| MazdaSpeed 3/6 - Wheels & Tires HaveMazdaSpeed 3 - Wheels & Tires - Have a question about wheels or tires? Need a calculator to figure out offsets? We have them in here |
![]() | | #41 | ![]() |
| Not Ranked : 0 score Tapadatass
__________________ |
![]() | | #42 | ![]() |
![]() Join Date: Jul 2008 Location: Ottawa, ON Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,005
__________________ 2008 Cosmic Blue Mica Mazdaspeed 3. BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob. To be installed: SS Brake Lines. | |
| The Following User Says Thank You to theurgy For This Useful Post: | Lex (09-27-2012) |
![]() | | #43 | ![]() |
| Not Ranked : 0 score This is where the plot thickens. I found a local set of OEM Dunlops that are literally new that I am tempted to pick up to replace the current ones. I got one summer out of these tires (albeit I did need an alignment for a few k miles there) - but in any case I'd like 2 summers out of the tires. Funny thing is that a lot of Gen2 people are having this tire wear issue along with regular Mazda5 and Mazda3 people overseas where the cars came with the same Dunlop 2050s. Something's fishy here.
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
![]() | | #44 | ![]() |
| Not Ranked : 0 score Very interesting and yes I know that deal for those tires. Thought about getting them myself.
![]() | | #45 | ![]() |
![]() Join Date: Mar 2010 Location: BOCA RATON FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 524
Groaned at 60 Times in 18 Posts
| Not Ranked : 0 score Tire pressure might be the issue. Here's how the premature inner wear went on my 2050's. For the first 10k miles I was really religious keeping the pressures at 35/34 and saw no uneven wear at rotations. At 10k was when I got lax and checked pressures less frequently and let them run down to 33/32 before I added air. At 15k I first noticed the excessive inner wear. At 18k they looked unsafe and that's when I replaced them. I'm on BFG comp-2's now and keeping the tires at 35/34. So far at 5k tire wear is even. Tread depth is down to 8/32 from 10/32 so I know they aren't the longest wearing tires but hopefully they wear even this time. I'm thinking that letting the pressure get low on the 2050's contributes to their demise. The 2050's inner sidewall isn't that stiff so you wind up riding the inner edge of the tread and kill it prematurely with low pressure.
__________________ 2018 Audi S6 Prestige. APR Tuned 575 AWHP (current) 2017 Audi A4 APR tuned 315 AWHP (sold) 2014 IS350 (sold) 2013 MS3 Stage2 E85 (sold) 2011 MS3 Stage2 (sold) |
![]() | | #46 | ![]() |
![]() Join Date: Mar 2008 Location: Brea, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 103
| Not Ranked : 0 score I am religious about keeping my tire pressure above 34lbs. Generally 35-37lbs. I check them often since the TPMS won't let me know they need more air since limit is below 30 (I think 28 or so). I like the stiffer sidewall I get from the higher pressure. Same front very inside edge wear issues since I bought my car new off the lot. If anything, too high a pressure would lead to abnormal quick wear in the center of the tread patch which would lead me to believe there should be less load on the outside edges so I'm not sure how this could be anything else besides toe issues. Even excess neg camber in the front would wear the inside tread patch more but I am getting wear only about a half inch wide and farther to where sidewall stops and the tread begins. Pics earlier in this thread are just like mine. |
![]() | | #47 | ![]() |
![]() Join Date: Dec 2008 Location: CT :: Stratford :: 203
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 632
| Not Ranked : 0 score what I don't get.. is that you don't check your tire wear & pressure on the regular??!!?. at least once every month or so... that's what I do.. I know my car is lowered.. I know my camber is off... not checking is just dumb. Sh*t happens.. stuff breaks.. things don't line up... the more aware you are of the shoes on your car, the safer you will be. ---------- my last set of tires Yokohama Avid Envigor's supposed to last 60k - only made it for about 23k.. camber wear killed them. if I just assumed they would make it to 60k.. I'd be dead in a ditch.. from a blow out while speeding. always check.
__________________ :: somewhere between CT & VA :: yea yea - i know i cant spell Last edited by :: Gusto ::; 10-06-2012 at 04:46 PM. |
![]() | | #48 | ![]() |
| Banned ![]() Join Date: Jul 2012 Location: North Cack-A-Lacky
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Factory suspension and stock dunlops on a 2012 speed3 wear excessively for about a 1'' band around the inner treads on the front, passenger side is the worst. I was worried I was the only one... I have 16k on mine and been challenging the 2/3 to retard service department at my local dealer since the first rotation at 5k, that the camber or toe settings are just not right regardless of the "spec" provided by the MFG. Finally had them agree to "zero out" the settings as best as possible and luckily I too keep a check on tire pressure and wear 1-2 times per month so I have another rotation round before I need new tires. Dependent upon the outcome with zeroed settings over the next 5k, I might ask them to adjust to front camber the positive side slightly on my new set since this turned from a fun ride into my primary ride unexpectedly. Question though, I thought only the rear had no factory camber adjustment? Still bugs me that obviously it is set too aggressive from the factory for a DD and instead of fixing the problem they just say "well this is an enthusiast car and the summer tires just tend to wear a little quicker, we see this a lot". |
![]() | | #49 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
Groans: 67
| Not Ranked : 0 score Neither front or rear camber is technically adjustable on the MS3. A little bit of "wiggle room" is available in the front upper strut mount bolt hole slop though...
