MazdaSpeed 3/6 - Wheels & Tires HaveMazdaSpeed 3 - Wheels & Tires - Have a question about wheels or tires? Need a calculator to figure out offsets? We have them in here |
![]() | ![]() | #41 | ![]() |
![]() Join Date: Apr 2009 Location: VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 677
Groans: 320
Groaned at 78 Times in 45 Posts
__________________ when was the last time your speed reeled in this many bitches? ![]() ![]() ![]() |
![]() | ![]() | #42 | ![]() |
![]() Join Date: Aug 2009 Location: Trevose, PA
Rep Power: 7485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,940
Groans: 224
(Thread Starter) | ![]() ![]() ![]() So right now to run a 17x9 +43 wheel with 255/40 tires I'll need to roll the rear fenders, trim where the bumper meets the fender and use either a 3mm or 5mm spacer in the front. Did I miss anything? Edit: I'm assuming camber will also be a necessity to an extent?
__________________ MS3 has been retired to daily duty Project 1G; 1991 Eagle Talon TSi. 63MM Borg Warner Powered, Corn-Fed, 2.4L Long Rod Monster Under Construction Stock Turbo-Stock Engine Grand Champion of the World! 501WHP & 569WTQ (PERM Tuned, 93 OCTANE PUMP GAS K04 W/N2O!!) NATOR PA |
The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post: | JacksonMS30 (12-13-2011) |
![]() | ![]() | #43 | ![]() |
Groans: 320
| ![]() ![]() ![]() Correct. Are you still on stock suspension? Hopefully you have those v1's that you were talking about a while ago. I could've sworn I saw a couple ms3's on 17x9 rpf1s with stock style struts and 255's at OCC meet this past spring. For the front camber you will not need adjustment, although the car greatly benefits from it. My Tein Super Streets do not have built in camber adjustment like other coils. I have spc rear camber arms dialed into -1.5* which isn't very far off stock specs. I'm not sure how much static camber you are getting without arms, but you can get a good amount. If you go with 255 I would get the rear camber arms. You can get away with 245/40 without arms, just depends on how much camber you have as is. I recently test fitted my wheels on a speed3 this weekend, it was dropped (close to max low) on bc's with a fair amount of rear camber (no adjustable rear arms) looked like he could get away with a just a roll, no arms needed. I'd get the adjustable rear arms just for the sake of not eating up tires. BTW, I have spoke to @tigermack regarding their STX speed3 and they seem to think 255 is good for the front but you're better off going 245 in the rear. Besides better rotation, I don't know why 255's all around wouldn't be more appealing. You're better off asking him or his brother @justint5387 regarding their car prep. one of the cars at OCC, the other one was white, and I think he was the one on 255's. I know he's on here somewhere.. Last edited by Manny; 12-12-2011 at 03:43 PM. |
The Following User Says Thank You to Manny For This Useful Post: | MS3-a(sore)ASS-rex (12-12-2011) |
![]() | ![]() | #44 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4017 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
Groans: 67
| ![]() ![]() ![]() If you're adding rear negative camber via adjustable camber links in order to fit wider tires, you're "doing it wrong," IMO. More negative rear camber means more understeer, which isn't what anyone looking for a well-handling MS3 should be after...
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club ![]() ![]() ![]() |
The Following 4 Users Say Thank You to Nliiitend1 For This Useful Post: | JacksonMS30 (12-13-2011), MS3-a(sore)ASS-rex (12-12-2011), Nataphen (12-12-2011), SLOWHATCH (12-29-2011) |
![]() | ![]() | #45 | ![]() |
Groans: 320
| ![]() ![]() ![]() Like I said, it's pretty close to factory specs. Would you consider -1.5* too much? Just trying to get your opinion here, because I already know it works for me and have had great results at a regional level of autox with this setup. I'm not the only one either. I feel like you don't even need that much (-1.5*) camber to clear the rolled fenders. IMO, this setup is barely aggressive by any means. Yet, you can still fit fat tires without sacrificing performance. Plenty of people out there fitting this setup without "too much camber" or "doing it wrong" The Tsang brothers have used that much rear camber in their FSP 3 and in their STX speed3, tell them that they're doing it wrong. Last edited by Manny; 12-12-2011 at 03:47 PM. |
![]() | ![]() | #46 | ![]() |
Groans: 67
For an MS3 with anything less than about -2° front camber, I'd say that yes, -1.5° is probably too much (especially for autocross - for open track it may be arguable depending on driving style/course layout). But at any rate, I'm getting off of my original point, which is that you really shouldn't ever be adding negative camber with those rear arms. They're needed to remove unwanted increased negative camber in with relation to the front negative camber on lowered cars, or for the purpose of cross-camber removal. I'm just saying that you're not likely helping the handling prowess of an MS3 by adding rear negative camber with them unless you're running extremely aggressive negative front camber and need to dial the tail-happiness of the car down a notch or two.
