Need some serious help!!!! I have 12mm, open ended lug nuts and was taking one off and the damn lug nut split!!! Any ideas of how to get it off!!!??? Thanks. |
can u take a pic of the problem? |
+1 for pics. We would need to see the problem in order to help you properly. |
Don't have the camera now. It is a lug that has a key that goes into the lug, not on the outside. Like a 12mm allen wrench. Hope this helps. |
camera phone? |
What if you tighten the other four nuts, leaving enough play in the broken one to get off with vicegrips. How cracked is it? Can you crack/split it more and just break it off? |
Vice Grips FTW. |
You can try a Gator Socket. http://www.endeavortool.com/admin/files/ggrip_20.gif |
When all else fails, brute strength and ignorance prevails. |
| All times are GMT -7. The time now is 09:35 AM. |