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
![]() | | #50 | ![]() |
![]() Join Date: Apr 2011 Location: Mississauga Ontario
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23
| Not Ranked : 0 score I had this issue with my dunflops as well. Got an alignment before i ran my summer wheels and still have this band of wear. Im running 1.5 degrees of camber which shouldn't be a problem. I wonder if there is dynamic camber and castor issues, that would cause wear as bad as that.
__________________ OEM+ FTW |
![]() | | #51 | ![]() |
![]() Join Date: Jun 2011 Location: Mechanicsburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,966
Groans: 80
| Not Ranked : 0 score I have this same issue with my car, it tore up my stock tires, I lowered the car, bought new tires and took it in for 4 wheel alignment(the tech told me it "wasn't to bad" and a year later same issue, tires are shot by 20K miles and it's the front that is wearing about a 1/2 inch to maybe an inch wide on the inner side of the tire.
__________________ CS SRI, TIP, SBT & BPH, BPV, SECBE/CP-e RMM, Catted-DP, TMIC/JBR SSP s2, RSB, TMM/AT Internals/Cobb AP/H&R springs/NGK plugs/SPC camber arms/MB Weapon rims/Pending install: Sure TIGS ![]() 285whp/321wtq-93 E85 tune in progress |
![]() | | #52 | ![]() |
![]() Join Date: Jun 2012 Location: Avon, Ct
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28
| Not Ranked : 0 score Although alignment print outs seem wonderful it is not hard to tap a tire to get it to read correct while its on the rack. I don't know if it's possible on all machines but I suspect it is. Alignment could be off tap the tire a hair and boom it's within spec. This will only work for toe obviously.
__________________ 08.5 true red speed3 semi-bolted. semi-bought, semi-built.... |
![]() | | #53 | ![]() |
| Not Ranked : 0 score Good Afternoon, I bought my speed3 in June of last year. I currently have 15,000 miles on the car and my inner tire wear is massive. I took it to a local place to get it realigned, with the specs of 0 toe front and 1/16 inner toe rear. I took it home yesterday and my stearing wheel is off by about an inch or inch and a half. I called them today and asked about this and they said to bring it back in. They called and said with this current setup there is not much they can do with this. Has any one else ran into this? My specs are from the last alignment. Left Front Camber -0.7 Caster ..... Toe -0.01 Right Front Camber -1.1 Caster .... Toe 0.00 Left Rear Camber -1.8 Toe 0.09 Right Rear Camber -1.8 Toe 0.08 Do these numbers look ok? Or should I take it some place else? (edit) And Im sorry I should have said its a 2012. I didn't want to make another thread over this issue.
__________________ Ignore the kitty smile.. Cause inside hes a devil and he wants your soul.... |
![]() | | #54 | ![]() |
Groans: 67
| Not Ranked : 0 score If they can't figure out how to center the steering wheel, you need to find a better alignment shop, IMO.
| The Following User Says Thank You to Nliiitend1 For This Useful Post: | El_Diablo (06-07-2013) |
![]() | | #55 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
I would request my money back and find a better shop.
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson | |
![]() | | #56 | ![]() |
| Not Ranked : 0 score Thanks guys for the replies. I got the car back a few minutes ago. It seems that they fixed the stearing wheel issue. When I get back from Pensacola I'll be putting new tires on this and might just go back to the default setup.
![]() | | #57 | ![]() |
Groans: 769
| Not Ranked : 0 score Let me know the printout and we can see if they did it properly.
![]() | | #58 | ![]() |
| Not Ranked : 0 score Crap! I didn't ask for a print out this last time. I'm not sure they adjusted any thing except the stearing wheel.
![]() | | #59 | ![]() |
| Not Ranked : 0 score ALWAYS ask for the print out.
| The Following User Says Thank You to theurgy For This Useful Post: | El_Diablo (06-07-2013) |
![]() | | #60 | ![]() |
![]() Join Date: Jun 2010 Location: corpus christ, tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,316
Groans: 68
Groaned at 22 Times in 9 Posts
| Not Ranked : 0 score I went to a shop one time that said their printer was broke when I asked for the printout. So I asked if they could at least write what they got on a piece of paper. Gave me the run around for that to and said to late the screen was already closed. I was pissed.