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club ![]() ![]() ![]() | |
![]() | ![]() | #47 | ![]() |
Groans: 320
| ![]() ![]() ![]() Do you happen to know stock rear camber values? I know the car comes with at least a degree of negative camber from the factory. There are huge variances when it comes to alignment though, I just don't see .5* (if that) being very significant. While I agree that the bigger picture regarding overall alignment is more important; I think the addition of more negative camber in the rear is a negligible amount. I do not find that i've sacrificed performance on any of the autox courses I have driven on. I'm open to trying new things, so I will try dialing the camber back a bit and see how that goes. To OP, don't make that shy you away from that setup though. Driving styles are very different and what works for one person may not work for another. How you set your alignment up affects that. |
![]() | ![]() | #48 | ![]() |
![]() Join Date: Apr 2010 Location: Forney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,098
Groans: 31
| ![]() ![]() ![]() Project Cars :: Project MazdaSpeed 3 - CorkSport Mazda Performance - 360-260-CORK I'm not sure about the differences in fitment from gen 1 to gen 2, but CS's shop car in this blog has some good pics with 8.5" +45 wheels and 235 tires. They have pics on stock suspension and with H&R Sports a little further down the page. I like this perfectly flush fit personally, so 8.5" on +45s is what I'll be getting for my MS3. I'm still not sure about what I need for the MS6.
__________________ ![]() ![]() 06 BM MS6=stock (totaled) 06 WWP MS6=suspension only (sold) 93 RX-7=single turbo swap, 300whp@8psi, 2600lbs (sold) Wife's 10 MS3=bolt-ons & tune, 13.6 best ET (sold) 13 5.0 Wife's 13 Focus ST |
The Following 2 Users Say Thank You to Nataphen For This Useful Post: | MS3-a(sore)ASS-rex (12-12-2011), uncorked11 (12-12-2011) |
![]() | ![]() | #49 | ![]() |
Banned ![]() Join Date: Jul 2009 Location: Fremont, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 257
| ![]() ![]() ![]() I have -1.8 rear camber, don't remember exactly. Could be just me, too little camber makes the car turn in a little slower, I prefer to get the turning done early. |
The Following 2 Users Say Thank You to justint5387 For This Useful Post: | MS3-a(sore)ASS-rex (12-12-2011), tigermack (12-12-2011) |
![]() | ![]() | #50 | ![]() |
![]() Join Date: Aug 2008 Location: SoFla
__________________ Oh looky! ![]() | |
![]() | ![]() | #51 | ![]() |
![]() Join Date: Nov 2010 Location: York/Philly, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 777
| ![]() ![]() ![]() there is an evo tuner 2miles from me selling bbs mr 18x8.5...with 245s (i think) |
![]() | ![]() | #52 | ![]() |
Groans: 224
(Thread Starter) | ![]() ![]() ![]() OMG possibly my favorite OEM wheel on any car period!! How much?!
The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post: | 4G63 (01-11-2012) |
![]() | ![]() | #53 | ![]() |
![]() | ![]() | #54 | ![]() |
Groans: 224
(Thread Starter) | ![]() ![]() ![]() How could you let those go?! lol
![]() | ![]() | #55 | ![]() |
Groans: 67
![]() I'd also like to say that depending on the particular camber curve of the setup, yes, half a degree of static camber can make a HUGE difference in how the car responds.
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club ![]() ![]() ![]() Last edited by Nliiitend1; 12-12-2011 at 08:01 PM. | |
The Following User Says Thank You to Nliiitend1 For This Useful Post: | Nataphen (12-12-2011) |
![]() | ![]() | #56 | ![]() |
![]() | ![]() | #57 | ![]() |
![]() Join Date: Aug 2008 Location: Bay Area, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 470
Groans: 78
| ![]() ![]() ![]() Why are you toed in? We ran 1/4" toe out in the rear... and about 1/16 toe out in the front. I run close to -2 at one point in the rear. Faster turn in but in longer turns, it starts to grip harder so I dropped it to -1.8.
__________________ Fuck HPDE heroes. HPDE ain't road racing. |
![]() | ![]() | #58 | ![]() |
Groans: 31
| ![]() ![]() ![]() He said toed out 1/16, aka -1/16. 0 rear toe, -1.1 rear camber, -1/16 front toe, -1.4 front camber.
