Coilovers and right now they are (deleted) set mid-way.
Basically if Ijust need a fender roll(deleted "ing") to have no rubbing while driving without someone sitting in the rear, I think I would buy these, (inserted space)so does anyone have any suggestions or (deleted "and")advice?
My MS6 and 240 (deleted "lol"):
[IMG][/IMG]
Some data(deleted "s" Something to note: "Data" is both singular and plural, therefore, there is never a reason to put an "s" at the end of it.):
Stock wheel
Wheel size 18x7 ET 55
BackSpace 156 mm (6.1'')
Rim Lip
Typical Weight ~ 23 lbs / 10 kg
Tires:
Tire size 225/40-18
Section width 225 mm
(8.9'')
Sidewall 90 mm (3.5'')
Tire
diameter 637 mm (25.1'')
Rim sizes 18x6.5 to 18x8.5
Circumference 2000 mm (78.7'')
Revs per
mile 804.6
Typical Weight ~ 21 lbs / 10 kg
Wheel+Tire Weight ~ 44 lbs / 20 kg
Rota wheel
Wheel size 18x9.5 ET 38
BackSpace 171 mm
(6.7'')
14mm (0.6'') deeper.
Rim Lip
48 mm (1.9") wider
Typical Weight ~ 31 lbs / 14 kg
Information obtained thrrough Custom rims, wheel tire packages for your ride -
RIMSnTIRES.com
So if it says it will (deleted "did" - it hasn't happened yet) fit what type of tire (deleted "wheel") should I put on, (inserted space) 235 or 225? inserted space(I know it will make it look stretched but I don't think 245 will fit.(deleted ".."))
Here(deleted "'s") the rims I am talking about and some pictures with them on MS3s:
[IMG][/IMG]
That dude's car is so sexy...
Anyway, (inserted space) please give me some advice on if they (deleted "it") can fit or not!!! (inserted space) I really need help here.
P.S: (inserted space) If they do(deleted "es")n't fit, I think I will just put my old Rays G-Game 99Bs on it. (inserted space) Will they fit or not? (deleted ",it's")
Rays G-Games 99B
18x8.5 +30
Pirelli PZero Nero
245/40/18
pic took by old time on my evo(now it's long gone...)
[IMG][/IMG]
yes,but i checked other's post and like i said they are all different answer to this,lol,it seems can be fit under aggressive set but just heared people said it rubs as hell...so really don't know= =
What's the offset on your rotas?(inserted space) Just styling and it's my DD
Come on guys. It's not finished yet,(inserted space) I want to make it Itasha (I know...) since it's just my DD.
What size of tire have you put on?
I wish they had 18"X8" et38 but they only have et44 in that size.
So, do you think that if I should put the et38 on that I will still need a pull?
I know, as I said, it's unfinished. (deleted "yet,") I am waiting for the big comic decals to come from Japan.
Man, (inserted space) it's just a different style, okay? I have seen so many Japanese cars whose owners have done that and I just think it's awesome, (inserted space)that's all.
[IMG][/IMG]
[IMG][/IMG]
I am asking help for my "performance wheels," as you would say, (inserted space)not my taste you idiot.
If you're going to use proper nouns, they should be capitalized. Japan is a country. Countries are proper nouns. Therefore, "Japan" should be capitalized, as should "Japanese." Moreover, if you're going to call someone out as an "idiot," at least fucking spell it correctly. If you insist on calling people "idot" then you should be aware that the dot on an "i" or a "j" is called a "tittle." So at least use the correct terminology.
Since when do I ask(deleted "ing) any(deleted space)one whether (deleted "that") I should add those stickers or not? (inserted space)Maybe you just want to have some fun. (deleted "which") I am okay with that, (inserted space)but the only reason I posted this was to talk(deleted "ing") about upgrading my wheels. It's a will this wheel fit thread, (deleted !)not a will you like these decals thread!
READ before saying anything!