__________________ 2006 MS6 -GTX3076 .82 AR-Steedspeed Topmount mani-DJ/PERM Top mount Kit with PERM tune-CXracing FMIC-Tial .44mm WG - KMD Internals- Sure RDM, Turbine tech FDM and FMM=JBR trilogy MM- Whiteline rear sway- eibach prosport springs-jbarone SSP-COBB AP-ACT 6PUCK- ITV22-Prosport Spin On Conversion-Snow Performance stg 2 Meth-CPE Injector seals-Matt Damon OCC |
![]() | | #61 | ![]() |
| Not Ranked : 0 score I wouldn't have paid. To me, the printout is like the receipt.
| The Following User Says Thank You to theurgy For This Useful Post: | El_Diablo (06-08-2013) |
![]() | | #62 | ![]() |
![]() Join Date: May 2011 Location: Naperville, IL
| Not Ranked : 0 score I am going to have a shop do an alignment on my car tomorrow. I am on my 6th set of tires in 100k on my ms6. ![]() What do i ask for? Get my toe as close to 0 as possible and my Camber as close as possible to -1.5? |
![]() | | #63 | ![]() |
Groans: 769
| Not Ranked : 0 score As long as it is within the set parameters you will be fine. As little camber as possible will help with more even tire wear.
![]() | | #64 | ![]() |
| Banned ![]() Join Date: May 2011
| Not Ranked : 0 score Just got back from Discount Tire to do a tire rotation/balance and they told me they would not be able to do it because my front tires have inner tire wear. According to the rep, he has seen this numerous times w/the MS3 and after about 20k miles I have to replace the tires or risk a blow out. What!?!?! Mind you I bought my 2011 MS3 brand new and it currently has 26k miles. This sounds like a manufacturer defect to me. I am filing a complaint against Mazda with the National Highway Traffic Safety Administration (NHTSA) and suggest everyone that is experiencing this problem do the same. According to the website: Motor Vehicle Defects and Safety Recalls: What Every Vehicle Owner Should Know | Safercar.gov | NHTSA , if the agency receives similar reports from a number of people about the same product, a safety-related defect may exist and would warrant the opening of an investigation for recall. I'm not paying $600 every 20k miles because of an obvious safety issue that should be handled by the manufacturer. What do you guys think??? |
![]() | | #65 | ![]() |
![]() Join Date: Oct 2011 Location: FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 601
Groans: 106
Groaned at 6 Times in 6 Posts
| Not Ranked : 0 score Welcome to the club. Mine lasted 12k miles. |
| The Following User Says Thank You to JSmith For This Useful Post: | slowspd (07-01-2013) |
![]() | | #66 | ![]() |
Groans: 769
| The Following User Says Thank You to El_Diablo For This Useful Post: | i8urgti (07-01-2013) |
![]() | | #67 | ![]() |
| Not Ranked : 0 score |
![]() | | #68 | ![]() |
| Police - Grammarhead ![]() Join Date: Sep 2009 Location: Metro Detroit, MI
Rep Power: 3749 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,748
Groans: 1,911
Performance-oriented cars on summer tires are going to eat through the tires fairly quickly due to more performance-oriented alignment specs. That having been said, with a good alignment, aimed more with an eye to tire-longevity, it's possible to get well into the 40k mile range before having to swap tires out due to wear. This, of course, assumes relatively sedate driving (mostly highway cruising, etc.), and not a whole lot of hard cornering or wheel-spinning shenanigans. I've got an MS6, so I have different alignment issues to watch out for, but I saw 42k miles on my first set of tires (RE960AS - 225/40/18), and have seen an additional 20k on my current all-season tires (Conti DWS - 225/45/18) with minimal noticeable wear. On my summer tires though...(RE040 - 225/45/18), I'll be lucky to see 15k, since I drive them harder. Basically, it's all about 1. how your car is aligned, and 2. how you drive. If you're planning on filing a claim with the NHTSA, then you should learn how to drive first @Samguzma;.
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! ![]() | |
![]() | | #69 | ![]() |
| Not Ranked : 0 score You guys can eat a d...! |
![]() | | #70 | ![]() |
Groans: 111
![]() I personally think that you have no clue about the car you've got or cars in general. If I were you I'd file a complaint with the NHTSA about some products in a grocery store as well and whine about some cheese going bad in the trunk in a 100F day. It happened in the car, so it must be the car's fault. Good luck with your complaint. P.S.: these cars have an aggressive alignment to give them both traction and cornering stability. If you drive them slowly/normally it's perfectly normal, read PERFECTLY NORMAL, to see inner tire wear. And as a daily driven car it's expected to drive them normally and see a bit more inner wear. If you push your car hard in tight corners or even high speed bends you will see outer shoulder wear as well, and in this case the wear will be more even. I'm not saying you should drive the car hard every day or for no reason and endanger yourself and others in traffic, I'm just explaining to you how things work in a sports car with McPherson/single arm suspension (things are a bit different with cars having double wishbone suspension such as the MS6 by example).