The Following User Says Thank You to Nataphen For This Useful Post: | Nliiitend1 (12-12-2011) |
![]() | ![]() | #59 | ![]() |
Groans: 224
(Thread Starter) | ![]() ![]() ![]() These posts are blowing my mind....
The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post: | Nataphen (12-12-2011) |
![]() | ![]() | #60 | ![]() |
Groans: 31
| ![]() ![]() ![]() Do not feah de alignment specs. |
The Following 3 Users Say Thank You to Nataphen For This Useful Post: |
![]() | ![]() | #61 | ![]() |
Groans: 67
I still can't find my last record sheet that has my final caster values (which is why I haven't yet posted in the recent Alignment Thread), but I basically had the guys maximize (while keeping them pretty much even from side to side) both caster and camber using the slop in the top mount bolts. I probably have a little more camber to gain if I fuck with the front subframe, but I probably won't get around to that until this Spring when the summer wheels/tires go back on. I'm been toying with the idea of ever-so-slightly dropping the ride height on both ends and figure that might be a good time to give it the ol' college try. ...and again, you guys (tigermack and justint8357) are running a LOT more front camber than I am. If I were running as much as you, I'd have my rear camber set significantly further in the negative direction as well.
![]() | ![]() | #62 | ![]() |
![]() Join Date: Oct 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
I have purchased some RPF1s 17x9 +45 and they are fitted with AD08s 245/40s. Planning on fitting the wheels to the car in the next coming weeks, so I might try and post up some info with photos on the fitment. I'm hoping that I won't have to use a spacer up front and might get away with just a roll/trim! Running stock suspension at the moment too. | |
![]() | ![]() | #63 | ![]() |
| ![]() ![]() ![]() Rolled in the rear 5mm Spacers up front Stock Suspension - Needs moar low! No rubbing at the moment! Room Up Front http://i44.tinypic.com/2btymc.jpg Room In The Back http://i39.tinypic.com/6f8idy.jpg http://i43.tinypic.com/s6m06q.jpg |
The Following User Says Thank You to Dru For This Useful Post: | MS3-a(sore)ASS-rex (01-11-2012) |
![]() | ![]() | #64 | ![]() |
![]() Join Date: May 2009 Location: Little Neck, NY
Rep Power: 3768 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,108
Groans: 326
| ![]() ![]() ![]() im looking at 17x8.5 +40 PF01's next year will probably wrap them in 245/45's also intend to drop down on H&R coils should be interesting haha |
The Following 2 Users Say Thank You to 8.5MS3 For This Useful Post: | MS3-a(sore)ASS-rex (01-11-2012), silvapain (01-11-2012) |
![]() | ![]() | #65 | ![]() |
![]() Join Date: Jun 2011 Location: sufu
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
Groaned at 41 Times in 24 Posts
| ![]() ![]() ![]() I'm thinking about running a 255/40-17 @ same as stock height, 10" wide, what wheel offset would work best without rubbing? What width? Sent from AT&T Inspire 4G using Tapatalk.
__________________ HT programmer, Mazdaspeed CAI, Turbosmart Dual port Bpv, Corksport Test pipe back exhaust, HTP TIP, Autotech CDFP internals, CP-E TMIC, Cobb Springs, Koni yellow struts, SU RMM, Ts shift plate, prosport bg, 10k headlights, 3k fogs, OZ Ultraleggera HLTs, Pioneer nav/dcs......On the way; Devils Own Stage 2 |
![]() | ![]() | #66 | ![]() |
![]() | ![]() | #67 | ![]() |
![]() Join Date: Nov 2011 Location: San Diego, Ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 184
| ![]() ![]() ![]() did the OP ever get the wheels installed? i'm interested in possibly running a 17x8.5 +44 with perhaps 235/40 all around. stock height ATM but looking into either coilovers or H&R springs/Koni Yellows.. .still have more research to do
__________________ 09 CWP MS3: COBB AP / MSD DH / AT HPFP / CPE SRI / CS TIP / CS BT-RH / M2 DP / CNT CBE / HKS BPV / EVO X / E85 PERM ![]() 07 TGM MS6: COBB AP / JBR PP SRI/TIP/ JBR BT-RH / CS CBE / FORGE V1 / JBR RMM / H&R CO Stratified OTS 07 BM MS6: DREADNAUGHT / JUGGERNAUT / SU DMM*PMM*TMM / JBR RMM / BC CO / MAGNAFLOW CBE / JBR OCC / SURE BSD / PRODRIVE GC06-H ![]() Long Signature made especially for Micha |
![]() | ![]() | #68 | ![]() |
![]() | ![]() | #69 | ![]() |
![]() Join Date: Jul 2009 Location: Keene, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
| ![]() ![]() ![]() You might find you'll have to roll the rear fenders if you drop the car, but on stock suspension that should fit no problem.
