Like Tree2Likes
 Old 12-11-2013, 07:31 PM   #41
gmoney542's Avatar
Posts: 236   (View Stats)
gmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the world
Nice wheel choice! I was thinking about getting a set of those before I got the ones in my sig.
I think you'll be fine running 215's on them too. I've had 215's on mine for almost 5 months now and all is well. They're stretched but only a tad and it doesn't look stupid at all. Of course I'd rather have some 245's but like you my tires were pretty much brand new and I don't have money to get new tires to replace my new tires lol.
Here's the best pic I have that shows how they fit on the wheel.
2009 CWP Mazdaspeed3
- COBB AP V3 - Richtune - 50/50 E85 - Autotech HPFP Internals - CNT Catless Downpipe - HTP 3" Intake - NGK One Step Colder Plugs -
- Kozmic Motorsports EGR Deletes - JBR 88 RMM/TMM/PMM - JBR Shifter Bushings - JBR TIG + Coolant Bypass - JBR OCC -
- JBR RSB - GroundControl Coilovers - CorkSport Camber Plates - CorkSport Rear Camber Arms - CorkSport Rear Toe Arms -
- WhiteLine Front Endlinks - WhiteLine Bumpsteer Kit - WhiteLine Poly LCA Bushings - AWR Rear Endlinks -
- 18x8 Mazdaspeed MS-01S - Nitto NT05 245/40/18 -
gmoney542 is offline   Reply With Quote
 Old 12-22-2013, 11:54 AM   #42
Natey's Avatar
Posts: 536   (View Stats)
Natey is the leader of the worldNatey is the leader of the worldNatey is the leader of the worldNatey is the leader of the worldNatey is the leader of the worldNatey is the leader of the worldNatey is the leader of the worldNatey is the leader of the worldNatey is the leader of the worldNatey is the leader of the worldNatey is the leader of the world
Groaned at 28 Times in 13 Posts
Originally Posted by Agent_Orange View Post
I'm still confused as to why a brownie is calling into question an OG's need to create a thread asking for help/input.
So what you've seen people get "pole-axed"? You wanna jump on the bandwagon and do the same shit huh?
You picked the wrong thread.
That's cool the OG wants to be herra frush, but I ain't gargling anyone's e-sack no matter how much money they gave to a website. This subject has been beaten to death. I'm riding on CCWs, how about you?
'93 RX-7: 100% CARB approved. Just some wheels and stuff.
'03.5 Mazdaspeed Protege: Custom clunk and turkey call.
'12 4Runner Limited: Hollister Hills pinstripes, dog hair, beach sand, melted surf wax, a few french fries under the seat...
Natey is offline   Reply With Quote
The Following 3 Users Say NO Thank You to Natey For This Un-useful Post:
Agent_Orange (12-22-2013), helmetface (12-22-2013), Status Update (12-22-2013)
 Old 12-22-2013, 12:18 PM   #43
btstarcher's Avatar
Posts: 4,852   (View Stats)
Groans: 112
Idiot. Nitro has been here since nearly the beginning. He's not "hella flush." He's trying to save money.
SnailTune in progress
 Old 12-24-2013, 12:23 PM   #44
Design's Avatar
Posts: 1,887   (View Stats)
Groaned at 9 Times in 5 Posts
Originally Posted by LumberJack View Post
@Nitr0EngiE; I just put a set of 18x8.5 +35 Gold Konig milligrams on last night. If you go with a 8.5 and +45 you WILL NOT CLEAR YOUR STRUT!
That probably needs some clarification. 235/40 +45 will clear with an OEM-equivalent perch (Koni, Bilstein, etc). It may not clear on KW/MS coilovers depending on how far the perch is dropped.
We have had several members here run 235/40/18 +50 on KW struts - no rubbing. 245's will generally require a minimum of +40.
09 CWP MS3 GT
Ownership & Build Thread
Design is offline   Reply With Quote
The Following User Says Thank You to Design For This Useful Post:
btstarcher (12-24-2013)
Trouble Picking Rims Noodlesincup 2010 MS3 - Wheels & Tires 14 12-27-2011 06:50 AM
Picking up a MS6 dubunderpar Mazdaspeed3/6 General Discussion 7 12-11-2011 08:32 PM
Page generated in 0.26344 seconds with 24 queries