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
![]() | | #71 | ![]() |
Groans: 769
True summer tires dont last. Look at one of the leading summer tires, the NT-05. Your lucky if you can get them to 15-20k miles.
| The Following User Says Thank You to El_Diablo For This Useful Post: | Vansquish (07-02-2013) |
![]() | | #72 | ![]() |
| The Following User Says NO Thank You to Samguzma For This Un-useful Post: | El_Diablo (07-02-2013) |
![]() | | #73 | ![]() |
![]() Join Date: Apr 2011 Location: NE IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
| Not Ranked : 0 score ^
__________________ 2006 LPM Mazdaspeed 6 Mazdaspeed CAI - AWR RMM - TWM Stage 2 STS - Cobb AP - M2 DP - AT Internals - Cobb TIP - NGKsparkers - CPE Rear Diff Mount - Whiteline Rear Swaybar - AWR Endlinks - Eibach Sportlines |
![]() | | #74 | ![]() |
![]() Join Date: Aug 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8
Groaned at 4 Times in 2 Posts
| Not Ranked : 0 score premature inner tire wear checking in. pass front is down to the cords, glad I was poking around and saw it, otherwise i would've thought "i've got another 5-6k before I need a new set." the irony is, i'm going through the car so i can get ready to sell it, and now i've got to dump money into it for new tires. FML. |
![]() | | #75 | ![]() |
Groans: 111
| Not Ranked : 0 score Ok, so as a conclusion, especially if the car is lowered and/or is running wider tires than stock we should adjust the camber a bit to widen the contact patch. This should improve both handling and traction, and make the tire wear happen more evenly across the entire surface of the tire. As far as I know too camber can't be adjusted, so we need camber arms (Eibach/SPC/JBR/Whatever).
![]() | | #76 | ![]() |
Groans: 67
| Not Ranked : 0 score I've said it before, but I'll say it again: I have absolutely no weird wear issues with a proper alignment, and mine's even a bit on the "aggressive" side of the spectrum (for not using camber plates, that is)... ![]() That said, I don't get a lot of mileage out of my tires. I'm also not using tires with a lot of treadlife to begin with, but I'd be happy to get ~15K and a few trackdays/autocrosses out of a set. Lol.
| The Following User Says Thank You to Nliiitend1 For This Useful Post: | El_Diablo (07-04-2013) |
![]() | | #77 | ![]() |
![]() Join Date: Nov 2011 Location: Minooka, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, FREEK TUNED, HTP full 3" intake/TIP, HKS SSQV 4 full VTA, Corksport catless downpipe, Corksport catless Racepipe, Cobb AP V3, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 80duro PMM, JBR cylindrical shift knob, Fidanza aluminum flywheel, EBC green brake pads, Centric high carbon rotors, Nitto NT555 tires, Gorilla spline lug nuts, DDM tuning HID's lows, Resonator Delete. | |
| The Following User Says Thank You to GODspeed7 For This Useful Post: | El_Diablo (07-04-2013) |
![]() | | #78 | ![]() |
| Neutral : -1 score |
| The Following User Says NO Thank You to Samguzma For This Un-useful Post: | El_Diablo (07-04-2013) |
![]() | | #79 | ![]() |
Groans: 769
| Not Ranked : 0 score Just forget about logging on to this site or stop the bullshit before things get bad for you.
![]() | | #80 | ![]() |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f319/holy-inner-tire-wear-98124/ | ||||
| Untitled document | This thread | Refback | 01-06-2015 04:23 AM | |
| REALLY uneven tire wear .... cause ? | This thread | Refback | 10-18-2013 08:42 PM | |
| Is this normal tire wear? | Bucker | 2010 MS3 - Wheels & Tires | 34 | 04-26-2012 08:39 PM |
| wtf insane tire wear!!! | superskaterxes | MazdaSpeed 3/6 - Wheels & Tires | 42 | 07-26-2010 10:33 PM |
| OEM Tire wear question | Chinsel | MazdaSpeed 3/6 - Wheels & Tires | 0 | 04-16-2010 03:39 PM |
| Bad Inner Tire Wear | MattJackson86 | MazdaSpeed 3/6 - Wheels & Tires | 3 | 03-09-2010 07:43 PM |
| Bad inner tire wear | cm-jp1 | MazdaSpeed 3/6 - Suspension & Brakes | 27 | 12-05-2009 08:19 PM |