__________________ 08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's 253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune 97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup 89 Kawasaki 650SX Stand-Up Jetski |
![]() | ![]() | #70 | ![]() |
Groans: 224
(Thread Starter) | ![]() ![]() ![]() OP hasn't installed anything yet. Need more go-fast goodies first lol
![]() | ![]() | #71 | ![]() |
![]() Join Date: Nov 2010 Location: Gothenburg, Sweden
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 534
I run 17x8 +40 but I took off around 3mm so the actual offset should be around +43 I have 235/45 all around and I rub a bit in the back but since I have trackday-tyres they are a bit wider than street-tyres. http://img834.imageshack.us/img834/4...j1164313em.jpg http://img863.imageshack.us/img863/4...j1164329em.jpg Stock height http://img846.imageshack.us/img846/6...j1175628em.jpg http://img215.imageshack.us/img215/4408/dsf3716.jpg Kw coils http://jonatanfoto.se/MPS/images/large/_DSF3830.jpg http://jonatanfoto.se/MPS/images/lar...F4069_Edit.jpg http://jonatanfoto.se/MPS/images/lar...F3870_Edit.jpg
__________________ GT3071R 23psi Tuned with Versatuner by Stratified Auto ![]() | |
![]() | ![]() | #72 | ![]() |
![]() Join Date: Feb 2009
Rep Power: 151847 ![]() Thanks: 55,993
Groans: 1,443
__________________ Evo VIII - 9.93 @ 150.05 - CAI and LEDs Beanfab / Tuned by Nishan | |
![]() | ![]() | #73 | ![]() |
rabble rabble ![]() Join Date: Aug 2008 Location: Delawhere
Rep Power: 3165 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| ![]() ![]() ![]() but I'm sure according to the suspension guru's, my setup is probably not optimal. I only have bilsteins, with not much ability to adjust front camber, and have rear camber set at almost -2.0, eibach springs, with cobb rear sway set on the softer setting. I think it handles fine, and I kind of like how hard it is to get the rear to break loose, and I ran it at NHMS like this for 2 days straight, and it felt fine. So I dunno, but I would love to get more front camber in the spring. definitely gonna be changing it up when it gets warm.
__________________ '08 CWP MS3 w/ T3 3071r | |
![]() | ![]() | #74 | ![]() |
Your car setup looks awesome, I'm thinking about getting 17's and 255/40-17. But lowering it like that wouldn't be to practical on the streets here, Last summer I had Cobb springs & 225/40-18's and my front lip was rubbing on all the approaches. So do you think your setup would rub fenders with the oe springs? I'm looking for something wider for more holeshot traction. Sent from AT&T Inspire 4G using Tapatalk.
__________________ HT programmer, Mazdaspeed CAI, Turbosmart Dual port Bpv, Corksport Test pipe back exhaust, HTP TIP, Autotech CDFP internals, CP-E TMIC, Cobb Springs, Koni yellow struts, SU RMM, Ts shift plate, prosport bg, 10k headlights, 3k fogs, OZ Ultraleggera HLTs, Pioneer nav/dcs......On the way; Devils Own Stage 2 | |
![]() | ![]() | #75 | ![]() |
OP: go fast parts FTW Sent from my SAMSUNG-SGH-I997 using Tapatalk
__________________ 09 CWP MS3: COBB AP / MSD DH / AT HPFP / CPE SRI / CS TIP / CS BT-RH / M2 DP / CNT CBE / HKS BPV / EVO X / E85 PERM ![]() 07 TGM MS6: COBB AP / JBR PP SRI/TIP/ JBR BT-RH / CS CBE / FORGE V1 / JBR RMM / H&R CO Stratified OTS 07 BM MS6: DREADNAUGHT / JUGGERNAUT / SU DMM*PMM*TMM / JBR RMM / BC CO / MAGNAFLOW CBE / JBR OCC / SURE BSD / PRODRIVE GC06-H ![]() Long Signature made especially for Micha | |
Display Modes | |
Need help with decision | 2gr84u | MazdaSpeed 3/6 - Car Audio & Electronics | 5 | 07-17-2011 11:22 PM |
First Day God Made Earth...Second Day God Made H&R Coils... | Radar_This | MazdaSpeed 3/6 - Suspension & Brakes | 98 | 12-08-2010 08:10 AM |
Need help with a decision | CCC | Exterior | 4 | 04-17-2010 07:14 PM |
Henderson says GM bankruptcy decision still in doubt; Hummer decision expected before month's end | Haltech | Automotive News | 0 | 04-17-2009 11:30 AM |
