 Old 12-20-2008, 05:50 AM   #1
Smokehouse's Avatar
Posts: 653   (View Stats)
Smokehouse is the leader of the worldSmokehouse is the leader of the worldSmokehouse is the leader of the worldSmokehouse is the leader of the worldSmokehouse is the leader of the worldSmokehouse is the leader of the worldSmokehouse is the leader of the worldSmokehouse is the leader of the worldSmokehouse is the leader of the worldSmokehouse is the leader of the worldSmokehouse is the leader of the world
Default MS3 wheel offset/size questions...
Ok...size seems to be not a big deal but the offset thing seems to be a bit up in the air. I see the stockers have an offset of 52.5 and a wheel siaze of 18x7.5...
I also see many aftermarket wheels are a 45 offset...
What can/have you guys run with no issues on stock suspension? I'd like to go a bit wider in the wheel/tire as well (possibly a 235?)
Any help would be great...
Smokehouse is offline   Reply With Quote
 Old 12-20-2008, 03:42 PM   #2
Young Roids
Lurkers
Young Roids's Avatar
Posts: n/a
Stock is +52.5mm 18x7
Ideally you want to keep the offset as high as possible to match the stock offset. To go 235 you will want an 8 inch wide rim. Aim to have an offset 48 or greater I would say.
 Old 12-20-2008, 05:46 PM   #3
Derek88's Avatar
Posts: 773   (View Stats)
Derek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the world
^ He's right. However if you are staying on stock suspension, you could get the 18x8 +45 that you have found and run 235s with no issues. I'm on Cobb springs with this set up and I have no issues.
-Derek
No longer in the Mazdaspeed Family
Derek88 is offline   Reply With Quote
 Old 04-05-2016, 07:22 AM   #4
pvtpeter9's Avatar
Posts: 5   (View Stats)
pvtpeter9 can only hope to improve
What if I run 18×9 +30 with 235s
Sent from my SM-G920V using Tapatalk
pvtpeter9 is offline   Reply With Quote
The Following User Says NO Thank You to pvtpeter9 For This Un-useful Post:
anavrinIV (04-05-2016)
 Old 04-05-2016, 07:32 AM   #5
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
No.
Blue Pu.
 Old 04-05-2016, 07:40 AM   #6
pvtpeter9's Avatar
No.
I. Was looking at these rims and I was concerned that they wouldn't fit but if I got spacers to push them out a bit you think it would work I was thinking about putting on some fender flares
 Old 04-05-2016, 07:43 AM   #7
anavrinIV's Avatar
Groans: 63
Oh yeah if you're doing spacers you'll be good.
Blue Pu.
 Old 04-05-2016, 07:44 AM   #8
pvtpeter9's Avatar
So if I added 15 mm spacers that would push the offset to 45 or is that not how it works
 Old 04-05-2016, 11:14 AM   #9
anavrinIV's Avatar
Groans: 63
Jesus. 5 seconds of googling. Go do it.
Blue Pu.
 Old 04-05-2016, 12:08 PM   #10
pvtpeter9's Avatar
Crarrs (04-05-2016)
 Old 04-05-2016, 01:38 PM   #11
Tachyonic Moderator
MS3Shadow's Avatar
Groans: 283
So I'm guessing you didn't do it.
sent from my Nexus 6P
 Old 04-05-2016, 04:47 PM   #12
JakeMS3's Avatar
Posts: 1,164   (View Stats)
JakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the world
Groaned at 7 Times in 5 Posts
He had to have searched something to find an eight year old thread and resurrect it. He knows how to do it, just being lazy or he is a definite troll.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
Corksport Catted DP/HPFP Internals
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
JakeMS3 is offline   Reply With Quote
 Old 04-30-2016, 03:36 PM   #13
JaeHxC's Avatar
Posts: 19   (View Stats)
JaeHxC has a spectacular aura aboutJaeHxC has a spectacular aura aboutJaeHxC has a spectacular aura about
Cobb SRI+TIH+airbox, Cobb DP+CBE, Cobb FMIC, Denso ITV-22 spark plugs, XLE BPV, Autotech HPFP internals. H&R coilovers, Cobb RMM, Corksport short shiftplate+weight.
JaeHxC is offline   Reply With Quote
Offset question from wheel noob. 08cosmic3 MazdaSpeed 3/6 - Wheels & Tires 10 05-16-2018 06:43 PM
stock wheels: Size,Bolt Pattern,Offset,Bore Jasnall MazdaSpeed 3/6 - Wheels & Tires 20 06-10-2014 01:53 PM
which size offset for rota slips Darksun280 MazdaSpeed 3/6 - Wheels & Tires 31 10-08-2008 08:47 AM
what wheel size sor slicks Stockturbo_Ms3 MazdaSpeed 3/6 - Wheels & Tires 2 09-18-2008 08:12 AM
Wheel questions. 06kr MazdaSpeed 3/6 - Wheels & Tires 0 07-14-2008 03:48 PM
Page generated in 0.32153 seconds with 26 queries