Funkster777 (04-12-2013)
 Old 04-12-2013, 12:01 PM   #43
rymanmazda's Avatar
Posts: 1,531   (View Stats)
rymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the world
Groans: 122
Groaned at 4 Times in 2 Posts
2006 BCM Mazdaspeed 6 GT w/navi SOLD
Freektune: 400whp/387awtq
Mods: Cobb AP, MSD Dashhawk, GT3076r, HTP 3" SRI, FMIC w/ tr8, Wiseco Pistons (9.5:1), Manely Rods, HPFP AutoTech Intenals, NJSPEED3 Ported Intake Manifold w/ VCTS Delete, Turbosmart BPV, Grimspeed 3-Port EBCS, NGK Iridium One Step Colder Plugs, 3.0" ATP Turbo Dowpipe w/ high flow cat, Devil's Own Stage 1 Methanol/Water Injection Kit, 50/50 Methanol, ACT 6 puck sprung w/ streetlite flywheel, Block8head vent pod, Prosport Performance Boost Gauge Amber/White, Cipher Auto Harness Bar, Cipher Auto 4-point Racing Harness, BC Racing Coilovers, CP-E rear diff mount, JBR RMM 80A, SPC Front Adjustable Ball Joints, Enkei Raijin Hypersilver 18x8 +45, 225/45/18
-Autocross Setup-
17x8 +38, BF Goodrich R1 225/45/17
Other Rides:
2006 Mazdaspeed6 GT BCM: 114k miles, never modded (Totaled March 2013)
1969 Ford Ranchero: 351 Windsor, Edelbrock 600cfm, fully re-done interior (w/ Grant steering wheel, '91 T-Bird SC racing bucket seats), C-6 Automatic Trans w/ shifter kit, First, body work, then drag racing and dumping money into it.
1969 Pontiac Firebird: 4:11 gears, 28x10 ET Streets (Middle of restoration with father)
1998 Toyota Tacoma 4x4: 174k miles, 5 speed, Fiberglass Baja Front clip, 2in body lift, 4in suspension lift, 33x10 BFG All-Terrains, Custom Smittybuilt Bumpers, Custom Intake (SOLD)
rymanmazda is offline   Reply With Quote
 Old 04-12-2013, 12:13 PM   #44
ANITIX87's Avatar
Posts: 1,394   (View Stats)
ANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the world
Groans: 93
Groaned at 27 Times in 16 Posts
That's a lot of effort...
TIS
TOTS
2012 Mazdaspeed3, CWP, Tech Package. COBB AccessPort V3, AUTOTECH HPFP Internals, JBR 3" Wide-path SRI+TIP, CP-E TMIC, UR 3" Test Pipe, CP-E Triton CBE, FORGE V2 BPV, DENSO ITV22 Plugs, JBR RMM 88a, JBR OCC, JBR RSB Kit, JBR Solid Shifter Bushings, CP-E Tow Plate, CorkSport ECU Relocation, TSW Nurburgring Bronze 18x7.5
alphasaur: "Fuck I just beat it to surprise tranny porn. Saw the dick right when I came fml"
ANITIX87 is offline   Reply With Quote
The Following 2 Users Say Thank You to ANITIX87 For This Useful Post:
ccspeed3 (04-12-2013), Vansquish (04-12-2013)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f319/help-wheel-fitment-rota-grid-142712/
HELP!!Wheel fitment for my MS6,rota grid - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 04-12-2013 09:25 AM
Rota Grid 18X9.5 +38 PapaSmurf 2010 MS3 - Wheels & Tires 75 10-20-2015 11:43 PM
Rota Grid - will 19 x 9.5 fit? soaptray 2010 MS3 - Wheels & Tires 19 07-01-2013 08:56 PM
Rota Grid & Mich. PSS fitment issues guitarzan134 MazdaSpeed 3/6 - Wheels & Tires 21 03-01-2013 02:55 PM
Rota Grid 18x8.5 Bonafide_Spd3 MazdaSpeed 3/6 - Wheels & Tires 3 05-25-2010 10:02 AM
Page generated in 0.32667 seconds with 24 queries
